Technical 50 Ford hood release
Discussion in 'Traditional Hot Rods' started by Steven Junkersfeld, Mar 8, 2023.
  1. Hi,
    Any tips on opening the hood on my 50 Ford after the cable release breaks? Had the same issue on my 47 Lincoln, but I was able to push the release through the grille with a wood dowel. No such luck on the Shoebox.
    Thanks for any help
  2. manyolcars
    manyolcars
    We all need a second release for when the cable breaks
  3. Yep - lessen learned!
  4. You have to remove the Grill so you can get your hand with a Small screwdriver above the center bullet of the Grill. find and hook the raised eye of the release lever and slide it sideways. Ask me how I know that. Notice the small piece of wire running alongside "NEW" my release cable.
    alanp561 likes this.
  5. The other way is to take an Ax and chop an access hole in the Hood. I wasn't into that.
  6.
  7. Thanks for the info! Yeah, the axe solution falls into the same category as my cutting torch fix - not aesthetically very good.
    Pist-n-Broke likes this.
  8. DKcoupe
    DKcoupe
    I made this tool for my 47 Chevy, but something similar should work for any fat car. Bent up an old screwdriver. Slide it in between the hood and top grille bar on it's side. Then turn it 90 degrees and push latch open. The red heat shrink tells me how far in to push it. Keep it in the trunk and practice using it once in a while. Also its a good idea to keep your cable and latch lubricated. The duct tape is just there to hold it for the photo.
  9. DKcoupe
    DKcoupe
    I might add that if you can't get into your hood now, I would find someone else with a similar car and make a tool like that before cutting up your car.
    Atwater Mike likes this.
  10. HOTRODPRIMER
    HOTRODPRIMER
    Exactly what I had to do. HRP
  11. inthweedz
    inthweedz
    Is there any way you can grab the release cable from thru the grille area, if so, give it a good hard pull and see if it will release the hood catch (before the inner cable has a chance to slip inside the outer)..
    I had the same problem with an OT car, and one good pull was enough to do the trick..
  12. seb fontana
    seb fontana
    from ct
    I call the cable company; they fix whats broke.
  13. Atwater Mike
    Atwater Mike
    Performed this exact operation on an unsuspecting damsel in distress's O.T. car...
    Her response? "OH, HOOKEYE..."
