Projects Bonneville XF/GMR Build
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Sep 14, 2021.
  1. alanp561 likes this.
  2. Calkins
    Calkins
    I think their pit is Impound! :rolleyes:
  3. Pretty much
  4. jimmy six
    jimmy six
    Not since 1975 for me. I ever found a problem with either my old coupe or roadster. I tow back under 20 mph.
    For long ch***is or very low cars a device to raise the front or have a flat surface is a must.
    I also don’t have the room to store an item like this but admire them.
  5. Stan Back
    Stan Back
    A tow bar and a set of motor home "whiskers" does the job just fine. You only have to make one run a day and go to Impound where the trailer is in the way. Park in the front row and push the car out to the road up front, couple up and be one of the first to run. It's easy.
    alanp561, jimmy six and 51504bat like this.
  6. cornfieldcustoms
    cornfieldcustoms
    I will stick to building my trailer
  7. Calkins
    Calkins
    We had a front wheel mount for the bike in '13 and '16. After going thru the baja staging lanes in '16, we'll never do that again. I still don't know how I didn't lose the bike. We will be using a trailer from now on.
    Tman likes this.
  8. Looking forward to seeing the end result. I also wondered about Super singles like somebody posted.
  9. cornfieldcustoms
    cornfieldcustoms
    They are just HD 14 ply trailer tires 15x6” rim
  10. I saw that, with all the failures guys have one the way too and on the Salt I wonder if we should be sizing up?
    saltflats likes this.
  11. saltflats
    saltflats
    from Missouri
    I see what you are saying Tman, I have been on those trailer tire failure trips and the dreaded wheel bearing failures also.
    Tman likes this.
  12. cornfieldcustoms
    cornfieldcustoms
    Tires just **** any more. I lost 3 on the way to speedweek last year, replaced all 8 tires on the road. Then on the way to GNRS i lost 2 of those tires. So i am trying these HD ones
    Stogy, SS327 and Tman like this.
  13. Cool, I will be watching and asking you how they fare
    Stogy likes this.
  14. cornfieldcustoms
    cornfieldcustoms
    Had the car outside soaking up some sun. It will be on display Piton Power show in Cleveland this weekend.
    24E7CC67-8B94-4407-ACA5-15F5A2A94FE1.jpeg 7CD92BB1-71BC-4590-95FC-CD290259679C.jpeg
    rod1, Stogy, Just Gary and 13 others like this.
  15. cornfieldcustoms
    cornfieldcustoms
    All ready to load up and head west for speed week
    C7D4D921-AD5B-484A-9CF5-981AC0EC3C6D.jpeg 3FD2001C-9351-4B22-8107-54090E74B6E8.jpeg 3786ED0E-90BD-42E9-94F8-0B189A21AED0.jpeg
  16. y'sguy
    y'sguy
    from Tulsa, OK
    Have a great time at Speedweek! Looking forward to the outcome. Good Luck.
    Stogy likes this.
  17. SEAAIRE354
    SEAAIRE354
    It’s been great watching you build this and it looks amazing. I’m also looking forward to seeing how you do. Good luck. And thank you for taking us along for the ride.
    Stogy, RatPwrd, SS327 and 1 other person like this.
  18. jimmy six
    jimmy six
    I read you are planning to compete at El Mirage this year after Bonneville. I’m sure you will have fun since you have attended a meet and welcome to SDRC. (Member over 40 years).
    I have an observation for you to consider as El Mirage is definitely a different venue for driving other than on Muroc which has a finer surface. Have the ability to remove your windscreen. Many Bonneville proven cars have needed to do this.
    Enjoy Speed Week and hope to see you and other HAMB members there. JD….
    Stogy and Tman like this.
  19. Hemi Joel
    Hemi Joel
    from Minnesota
    Why is that?
    Stogy likes this.
  20. Calkins
    Calkins
    Dust build up in the ****pit due to negative pressure. Taking the windscreen off will help **** it out.
  21. cornfieldcustoms
    cornfieldcustoms
    yes the windscreen is easily un bolted
    Stogy and jimmy six like this.
  22. jimmy six
    jimmy six
    Actually it will let less in as the windscreen adds air over the driver and roll cage causing suction in the body area. The rear of the surround helps with the vacuum coming forward by the rear shape of a roadster. It’s all a “**** shoot” learned by many runs there and learning from each one. Positive pressure added at the top of the body behind the firewall is useful tool if needed. By looking at roadsters that run on the fine dirt in videos you can see both dirty and clean ones. Being a modified does help and this one may not have the dusting..Just something to think about when coming to El Mirage for the first time to run.
    Stogy, alanp561 and Calkins like this.
  23. Stan Back
    Stan Back
    El Mirage is shorter (but harder).
    alanp561 and 51504bat like this.
  24. cornfieldcustoms
    cornfieldcustoms
    rod1, Stogy, loudbang and 2 others like this.
  25. A Boner
    A Boner
    How hard was the salt clean up? They say it gets everywhere.
  26. WiredSpider
    WiredSpider
    Since it is a race car, what happened at speedweek?
  27. cornfieldcustoms
    cornfieldcustoms
    its not bad, the salt was mostly on the outside on the body. I am sure I going over kill. Car is all torn down for cleaning and servicing getting ready for El Mirage in Nov.
    car did well for its first time. I got my rookie run/ E license in at 114, one of my friends got his rookie run/E license , my another friend licensed up to a D license. Worked out a few small bugs on the salt. The course was rough for the first 3/4-1 mile so we took it easy since it was the cars maiden voyage. Car had tons of power left, ran a 2.58 gear and pulled hard through 4th gear for the full course. Some fine tuning and changing a few things, with good salt we will see what she can do
    Stogy, A Boner, NoSurf and 4 others like this.
  28. jimmy six
    jimmy six
    We used our enclosed trailer to retrieve the car so the car was not bad..first time for this because of return road conditions.
    Stogy, Elmo Rodge and saltflats like this.
  29. cornfieldcustoms
    cornfieldcustoms
    Same here. We didnt even set up a pit. We used a small enclosed to transport behind the f100 and got right back in line, serviced the car in the trailer while we waited
    Stogy, SilverJimmy, jimmy six and 5 others like this.
  30. cornfieldcustoms
    cornfieldcustoms
    Here are a few pics of the car on the salt at speed week 2100961A-477C-4202-BF93-2D971B384E37.jpeg ECE5E7DA-204E-44FE-924E-74AAD3EC3F3B.jpeg A05A06AE-5F43-4EDD-BC2C-DBE2BA18A041.jpeg B6DDFD02-2D7E-48E6-A4B5-3CD9BF65E4F9.jpeg 984F03A7-BCB6-4C9C-A892-81772BCA8C59.jpeg 3F065BB1-C191-4ACD-9C22-B048DACC1D39.jpeg 48F2D058-5E87-4EB8-A0ED-FD6119ABA559.jpeg 73470793-E81D-484D-B7DB-CCC72A846F59.jpeg 9377923A-FB76-4032-B054-91AB3A09EC21.jpeg BCED3457-C204-42FB-85C6-ACBA6DB724E2.jpeg 47411EFC-78DC-4005-90A4-49D6C2EFC63B.jpeg
