Technical I need advice
Discussion in 'Traditional Hot Rods' started by jerryt, Mar 8, 2023.
  1. jerryt
    jerryt
    When I started this project I ordered gauges to keep track of things. But the old adage spit happens but me. I have an amp gauge where I lost the bracket and light. My question is the bracket have to be insulated? Or can I just bolt on a regular bracket onto this gauge? One of the old brackets have a plastic insulation. But it doesn’t fit my gauge. I guess worst case scenario is just don’t mount amp gauge. Any ideas?
    Thanks
    Jerry
  2. Fordors
    Fordors
    Insulated, no getting around it.
    Boneyard51 and hrm2k like this.
  3. Rocky
    Rocky
    Classified Editor
    Advise: Ditch the AMP gauge and run a volt meter instead.
  4. exactly. ^^^^^ all an amp gauge does is tell you how much juice you are using, not how much you are making.
    OH to answer your question yes like someone already said it needs to be insulated.
    jim snow, SS327, alanp561 and 3 others like this.
  5. belair
    belair
    Listen to those guys^^^^^
  6. ratrod harry
    ratrod harry
    Amp gauge is traditional. No volt gauges in 65.
  7. Plant your corn early
    bout the best advice I have today
  8. saltracer219
    saltracer219
    There definately were volt gauges in 65. Stewart Warner offered them much earlier than that, you just diden't see them as often as you did Amp Gauges.
  9. Mr48chev
    Didn't have many charging systems that put out more amps than what the ammeters would handle or many vehicles outside of emergency vehicles that had larger amp draws than what an ammeter would handle either. You were big time in 1960 if you had a 9 inch rear seat speaker, a fader switch and a reverb box in the trunk.
  10. deucemac
    deucemac
    Contrary to popular wive's tails, ammeters are safe and reliable if they are matched to the system current demands. Detroit got away from them because of the cost of building an ammeter consistent with the later u trans high amperage draws. It would be very expensive and require very heavy gauge wire to and from the unit. An ammeter shows the condition of the charging system better than a voltmeter. On àn average 12 volt system it will take about 13.8 volts to override the battery and have it accept a charge. Volt meters only show system voltage and never indicate charge rate. If you see an ammeter showing a charge, the system must be at least above the 13.8 volt threshold or no charging takes place.an ammeter shows current draw in the system but a voltmeter shows only voltage. If the voltage drops below the 13.8 level, no charge takes place. But, it still won't show you if the system is being charged properly. Given the choice, I prefer an ammeter over a voltmeter. But since modern systems draw a tremendous amount of current and I am certainly not a rich man. I would default to the voltmeter. Just an example, a modern fuel injected V8 can draw as much as 40 amps to pulse the injectors at highway speeds. Add the lighting system it is nighttime and air conditioning if it's hot plus windshield wipers if it's raining you can easily have in excess of 100 amp output, that's why the voltmeter, it's cheap and easy to install .
  11. 64Pony
    64Pony
    You can buy insulator washers cheap. I’d bend up a new bracket to fit the gauge.
  12. enjenjo
    enjenjo
    from swanton oh
    Send me a PM I likely have the parts you need just for the postage. I need the spacing on the studs.
  13. loudbang
    Not quite during the 60's mopars had a severe ammeter problem with ALL power going through the meter and ANY short in any electrical circuit would result in fires. Made a small fortune (for the time) in OT replacing them under warranty at our dealership.
  14. hepme
    hepme
    HAMB advice is real cheap. Do what they say.
    Just Gary likes this.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    July 1961 date code on the Stewart Warner volt gauge in my 40 2B0032BB-8412-4362-92D3-CAC81466E748.jpeg
  16. Boneyard51
    Boneyard51
    I did a lot of those amp meters also on Police cars, back in the early seventies. The thing about is was not all failed. Some worked just fine. I always figured the ones that failed , failed due to the nuts on the back of the gauge came loose, causing it to arc. There was a piece of copper way larger than the wire to connect the in and out wire! But the damage was always very close to the gauge, usually centered at the connection!
    You are right though, 100% of the currant the car used, went though the gauge! Connections are very important!
    Bones
    5window likes this.
  17. Budget36
    Budget36
    Didn’t some models of 40 or so fords come with a volt gauge instead of an ammeter?
    SS327 likes this.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, My 40 has a factory volt gauge ....
    Outback and Budget36 like this.
  19. Atwater Mike
    Atwater Mike
    Panteras used ammeters, think for a main fuse. :D:eek: Replaced LOTS of them for wealthy yuppies in Silicon Valley mid-'70s. Only 3 fires, I recall. Most went dead in the water. Then dry-docked. (grin)
  20. Budget36
    Budget36
    Seems it can be-gasp-considered “traditional “ then;)
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    I do have a 1961 SW volt gauge in my car. I will agree though that there were far more Ammeters in cars back then , people seem afraid of them these days. I am not sure that most know that a 30 amp ammeter and a car with power everything and a 150 amp alternator do not mix.....
  22. Rickybop
    Rickybop
    The HAMB is so sweet LOL.
    Never ceases to amaze me.
    The man asks whether he needs to insulate his gauge. He's offered the missing pieces and we all learn the ins and outs of ammeter vs voltmeter.
    I could ask why wheels are round. I'd come away with the formula for pi and the recipe for synthetic rubber.
    :D
  23. Rickybop
    Rickybop
    Oh yeah... and how to make it in your backyard in a trash can for cheap. ;)
  24. twenty8
    twenty8
    ........... with videos on their own yoochewb channel..........:rolleyes:
    i7083, Rickybop and Outback like this.
  25. jerryt
    jerryt
    hi I’m Jerry. I posted the question about amp gauge. Here is pictures of my gauge. It’s a summit racing 21/16 gauge.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    he wanted you to send him a PM
    Budget36 and badshifter like this.
  27. badshifter
    badshifter
    After all this, it’s a Summit Racing Gauge we got all traditional argument about.
    Budget36 and Moriarity like this.
  28. Ebbsspeed
    Ebbsspeed
    It depends on where in the system the ammeter is wired.
    Elcohaulic likes this.
  29. Budget36
    Budget36
    Click on his name and start a conversation:).
  30. BamaMav
    BamaMav
    from Berry, AL
    If memory serves me, there is a ammeter style that doesn’t require all the current flow through it, it reads by induction, the pickup is wound around the wire but not connecting to it. I have also heard of using a connection that only p***es some of the current through the meter by using a byp***, maybe called a shunt, so the meter can’t be overloaded.
    Been a while since I had an ammeter. I’ve got the same voltmeter Moriarty has in my car. Not sure when it was made, but looks just like his.
    Atwater Mike likes this.
