chevy II 153 four cylinder
Discussion in 'The Hokey Ass Message Board' started by junior 1957, Oct 21, 2012.
  1. 34Phil
    34Phil
  2. Tim
    Tim
    from KCMO
    Holy ****!!
  3. 1biggun
    1biggun
    Saw this today for $900 with a mega squirt fuel injection control.
    Not really HAMB material but found it interesting . Those blowers don't like fuel through them however if you want carbs Screenshot_20230305_133023_Chrome.jpg Screenshot_20230305_133023_Chrome.jpg Screenshot_20230305_133117_Chrome.jpg
    GuyW, Six Ball and Tim like this.
  4. Six Ball
    Six Ball
    from Nevada
    Interesting and not a bad price.
  5. dreracecar
    dreracecar
    from so-cal
  6. Tim
    Tim
    from KCMO
    Hell yeah!
    Six Ball likes this.
  7. dreracecar
    dreracecar
    from so-cal
  8. Tim
    Tim
    from KCMO
    Very cool!
  9. Tim
    Tim
    from KCMO
    Also that angle build into the valve cover under the breather is neat. Is that one of 12 bolt toms covers?
  10. dreracecar
    dreracecar
    from so-cal
    Yes, A friend gave me the tower breather, spent the next 4 hrs building the mount and blending it in, Going to black wrinkle the cover to hide the flaws and highlite the fins
  11. Tim
    Tim
    from KCMO
    I dig it man, whole package looks Great
  12. Flatrod17
    Flatrod17
    dreracecar, I know you said your intake runners are old VW webers but what is the box you have them welded to? Something you made as well?
  13. dreracecar
    dreracecar
    from so-cal
    Yes, started with some 4" x 4" x 1/2" structural alu angle for the top and outside. Machined the top fins with a ball endmill and flycut the thickness on the outside to about 1/4. Used a radius cutter for the corner to match the inside radius. Used another 4" x 4" x 1/4' angle for the back and bottom. Sized the box and welded them together, and again used the radius cutter on the corners. Machined the flanges off the runners, and bored matching holes on the box to weld to upload_2023-3-14_14-33-59.jpeg upload_2023-3-14_14-34-19.jpeg upload_2023-3-14_14-34-37.jpeg
  14. dreracecar
    dreracecar
    from so-cal
    Also instead of machining a hole for an oil fill, I used the stock fuel pump mount to make the oil fill direct to the pan
    INVISIBLEKID, X-cpe, Six Ball and 2 others like this.
  15. Flatrod17
    Flatrod17
    Thank you, It looks great!! I was thinking something like that for one of mine, but making it with a throttle body. I can't weld like that so I may not get that idea off the ground.
    Great work, like the supercharger!! I have a Potvin end cover and may try something like your set up.
  16. Tim
    Tim
    from KCMO
    Very cool that’s for the peak behind the curtain on how it came together
  17. I'm getting this project close to putting it in. I'm going to have some spare parts I will be listing on the for sale page, this weekend...just an FYI. Gene. Resized_20230322_192410.jpeg
  18. Beanscoot
    Beanscoot
  19. walls
    walls
    Could someone recommend me a flywheel? I’m ***uming a standard, not lightened is what I’m going to want?
    153 with an adapter to early V8 Ford trans with 10” Flathead pressure plate/clutch
  20. Tim
    Tim
    from KCMO
    Good question. I’d also lean towards standard
  21. Flatrod17
    Flatrod17
    This popped up on another thread here, any one here know what it fits? 4CB0DCE5-BA2C-4A48-8BDE-E79D1FEFE7FA.jpeg.jpg t
  22. Six Ball
    Six Ball
    from Nevada
    If you are using the 153 starter that mounts to the block I'm pretty sure you you are stuck with a 153 tooth 12.5" flywheel. I don't know if the Flathead clutch & pressure plate will fit on that. If your starter bolts to the adapter like the ones for the early Chevy small blocks you'll have to use a 168 tooth flywheel. The 10" clutch 14" 168 tooth flywheel was hard to find but I found one at Jegs. A lot of clutch plates have the right spline for the Ford trans but the hub may not clear the flywheel bolts. What ever works for a two piece seal Chevy small block will work for a 153.
    Tim likes this.
  23. Six Ball
    Six Ball
    from Nevada
    That looks like maybe for an Iron Duke. (151)? Maybe 181. Could be adapted for a 153.
    onelow41 likes this.
  24. BZNEIL
    BZNEIL
    I believe that is an EVM injection unit drilled for a Fontana/Arias Head based on the Chevy II. They used the same castings for both, you can see the undrilled stock Chevy II hole locations. I have EVM injection on my chevy II midget earlier in the thread.
  25. Flatrod17
    Flatrod17
    I believe you are right! Thank you BZNEIL, EVM is casted in it, I just couldn't read it. I did go back and look at your picture. Sure wish I had one of those!
  26. 29Coupe
    29Coupe
    Would anyone happen to know what the stock oil pressure at idle is supposed to be on a 153 4 cyl?
    thanks!
    Bone-Head likes this.
  27. hotrodbob
    hotrodbob
    Not sure what stock is, but on start up mine is 40psi and 15 to 20 hot. I run 5-50wt Castrol edge synthetic oil (was Syntec). Castrol said this was designed for flat tappet older engines. I have been using it for over 20 years on all my older cars.
    Was told by a racer friend that 10psi per thousand RPM is normal.
  28. 29Coupe
    29Coupe
    thanks! Are you running a stock oil pump or a high volume one?
    Mine running hot is around 20. And 10 around idle. That sounds about what you’ve got going on. I thought it was a little low. But maybe it’s ok.
  29. hotrodbob
    hotrodbob
    I didn't build the engine, but as far as I know from the builder it has a stock pump. The engine was built a little loose as far as pistons and it has a rattle. I also forgot to shut the fuel off and washed the cylinders down. Does not use oil and runs strong. Has a Rochester 2 jet carb, it runs rich and bogs on right turns. Just got a webber 2 bbl and clifford adapter to change it to.
  30. 29Coupe
    29Coupe
    Looks great! Thanks for the info.
    hotrodbob likes this.
