Technical Ford Model A Vega box to 525 swap ?
Discussion in 'The Hokey Ass Message Board' started by ModelEh1931, Mar 5, 2023.
  1. ModelEh1931
    ModelEh1931
    Has anyone with a Model A swapped out there Saginaw 140 (Vega) steering box with cross steer to the larger 525 box ?
    Thank you.
  2. Fordors
    Fordors
    Other than the input shaft being longer requiring a change how your column connects the 525 it is a direct bolt in.
    olscrounger likes this.
  3. krylon32
    krylon32
    from Nebraska
    525 is overkill on a Model A
    lothiandon1940 likes this.
  4. 31Apickup
    31Apickup
    It’ll bolt to the same mount but is much bigger and may not clear motor mounts.
  5. ModelEh1931
    ModelEh1931
    Thanks for the replies.
    Keep ‘em coming.
  6. nobby
    nobby
    the c3 corvette input worm will go in a gm 525 and have a quick input.and the input shaft itself is just the stub - or you dont have the 3 inches sticking out of it so youi can swap for a power 800 and suchlike
    the 1980 camaro manual pitman arm is the one that fits them and is straight, plus it has a wee small hole in it enabling the opening out of it for a early ford tie rod
