Projects Bought a Mercury on purpose
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Feb 4, 2023.
  1. One of the heads from my $200 marketplace “rebuilt” 283. Not bad. Valves look good. Will get my machine shop guy to check the guides.
    Crank looked great. It’s getting checked.
  2. BamaMav
    BamaMav
    from Berry, AL
    Surface looks fresh machined.
    anthony myrick likes this.
  3. bobss396
    bobss396
    More like it was hit by a whiz-wheel...
    Budget36 and anthony myrick like this.
  4. Both
    Cleaned up the old gasket
    Heads appeared to have been surfaced
    chryslerfan55 and bchctybob like this.
  5. Squablow
    Squablow
    There are bolt-on transmission side mounts to use SBC front mounts in a 55-57 Chevy with a later trans so you wouldn't need the tail shaft mount. Guys use them when they swap out Powerglides/Turboglides for newer transmissions without swapping out the original engine. They'd be easy enough to make, bolts to the bellhousing bolts.
    The engine in my '57 has front mounts and a tail shaft mount, and I added some of those bolt-on center trans mounts to it but didn't run them down super tight, they act just like those Y-block steady rests shown earlier. It might be overkill (or bad engineering on my part) but it hasn't had any issues yet.
    As long as the flathead goes into something, I'm happy with that. They're more fun in a light, early car than in a big 50's sedan anyway.
  6. Visited the machine shop with the 283.
    Crank is perfect. Block needs bored.
    No big issue. But……….they are booked solid
    Shouldn’t post this but my wife brought up the hemi again.
    Arghhhhhhhhh
    So after getting back from the machine shop I dug up my hemi ****.
    Did another thread asking a few specific hemi questions.
    Decisions decisions decisions.
    the machine shop is booked up for about 6 weeks. Race season starting.
    might just see how this fits in the parts car at the house to see what I’m up against.
    while I’m waiting.
    I guess this **** is cheaper than drugs
  7. 51 mercules
    51 mercules
    Hemi will fit in your merc![​IMG][​IMG]
  8. Cool.
    I’m kinda on the fence for on the road quick and doing the hemi or Y.
    But since my machine shop is booked, I might just check.
    I have another complete 331 I might just fit in my parts car. I could mock up and build mount, check for steering link issues……
    I’ve looked at the small block mopar bells.
    Might just pic one up.
    im thinking on keeping it 3 pedals. But that’s not written in stone either.
  9. 4 pedals
    4 pedals
    from Nor Cal
    I'd want a smooth, powerful custom. Hemi could do the trick while being a vintage engine.
    Devin
  10. 51 mercules
    51 mercules
    I was thinking 3 pedals too. I have a 50 olds 3 speed but I was having a hard time finding a 50 olds/37 la Salle adapter at the time, so I went with a turbo 350. I still might do it one day.
  11. Engine will be vintage.
    I’ve also got an FE. But I know I could finish this 331 for the $ it’d take to do the FE
  12. I’ve got a truck early hemi bell and FW.
    Clutch fork is on the p***enger side.
    I’ve located a 833 bell and trans.
    Hmmmmmmm
    I’ve got 2 complete 54 and 55 Chrysler autos. Couldn’t give em away.
    In my stash of parts I do have a good th400, a buildable th350C
    just for spits and giggles. Possible to hook up one of the ford top loaders I have with this or an OE mopar small bell?
  14. SS327
    SS327
    SQUIRREL!!!!!!
    Someone had to stop him! Too many choices! 283 and be done with it!
    Torkwrench, bchctybob, Tman and 4 others like this.
  15. Yep.
    I guess this is what happens when you “organize” the. shop
    But it’s probably an even race right now.
    Took a couple caps off the Y. It looks great.
    It would run as is after a clean up and gaskets. :)
  16. Gettin there
    0CED0F88-C5AD-4FD6-B053-679A88FB71CD.jpeg Spot was about 3/16 thick on filler.
    C29E7D11-42DD-4B67-95CD-01E59F4A48B6.jpeg C73861BD-F59D-4CE4-B2E9-EC6CD81D66ED.jpeg EC41A66D-D65D-4CAC-BC48-AD7DC627A852.jpeg
    just about there. Just a little fine tuning left.
  17. 24FDD01D-B814-4485-80D3-B84367783363.jpeg D5D929AA-5387-4843-8770-FA2988EA069F.jpeg E930A062-94E7-4FEF-82F9-9ADC5317BE0D.jpeg 8FE68F3F-6E9D-48E4-9EA6-064CB7DD054B.jpeg
    roughing out the front of the fender and splash pan
  18. nrgwizard
    nrgwizard
    from Minn. uSA
    Thanks for the pics. Too bad I don't get to see/observe in person. But it's helpful. :) .
    Marcus...
    Algoma56 and anthony myrick like this.
  19. Sr cl*** progress.
    I like to map out highs and lows with a marker.
    fender is ironing out
    Still got more to go
    students we’re introduced to a shrink disc
  20. s55mercury66
    s55mercury66
    from SW Wyoming
    A shrinking disc is something I haven't thought about in a while, thanks for the reminder, I need a new one.
    Algoma56, bobss396 and anthony myrick like this.
  21. bobss396
    bobss396
    Your kids are doing an amazing job. I used to live for my auto shop cl***es.
  22. Anthony, you're a pretty sharp guy so rather that give you an answer based on my opinion I'll say this. I know you understand alignment settings and what a few degrees of movement does to correct things. Now, take the spindle support and install just the King Pin in the 2 bosses. Stand the upright vertical as in it being installed in the vehicle. Notice the king pin angle. Now turn it upside down and move the Top mount eye inboard far enough to get the King Pin back to the angle it was at in the other position. Now you understand what's at hand.
    Kustom guys have been destroying steering geometry for generations for the sake of Looking Kool. Anyone can bend parts enough to get the Tires pointing forward enough to go straight. Going around corners and returning to center is another issue. A lot of people think a Hot Rod don't need good driving manners as long as it Looks Kool. I happen to disagree. There also can become safety issues with doing the Upright flip. Then there's a Tire Scrub and ware issue that jumps into play that some will say don't matter, again I disagree. Looking Kool can be done and also work well and be safe if you're willing to understand the issue at hand and fully understand what you're doing. There's also a steering term that 80 percent of home builders don't even know, it's Ackerman. Most I Beam Hot Rods never even get this addressed. It comes into play in every 4 wheeled vehicles out there. When it's Wrong few even know what's wrong but when its Right, man is it a pleasure to drive.
    Gets down to basic Math and Geometry. You can't dispute the facts.
  23. I’m smart some days. Just not the ones that end in Y.
    That thought came up after seeing a camber mod used on shoeboxes in some threads on flipping uprights.
    Kinda sounded smarter until ya digested the thought.
    It also came up with a guy here locally that is flipping his and shortening the upper A arm.
    The fabricated ones look sketchy.
    And folks have lots of miles on em.
    I guess I’ll mess with lower springs and cruise it.
  24. Going from memory (that's a dangerous thing today) I believe the lower spring plate is riveted to the actual A-Frame arms. If you like the ride of stock coils you can drill out the rivets and use 3/4" bar stock making a spacer and bolt it all back together. I think that lowered the car 1.750 and kept you in adjustment range of the stock Cam bushing.
    chryslerfan55, Algoma56 and SS327 like this.
  25. Dang I’m glad a friend of mine visited the s**** yard before I did today.
    not sure if 352 or 390. 64ish. Has the breather on the intake.
    S**** yard killed everything but the block, intake and heads but at least we saved this. Word was someone dropped off a 64 galaxy. No sign of the trans was found. Was told it was a 4 speed car :mad::mad:
    I guess we should be thankful for what we saved.
    Plans are for it ending up in a chopped 50 ford coupe with a FMX
  26. If it had a 4 speed on it look for a pilot bushing in the crankshaft, however it looks like the remainder of a Kickdown linkage on the intake. I don't think 64 was throttle cable yet.
  27. Has a manual bell.
    S**** yard killed it.
    Trans was the old bolt pattern.
    The block breather tube could be what you may be referring to.
    chryslerfan55 and Algoma56 like this.
  28. s55mercury66
    s55mercury66
    from SW Wyoming
    The blue on the FE indicates 1966 and up, I always thought, but that is not so, 352's ARE blue, 390's are gold.
  29. It’s been messed with.
    Intake casting number starts off with C4
    The heads are older
    chryslerfan55, Algoma56 and bchctybob like this.
