Hot Rods Firewall Gauges
Discussion in 'The Hokey Ass Message Board' started by Ryan, Mar 13, 2023.
  1. Blue Moon Garage
    Blue Moon Garage
    EVL401, AHotRod, catdad49 and 4 others like this.
  2. oldandkrusty
    oldandkrusty
    This car still exists. It is the garage of Carl's son.
    mad mikey, Atwater Mike and catdad49 like this.
  3. Ned Ludd
    Ned Ludd
    That was my first thought also — or some arrangement by which one set of gauges is visible from both sides of the firewall? A through-the-hood setup as on a number of '60s cars, with some kind of swivel mechanism? Something involving mirrors? Hmmmm ...
    The Shift Wizard likes this.
  4. BamaMav
    BamaMav
    from Berry, AL
    How about fender mounted? I bent up the stainless box for them. underhood gauges.jpg
  5. Paul
    Paul
    Editor
    oil pressure and water temperature in my old '27
    WC145, EVL401, mad mikey and 7 others like this.
  6. bigdog
    bigdog
    I've got no problem with them but I don't see where oil pressure and temp do you much good for tuning. Tach/dwell meter and a vacuum gauge would be handy.
    Adriatic Machine and AHotRod like this.
  7. Paul
    Paul
    Editor
    in my case (in picture above) I was using those two gauges as place holders until I installed a tach and vacuum gauge.
    I found a 2-1/16" tach but not a sender/converter to work with the magneto and sold the car about the time I found a matching vacuum gauge.
    now there isn't enough room for any gauges in the firewall on the '23
    EVL401, AHotRod, Sancho and 3 others like this.
  8. DaveyJonez
    DaveyJonez
    from Houston
    osage orange, WC145, EVL401 and 3 others like this.
  9. Atwater Mike
    Atwater Mike
    I always liked 'em, (first saw them used in '52 when I was 10. One of the local older rodders had 3 in the firewall of his '32 roadster: Big flathead, dual carbs, finned heads. I figured something THAT hot needed 'em!)
    mad mikey, Sancho and Paul like this.
  10. dana barlow
    dana barlow
    from Miami Fla.
    I enjoy seeing the extras on a firewall,but I never had any on my own. Just not enough $$ for doing it. Latter on,after I started showing my cars in indoor car shows going into in the 1960s,there was a show point sheet given out> Some added stuff just too get the extra points ;), I didn't do that,seemed out of place an p***ed my $$$ anyway. Yes,I liked the trophys,but really liked the show atmosphere an those I met :D,both other show car owners and fans:p that came.
    Driver50x and Paul like this.
  11. Rand Man
    Rand Man
    Yep, I like firewall gauges, but guess that’s something for the rich folk.
  12. longhorizon
    longhorizon
  13. Rickybop
    Rickybop
    Never thought about them enough to decide if I like them. Looking at the lit ones you showed, I think maybe I do. That looks pretty cool.
    And handy.
    Some redundant underhood gauges may not help with tuning... but they could help you to know if your main gauges might ever be lying to you.
  14. John Starr
    John Starr
    A nagging vapor lock issue inspired me to take my one bay-mounted gauge (fuel pressure at the carbs) and relocate it to be driver line-of-sight. All of a sudden that gauge was… useful!
    It was quite educational to see what my fuel pressure was doing as I drove in different conditions. And now that I have an electric fuel pump, I can keep tabs on it while driving.
    mad mikey likes this.
  15. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    @Rand Man,
    If I had your money, I would throw mine away! :D:D:D
    orbitup likes this.
  16. Rocket88NZ
    Rocket88NZ
    Yes like the look of them, I can see them being very useful on initial start up. Oil and temp. P1040448.jpg
    hfh, WC145, jaw22w and 3 others like this.
  17. A friend of mine likes the speedometer idea, but he hasn't done it ... yet. I like the idea of an underhood fuel pressure gauge (working on it) and a firewall mounted dwell meter. Everything I own runs points so that would be a nice add on.
  18. Damn straight. You need it for show points. :D
    I do not have any pics and I look at things differently perhaps than most. I think that firewall gauges for tuning is a good idea. I have often though that a fuel pressure gauge (electric with the sender right at the carb), a vacuum gauge, and I doubt that you could find one but if you were running a Chevy with a window distributor a dwell gauge would be a real benefit. Perhaps a small tach.
    Like I said I look at things differently, kind of form follows function and those would make a good tuning aid.
    All that said I have always thought that firewall gauges were cool
    Sancho likes this.
  19. Bert Kollar
    Bert Kollar
    Clutch101, Sancho, hfh and 4 others like this.
  20. Stock Racer
    Stock Racer
    What tuning can be done with an oil pressure or water temp gauge?
    jaw22w and Adriatic Machine like this.
  21. PBRmeASAP
    PBRmeASAP
    Things that happens this winter, cowl gauges 7616B5D1-A394-4F78-B0B5-059A5EFCFDDC.jpeg
    WC145 likes this.
  22. jaw22w
    jaw22w
    from Indiana
    Well, while you can't really do any actual tuning with the OP and Temp gauges, when starting a new engine for the first time for break-in and such, they can be very handy, so you don't have to keep running around to look at the gauges in the dashboard, to make sure you have oil pressure and are not overheating.
  23. pila38
    pila38
    No pics, but I have it planned for my project. Even have the extra gauges. Was only planning vacuum and tach for tuning purposes.
  24. Dreddybear
    Dreddybear
    Firewall gauges can be practical, and also be taken to beautiful, sweet over-the-top excess. I tried to find that balance between too-much and way too-much :)
    Anyway, it's all about TRUNK GAUGES!
