Technical Slip yoke to exhaust clearance
Discussion in 'The Hokey Ass Message Board' started by Crotty 32, Mar 4, 2023.
  1. Crotty 32
    Crotty 32
    I am slowly building the exhaust on my 32 roadster project (8ba flathead and T5 transmission) and I am curious what the consensus is for clearance for the exhaust pipe to the slip yoke. I do not have the slip yoke yet, but mocked up my best guess using a cardboard tube and a 4” wide white piece of poster board taped to it, 1.25” away from the tail house of the transmission. This is getting me 1/4” clearance. Is it enough?? The slip yoke diameter is probably more like 3.75” wide, so I might have 3/8” clearance in reality. Thoughts???
  2. 6sally6
    6sally6
    I'd go with it but........that's me.
    Shouldn't be much/any ....side-to-side motion between the yoke and pipes.
    6sally6
    Just Gary and Crotty 32 like this.
  3. 325w
    325w
    What he said.long as it don’t hit your good
    Crotty 32 likes this.
  4. Mr48chev
    You are going to need the same room a the yoke on the rear end takes plus wiggle room and clearance. Remember you are working with the circle that the yoke spins in and not just the flat measurement.
    Tow Truck Tom likes this.
  5. BJR
    BJR
    How about the U joint width?
  6. I’d run it.
    mad mikey and Crotty 32 like this.
  7. jimmy six
    jimmy six
    The only time I believe heat on the u-joint would be a problem is if spend a lot of time idling or in parades. A spinning u-joint on a drive shaft stirs up a lot of air and so does air p***ing by exhaust components.
  8. Crotty 32
    Crotty 32
    Thanks for the replies. I feel better about the location now and will continue the exhaust build as I have it now.
    Just Gary likes this.
  9. 1971BB427
    1971BB427
    from Oregon
    Since it's up front the side deflection is minimal. Even if the rear axle shifted 1/2" the movement up front wont be more than maybe 1/16". But it does look like your exhaust could easily move out a little if you're not sure, and maybe just cut a notch in the cross brace if it's too close.
    mad mikey, Just Gary and seb fontana like this.
  10. Crotty 32
    Crotty 32
    Thanks. I do have some room to move the pipe over, but I’d like to avoid it if possible….more work and it may shift the muffler a tad too close to the ladder bars.
  11. Dak Rat
    Dak Rat
    from NoDak
    You will be fine. Nice pictures by the way!
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Am I seeing something of more concern? F00B02FE-C702-4424-9494-95897E80E191.jpeg
    Desoto291Hemi and mad mikey like this.
  13. '49 Ford Coupe
    '49 Ford Coupe
    It appears that you've got at least another inch maybe 2 inches of clearance by starting that elbow a little more to the right. It would be more than disappointing 5 years from now if you start hearing a banging sound coming from under the floor.. only speaking from experience, I have "retrofixed", if that's a word, more than a few things on The Judge... That's a whole lot easier to make the change now then when you are on the road.
    seb fontana likes this.
  14. nobby
    nobby
    you want the 1310 small slip yoke
    not a 1330 or a 1350
    you want a th350 gm slip yoke 1310
    n/b
    the prop place i go to will only use 3'' tube on anything about 55 inches long
    why is that?
    is it because he only has 3'' 1310 drive shaft yokes
    or is there something to it?
    plus of course, you don't want the stock gm style slip yoke with the inney clips either
    and want the style with the outey clips
    2 cents
    qnd lastly
    what length is a stock s10 slip yoke
    and very lastly
    are you aware that it is noted that you ream the internal oi;ite style bush to fit the slip yoke
    maybe if its a new bushing
  15. Crotty 32
    Crotty 32
    Concern being close to the frame? I’ve got 1/4” clearance at those spots, though the pics don’t reflect that. I know it’s not a very clean routing, but I just went with the direction the Reds Headers were pointing until I could shoot the pipe up inside the frame
  16. Crotty 32
    Crotty 32
    This is what has been lurking in the back of my head after I finished that first section. I looked proudly at my beginner-level work and thought “****….will that be enough room for a slip yoke?”
  17. Crotty 32
    Crotty 32
    Yes! Thanks for the reply. I’ve been researching slip yokes and u-joints to try and determine what I need and the size of it and came to the same conclusions - 1310 with the outey u-joint clips.
  18. nobby
    nobby
    oh and if you are a novice, NO NOT put any paint on the pinion yoke where the universal joint sits in...........
    Crotty 32 and Just Gary like this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No below the K member rather than thru it as far as ground clearance is concerned. But it appears this routing is only temporary so carry on.
  20. '29 Gizmo
    '29 Gizmo
    from UK
    At least put some heat wrap on it. Even this far down the pipe can still be extreemly hot.
    Crotty 32 and mad mikey like this.
  21. mad mikey
    mad mikey
    I think for the most part you are good to go. I would not ponder on little measurements and increments, as long as you have clearance.
  22. Crotty 32
    Crotty 32
    Ah, gotcha. I think ground clearance is OK at 9” (at unloaded ride height). The pipe is actually above the transmission case and the bell housing. I was thinking of going through the frame from the headers, but the way the header is positioned it was already shooting in this direction so I went with it. Figure it might be easier to install/remove with this forward portion under the K member as well. Little quirky and won’t win me a Riddler, but it should work. 7E76B93E-7E64-4824-B7EF-D901897388E5.jpeg
