Hot Rods Edelbrock dual carb setup fuel inlet - struggle choosing
Discussion in 'The Hokey Ass Message Board' started by Doug520, Mar 12, 2023.
  1. Doug520
    Doug520
    I'm trying to pick a fuel line inlet setup for my dual Edelbrock carb setup. I saw a couple of nice ones but they're blue, red, etc anodized. The only non-colored one I saw was one made by Edelbrock and it's out of stock everywhere. What are you dual Edelbrock carb guys using for a fuel line setup? I'd like something clean and simple. On my Ford FE in my Cobra, I have a manifold mounted log with ******s that the fuel lines go onto and then into each Holley carb inlet. Nothing like that exists for the early Hemi. I'm not much for fabrication either.
    Lastly, are the inlet thread sizes for a center hung Holley carb fuel inlet and a 1403/1404 Edelbrock fuel inlet the same size? I'm thinking of buying a chrome dual inlet fuel line for a Holley double pumper, cutting the longer line, and connecting the two with a length of braided fuel line. Would that thread into the Edelbrocks and seal well?
  2. squirrel
    holley is usually 1", the AFB is 5/8, so no, that won't work. But there are fittings to adapt each to 3/8" inverse flare, which is pretty common.
    you can buy braided line fittings that are nickel plated, they look decent.
    of course if you can't put it all together, then I guess it's moot.
  3. Doug520
    Doug520
    "But there are fittings to adapt each to 3/8" inverse flare, which is pretty common."
    That may be, but apparently not common enough for me to understand what you're talking about!:D
    Can anyone give me an example of what fittings I'd need to adapt Holley dual inlet double pumpper fuel line to Edelbrocks? Apologies, guys - this is my first time using Edelbrocks and it's all foreign science to me.
  4. Doug520
    Doug520
    On second thought, disregard. I know what you mean. The common Holley hard line is a 3/8 flare. I can get a fitting that screws into the Edelbrock inlet that will accept the 3/8 flare. Duh - please forgive the dunce moment.
    That said, anyone have another photo of a tricked out solution for dual Edelbrock fuel lines?
    squirrel likes this.
  5. Bugguts
    Bugguts
    I used the Edelbrock fuel lines and used EASY OFF to remove the anodized color and then polished the fittings for a nice shiny look. Of course, it was available when I installed a few years ago.
    acme30, loudbang and pprather like this.
  6. swade41
    swade41
    from Buffalo,NY
    You can wire wheel the red/blue anodizing off the fittings, that's what I do.
    Screenshot_20230312_222246_Message+.jpg Screenshot_20230312_222257_Message+.jpg
    Paul, Bandit Billy, Just Gary and 2 others like this.
  7. Doug520
    Doug520
    Hmmm - I have heard of that but hadn't thought of it. Thanks!
  8. squirrel
  9. jimmy six
    jimmy six
    Easy Off oven cleaner takes off the colors and clear finger nail polish makes a good clear coat. I make my own hard lines using 5/16” fuel line fittings and br*** Tees. An Eastwood style flare tool and bender finish’s with no flexible line on the engine just like stock.
    acme30 likes this.
  10. swade41
    swade41
    from Buffalo,NY
    Not sure if you can make anything out on this photo but I think I bought an adapter for the carb that took a regular AN fitting, the adapter was different than Holley because I had those and they didn't fit.
    LOST ANGEL likes this.
  11. swade41
    swade41
    from Buffalo,NY
    I tried a generic oven cleaner in a yellow can and it wouldn't remove the color, so if you try that buy the good stuff.
    Bugguts and Hollywood-East like this.
  12. Doug520
    Doug520
    I'm looking at this from Speedway. Once you spray the over cleaner on it, does the color just sort of bubble up and rinse off, or do you need to scrub and s****e it off? I'm concerned about getting the color out of the crev***es and between the lines where the lines come together. I don;t know if I can get any sort of scrub pad or tool between the lines where they come together.
  13. squirrel
    dang that's a hokey looking bit of plumbing....fake hose end clamp covers....ugh
  14. Olcars
    Olcars
    Here is my setup. I think it looks traditional
  15. 57 Fargo
    57 Fargo
    my cobbled together set up looks better then the fake one you are looking at…br*** tees and some 5/16 hardline. As squirrel said though if you can’t put it together yourself then I guess you are stuck with ugly.
  16. jimmy six
    jimmy six
  17. swade41
    swade41
    from Buffalo,NY
    I run this simple setup on one car, some people hate it but I think it looks tradionl-ish, not for a show car but doesn't impede fuel flow which I'm more concerned with.
  18. Mike VV
    Mike VV
    from SoCal
    Not the best shot of the fuel lines...
    Teflon braided, with plated fittings. Stainless steel fittings USED to be available, but are all but no longer available.
    I use the Teflon instead of any rubber because NO fuel, no matter how much alcohol is in it, will damage it. It costs a little more, but will outlive the car !!
    Mike
  19. There are several raw aluminum fuel blocks for sale in our cl*** ads now. If i wanted something that was traditional that is what i would do. Get a two hole fuel block, mount them on the intake between the carbs.
  20. 427 sleeper
    427 sleeper
    saltflats likes this.
  21. Besty34
    Besty34
  22. Doug520
    Doug520
    All good looking solutions. I like 57 Fargo's setup. I have a bender and flare tool. I'm not particularly adept with it, but I think I can certainly try something like that. I suppose that's 5/16 steel line, not stainless or aluminum?
  23. 57 Fargo
    57 Fargo
    Plain steel line, buy pre flared line, that way it’s half as many you need to make. I did polish the line.
  24. Jmountainjr
    Jmountainjr
    I will just add that a soak in white vinegar will remove the anodized finish from fittings and is less toxic and messy than oven cleaner. It also works on zinc plated items like bolts, etc. as well as rust.
    jimmy six, Tman and pprather like this.
  25. It needs to be good ol fashioned EZ Off, the caustic stuff and NOT the good smelling lemon scented! A person has to be super careful, it is awful easy to let it set to long and stain/corrode the base aluminum. You will end up with dark splotchy areas or worse
    INVISIBLEKID and Bandit Billy like this.
  26. 1971BB427
    1971BB427
    from Oregon
    I just buy 3/8" hard line and bend and flare my own lines. Then have a short piece of flex line from engine to frame to isolate vibrations. It's cheaper, and cleaner than a bunch of hoses for my use.
    jimmy six likes this.
  27. Bandit Billy
    Bandit Billy
    True this! I sprayed the EZ Off into a container and soaked a red/blue anodized 6 AN swivel fitting over night (because I forgot about it). Took the anodizing off but it didn't swivel any more.
    Bob Lowry and Tman like this.
  28. swade41
    swade41
    from Buffalo,NY
    I was worried about that too, if the acid in the easy off would deteriorate the seal at the swivel, I put mine in for a couple minutes at a time and was using a br*** brush, after 30 minutes of nothing really happening I wire wheeled on the grinder.
    Tman and Bandit Billy like this.
  29. Bandit Billy
    Bandit Billy
    Yeah, on the next one I used 000 steel wool and some reducer I had laying around. More work but I didn't ruin the fitting.
  30. swade41
    swade41
    from Buffalo,NY
    I happened to be in the carb parts drawer, this is the difference between a Holley and a Carter/Edelbrock fitting, both -6 on the AN side, you can see how much bigger the Holley is.
    Also found this hard-line setup, something like that would be an old school look.
