Projects In need of help, Jenkins OHV B motor parts
Discussion in 'Traditional Hot Rods' started by douglasb, Feb 21, 2023.
  1. douglasb
    douglasb
    Hello all i have a 32 b motor with a Jenkins OHV conversion. I starting noticing some issues a bit before and during the Flabob TROG. Pulled her down when i got back and found some broken and bad parts. I didnt built this motor, i got her running/driving at the time and didnt investigate further. I pulled the motor and its at my builder. So we are trying to find some parts/help
    The bad
    #4 intake pushrod broken in half.
    #1-3 pushrods all rubbing and close to breaking also
    The rocker arm adjusters were hand tight and mismatched.
    A head gasket and spacer (for clearance)?
    #4 piston sits .60 thousands higher then the other 3.
    1-3 pistons sit almost flush
    Aluminum Fan pulley cracked
    If anyone has an idea on a replacement head gasket part number/brand
    Replacement pushrods or where i could get them made?
    Thanks all for any help or leads. 20230128_141916.jpg 20230128_141916.jpg 20230128_152705.jpg
    And why they mig 20230128_152705.jpg 20230128_153337.jpg 20230128_153334.jpg 20230128_155619.jpg 20230128_155622.jpg 20230128_160014.jpg 20230206_104344.jpg 20230206_104346.jpg ht of used a spacer and headgasket.
    Deuces, v8flat44 and Okie Pete like this.
  2. hotrodA
    hotrodA
    winduptoy and Okie Pete like this.
  3. Kevin Pharis
    Kevin Pharis
    from Califunny
    If yur gonna s**** the Jenkins head… I’ll happily give you the $2.00 per pound s**** rate! They are strong running heads and are well worth the effort to dial in. Yours probably suffers from amateur ***embly as many old motors do.
    The piston height difference is probably from a mismatched set of rods. This motor probably lost a rod bearing once upon a time, and the long rod is from a different batch. Talk with a reputable babbit pourer and order up a rod with a length to match the rest. Look up Rocker Arms Unlimited in Redding CA
    Okie Pete and Outback like this.
  4. Dan from Oakland
    Dan from Oakland
    The Jenkins heads were a project of Dan Iandola for quite a few years. Max McClain has a pretty strong running
    Jenkins on a B block in his roadster. Pretty sure that Pat Gary did a lot of the machine work on Max's engine. Pat is in Paso Robles if you want to discuss your issues with him.
  5. Outback
    Outback
    from NE Vic
    Were these the Jenkins heads that Andy Jenkins in Australia made in the 80's?
    Midnight Rider likes this.
  6. Dan from Oakland
    Dan from Oakland
    Outback- yes, my understanding was that Dan Iandola purchased the patterns from Andy Jenkins and brought them to the US. I don't know any exact details. I'll check with Pat on that and report back. Pat was pretty good friends with Dan.
    fur biscuit, Okie Pete and Outback like this.
  7. alchemy
    alchemy
    Okie Pete, Shain and Outback like this.
  8. douglasb
    douglasb
    Thanks all for the info
    HotrodA- thanks im just trying to get my engine builder in touch with them now
    Kevin- thats what my engine builder was thinking he was tearing it further apart to verify this past week.
    Dan from oakland- thanks for the info i have tried to gwt ahold of pat gary but the number from google is disconnected .
    Alchemy- it looks like the roof headgasket will fit i just need to confirm bore size before i order.
    Thanks all for the help and knowledge hoping to get her back together and be stronger for the next trog drags. Doug
  9. Dan from Oakland
    Dan from Oakland
    Outback likes this.
  10. douglasb
    douglasb
    So i got some more info from my builder, good and bad.
    The lower end is in good shape, it still has babbit bearings, but has a c model counterbalanced crank with wilson inscribed. The b motor block has don davis inscribed on it. And a jim brierly cam shaft. The pistons/cylinders are in great shape .60 over. He found issues with the rear main and had to modify/add shims to fix the leak. Looks like the #4 cylinder blew out the original headgasket as well.
    Just trying now to source the pushrods. I not finding an off the shelf length and going to need custom ones made. It looks like the roof headgasket will work. Hoping to get it all back together foe the next Trog. Also planning to switch out the 2 stromberg 81s for 2 97s.
    Also was able to talk to Max Mclain about his awesome jenkins set up and his builder Pat Gary.
  11. Outback
    Outback
    from NE Vic
    Glad you got some positive answers
  12. 51 mercules
    51 mercules
    Glad you got some good answers. I was also thinking the Riley or Roof gasket might work maybe some pushrods from a Riley too? Maybe contact Max at H&H Antique? I'm doing a Riley 4 Port and I'm using this plugs on the block for the pushrods to go through.[​IMG]
    Outback and Okie Pete like this.
  13. douglasb
    douglasb
    Thanks 51 merc i will try and call them. Also i had seen those vavle guides and was asking my builder his thoughts.
    Okie Pete and 51 mercules like this.
  14. 51 mercules
    51 mercules
    You're welcome!Keep us posted.
  15. burl
    burl
    from Minnesota
    There's a shop here in Minnesota that will cut custom head gaskets but you would need a file.We have used him for the custom heads we machine 814B89BC-EBC4-47C4-B266-541FFE492ECA (1).JPG
  16. Shain
    Shain
    from Omaha
    I'm not a 32 /Jenkins owner or builder, but this thread is kind of amazing.
    The knowledge and expertise displayed here.....and generosity of sharing it with members is top notch.
    Well done guys !
  17. 51 mercules
    51 mercules
    Just curious?Any updates?
  18. douglasb
    douglasb
    Thanks again for the advice.
    Yes some progess. Sorry been busy. So i was able to talk to Max and pick his brain on his fancy jenkins and also the engine builder Pat. Both are full of valuable knowledge.
    So my builder was able to get the bottom end ****oned up and all put back together. The babbit bearing and crank all still looked really good. My builder added a couple shims to seal the rear main that were MIA at first Causing my oil leak. The previous builder ran into an issue when bolting the jenkins head on as the pistons were hitting the head. So he made a .125 thick spacer. This spacer has become an issue as its now a weak point and helped the headgasket fail at cylinder #4. After talking with both builders it is agreed to maching the head to accommodate the pistons and remove the spacer. Also it was found that i have the incorrect rocker arms and thats why the pushrods were rubbing the block. So at this point she isnt making it to the trog this weekend. But ill be picking up the motor from my builder in SLC and taking it to Pat in Paso to do the machine work to the head and get it back together. Really looking forward to seeing what she can do with 4 cylinders running.
    Midnight Rider, Okie Pete and Outback like this.
  19. studebakerjoe
    studebakerjoe
    If it were my engine and my head I'd rather get another set of pistons than machine the head. Pistons are easy to replace but a rare head not so much. Just my 2 cents.
  20. Outback
    Outback
    from NE Vic
    Would be interesting to hear the thought process, because it's harder to put material back in a head...
  21. denis4x4
    denis4x4
    from Colorado
    Crower made the push rods for my CRAGAR head on a B engine.
  22. I wonder if you could cut a solid copper gasket if you had access to a laser cutter. if only there were some way to scan the surface and make the file from the scanned head, or old head gasket.
  23. burl
    burl
    from Minnesota
    Thats what they do. Need a file to program to.
    The_Cat_Of_Ages likes this.
  24. burl
    burl
    from Minnesota
    Just curious but wouldn't just machining the head change the combustion chamber cc ? I know when we machined our heads there was a certain number we tried to achieve to make it make the right kind of power. Just curious as it seems like the lesser of two evils to make it work but having the right pistons would help the head to do what it was supposed to do. Hope John N can chime in with his expertise.
  25. 34 5W Paul
    34 5W Paul
    from Fresno CA
    Thanks for the ride along, absolutely fascinating.
    I agree with Burl, milling piston tops seems like the better option with a piston/head issue.
    One item I haven't heard about the remedy for - the one piston having .060" positive deck height versus the others. One opined that it might be a mismatched set of rods. Either way, the rod length can be corrected. What's been done to correct that issue?
  26. Outback
    Outback
    from NE Vic
    @johnneilson
  27. Dan from Oakland
    Dan from Oakland
    This is not Pat's 1st rodeo. He is perfectly capable of finding a solid solution to head - piston- combustion chamber issues without taking unnecessary risks. Sounds like the initial build might not have been quite up to par.
    Outback likes this.
  28. douglasb
    douglasb
    Thanks you guys have some good points about milling the head and pistons. Ill give an update once i drop off the motor to pat and he physically has it in his hands he can come up with the best solution.
    Outback likes this.
  29. douglasb
    douglasb
    So a little update, I dropped the motor off with Pat Gary and man he knows his model A/B motors, tons of knowledge and cool stuff everywhere. he even makes his own upgraded parts for these motors. so my little jenkins is in good hands. Also found out from him that mine is a later Los Angeles cast version. Thanks Doug
    oj, Outback and Dan from Oakland like this.
  30. Outback
    Outback
    from NE Vic
    Given their Aussie heritage I'm quite interested in these heads, thanks for keeping us in the loop :D
