Folks Of Interest Canadian v8 flathead question:
Discussion in 'The Hokey Ass Message Board' started by don daddyo, Mar 9, 2023.
  1. don daddyo
    don daddyo
    I've got this engine flathead ( made in Canada ) with the serial number ( rc10939 ) and a star at the end of the number , plus the transmission must be a 3 speeds...need info on that ...thanks , Don
    Oh ! and the heads are EAB 24 studs...
  2. 19Fordy
    19Fordy
    don: Please post photos of what you are dealing with including the transmission.
    Also, what specific questions do you have about the engine?
    You might also want to post your questions on www.fordbarn.com
    The information below will help.
    eab flathead ford - Search (bing.com)
  3. don daddyo
    don daddyo
    thanks, I have the engine with the trans... on , I will take photo as soon Ill be able to
  4. don daddyo
    don daddyo
    upload_2023-3-10_9-50-20.png upload_2023-3-10_9-50-50.png upload_2023-3-10_9-51-50.png upload_2023-3-10_9-52-23.png here are the five pics have take today...the Flathead I've upload_2023-3-10_9-52-50.png
    OzMerc39 likes this.
  5. don daddyo
    don daddyo
    Is this worth rebuilding, that would be for my 29 Roadster Ford...?
  6. trey32
    trey32
    The trans appears to be a truck four speed
  7. 19Fordy
    19Fordy
    The floor shift makes me think it came out of a truck.
    It looks to be worthy of a rebuild BUT, the only way will know for sure is if you
    remove the heads and check for cracks in the block. Also, check the stroke to verify that its
    either a 3 3/4 in. stroke (Ford) or 4 in. stroke (Mercury) as someone might have installed a Merc. crankshaft
    ***embly years ago. Also, remove the intake manifold to see if adjustable lifters have been installed.
    Take photos and notes as you go. I wonder what that sending unit that is screwed into the headbolt on the bottom left of your last photo is for? It would be great if a Fordbarner could decode the RC10939 date code stamped on the intake surface.
  8. alchemy
    alchemy
    Sure it's worth rebuilding! If it's not cracked up. Tons of guys love flatheads, and there are parts available to do anything you could want to do to them.
  9. don daddyo
    don daddyo
    Thanks again for the info ,Oh ,I will check further for some more...but for now I on some reno... at home , but I'll be back with some photos and notes
    thank you all...Don
  10. 1952henry
    1952henry
    Believe the transmission to be a T98 WG synchronized 4 speed. Bellhousing looks to be from a 53 truck. Could be 54 in Canada as you folks kept the flatly for one more year.
  11. don daddyo
    don daddyo
    I've check the transmission ,and it is a 4 speeds and yes it was on a pick-up Ford 1953 ,and the engine seem to be the original and never been rebuilt ...I think...
    210superair likes this.
  12. A 2 B
    A 2 B
    from SW Ontario
    I don't see any obvious rust on the heads. Are they possibly a set of the elusive factory aluminum heads most usually found on trucks in Canada? It appears to be the correct color paint for a '52/'53. Maybe not, its hard to tell on a computer screen. I would definitely check the stroke on that one. Good luck with it! tumblr_nfypbtPzxL1rn8k76o1_r1_1280_zps14a7a4be.jpg
  13. don daddyo
    don daddyo
    No ! the heads are casting , not alum.. and the color was green like your photo and it's complete so...
  14. don daddyo
    don daddyo
    and the heads are made Canadian cast
  15. don daddyo
    don daddyo
    Could that sending unit ,would be a block heater or else !!!
    Center of the Galaxie likes this.
  16. Yes that "sending unit" on the head bolt is indeed a block heater. :)
  17. don daddyo
    don daddyo
    YEESSS! I knew it...thanks a millions...
  18. don daddyo
    don daddyo
  19. don daddyo
    don daddyo
    My V8 Flathead...it turn free , no cracks anywhere , the block seems very workable...but I can't upload the video I did...Is there something that I miss ?Don It said , ; The following error occur
  20. clem
    clem
    I think that for videos - you have to put them on YouTube and then add a link to your post here.
    I tried to upload one and that’s how I understood it.
  21. don daddyo
    don daddyo
  22. don daddyo
    don daddyo
    the video will come tomorrow...
  23. eaglebeak
    eaglebeak
    I pulled two motors out of Ford trucks up here and both had 4" cranks.
  24. don daddyo
    don daddyo
  25. don daddyo
    don daddyo
    finally...done
