Technical Let's talk about seat foam
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Mar 10, 2023.
  1. Roothawg
    Roothawg
    I am getting close to doing the seats in the roadster. I am having a hard time figuring out what foam to use. It seems to me that there isn't a standard across the foam world.
    I am familiar with aircraft foam and there is a standard for the different foams. They color code the foam, based on the density. I just don't wanna pay for aircraft foam. It's stupid money. You pay for the certifications.
    In the aircraft world they start with a firm foam for a base, then a medium firmness then the soft on top. Glue it all together, then they carve it.
    I am trying to figure out how to do the same for the roadster. The only foam around here is for mattresses. Not even sure what to search for on the web.
    Let's talk.
  2. Stuff ain’t cheap.
    One place (don’t know the name) sent samples. Different densities.
    google automotive seat foam
    if there’s an upholstery supply place near ya, go visit.
    1oldtimer likes this.
  3. lostone
    lostone
    from kansas
    Watching this thread too as I was wondering the same thing!!
    Roothawg likes this.
  4. Roothawg
    Roothawg
    Done it. Been researching for weeks. It's a rabbit hole.
  5. My mattress is just one piece of foam and damn is it the most comfortable one i’ve had. I don't remember if it’s what’s called memory foam or not. I would consider buying a small mattress to use. Something like this from Lowes
  6. lumpy 63
    lumpy 63
    I sent my Corvette seats to Tijuana , They are pretty comfortable and don't smell like horse ****. Sorry Chris couldn't resist:p
  7. Roothawg
    Roothawg
    Well, that's a good thing...
    Okie Pete and lumpy 63 like this.
  8. Dedsoto
    Dedsoto
    from Australia
  9. Roothawg
    Roothawg
  10. rockable
    rockable
    lemondana, Okie Pete and Roothawg like this.
  11. Wayfair has memory foam mattresses from anywhere between $ 118,, to $ 200 for a regular size mattress,,,,,and go up to $300 and more .
    A nice 10 inch mattress was about $140,,,,I believe a man could get several seats out of that .
    You could shop and see,,,,,different thickness,,,different firmness .
    It’s just an idea .
    Tommy
  12. theHIGHLANDER
    theHIGHLANDER
    All I have to offer is a thought process. Are you using springs too? Let's say yes. If so, spring base 1st (easier than it sounds) then something firm, closed cell about 1 inch or so. Spreads the load. Next something softer, a little thicker and when the cover goes over that you'll pull it down to the final hgt. This gives a seat that holds you in place without being sloppy and springs ***ure long life.
    If no springs, all foam, you need a heavy dense base for support and strength then softer for seating surface. Source not often thought of? Packing companies. The places they send things usually s**** the foam blocks after time. I've scored enough "come n get it" foam to build a cpl seats and if you weren't so far away I'd say drop in and let's build one.
  13. Chavezk21
    Chavezk21
    I went to pick n pull for my last seat base. Found the newest car took the backseat out narrowed etc. I have a fried in the upholstery business. Foam for cars is stupid money. Lust like the aircraft foam different densities, glued carved etc. Or find a seat bottom, new foam replacements with durafoam then narrow and reshape for what you are using it on.
    vtx1800 and Roothawg like this.
  14. alchemy
    alchemy
    I bet Jim can tell us exactly what you need to know. Hey @stanlow69
  15. Blue One
    Blue One
    from Alberta
    The subject of foam for seats is definitely a rabbit hole and I really wish we could get some experienced upholstery people here who could advise us on the right foams and sources for them.
    I’ve asked the same question here before and was underwhelmed by the responses.
    With the number of experienced upholstery members we have responding to the upholstery threads it’s amazing that we can’t seem to get good information on seat foams and construction/ sources.
  16. stanlow69
    stanlow69
    This is out of a company in Chicago I used to buy from. Study this. Scan_20230103 (2).png Scan_20230311 (2).png Scan_20230311 (3).png Scan_20230311 (4).png Scan_20230311.png
  17. stanlow69
    stanlow69
    What I do. I go by what engineers have spent years researching and designing the shape of foam seats for automobiles for years. So I use what they know and get foam from used seats. If they have 100 thousand miles on them and are not destroyed. It must be good foam. A little repair might be needed to make the seats as good as new. Use the p***enger side foam for the drivers side. If possible. When looking at a new piece of new foam, (compared to wood) can you tell if it`s a piece of Walnut, of if it`s a piece of Pine. How long is it gonna last ?
    vtx1800, jim snow, Roothawg and 2 others like this.
  18. oliver westlund
    oliver westlund
    Go to craigslist, free section, look for memory foam mattresses and sofas, harvest n hault the rest to the dump. Its work and dirty but cheap as hell!
  19. oliver westlund
    oliver westlund
  20. stanlow69
    stanlow69
    Foam in couch cushions are way too soft and have no firmness as compared to auto motive foam. That`s why furniture is so cheap. They use cheap foam that does not last. That`s why it is difficult to know if a new piece of foam is worth a darn.
    vtx1800, Falcon61wagon, Tman and 3 others like this.
  21. Kerrynzl
    Kerrynzl
    Years ago ,I use to buy cheap foam mattresses just for the foam, and I use to carve them with an electric bread knife.
    Tip : always carve / shape the underside and let the top sides roll around the shape,
    If you must shape the top /outer edges ,glue a layer of 3/4"-1" foam around it [or it will appear lumpy]
    If you are putting foam directly onto a piece of ply [with no springs] put a layer of 1" polystyrene on the bottom.
    Your spine will thank you.
    I've built seats for off-road racers with 6" of foam that still "bottomed out" .so the poly fixed that issue. [like a helmet]
  22. stanlow69
    stanlow69
    Buying used mattresses off of Market place is not something I would want to use. No matter how good the foam is. Yick !
    Falcon61wagon, Tman, scotty t and 5 others like this.
  23. Roothawg
    Roothawg
    Thanks for the replies.
    A couple of things.
    We tried memory foam in our aircraft and all of the pilots complained that the seats were too rigid. We ended up replacing all of it.
    Next thing is, we do have springs in our seat frames. I had Wise Guys build us a set of frames to fit the openings since the car was channeled and had the drive shaft tunnel to contend with.
    My thing is I don’t know what is a standard thickness. 4” ? 3”? How much does it compress over time? I don’t want my covers to get loose in a month of driving.
    Jim, I will take a look at your info when I can see it better. I have old man eyes and I am looking at my phone.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    what makes covers look loose after a month is the springs digging into the foam, you need to cover the springs with burlap before you put the foam on it... but I am sure everyone already knew that
  25. stanlow69
    stanlow69
    This explains it much better. But to get this info on foam you are buying is the tricky part. The support factor, firmness and the density are what you want to know for good long lasting comfortable foam. And always buy the best. Don`t buy foam at fabric stores. Scan_20230311 (5).png
    Ned Ludd likes this.
  26. We had one custom built seat that used trampoline mesh/mat/whatever it’s called as the “springs”
    Rand Man likes this.
  27. If you live near a city, look up foam suppliers in the area. I worked at a place that used different types of foam, and sometimes I had to go to one of our suppliers. They took me around and showed me what was available.
  28. stanlow69
    stanlow69
    I`m sure there are different grades of memory foam as well. Putting burlap over the springs isn`t enough. You need to put a topper on it, or you will be able to feel the springs thru the foam. I use household bonded carpet pad foam. There are different grades of that as well. I always use this when a board is the base as well.
    2OLD2FAST and Roothawg like this.
  29. 40Vert
    40Vert
    I was taught to use 46 ILD (1.8) for the seating, and 70 ILD (1.8) for the bolsters if you’re custom sculpting the foam on a wood base. Keyston Brothers is a good supplier.
  30. stanlow69
    stanlow69
    Ford pickup`s used that for the seats for a couple years. I can post pic`s if anybody wants to see examples of anything I posted already. When putting foam directly over the burlap, springs, seat frame, glue some good material on the bottom side of the foam. The seat frame (ect...) will cut into the foam and break it down. Just look at your daily driver.
