Projects The Thrifty T build!
Discussion in 'Traditional Hot Rods' started by sodakmini, Jun 18, 2015.
  1. sodakmini
    sodakmini
    So I have done a ton in the last 6 months. I will come back and build a better post. But here is a current picture. Lots to do yet.
    Stock Racer, OFT, simplestone and 2 others like this.
  2. Mr48chev
    That turned out great and is proof that you can turn out a real nice looking hotrod without having to break the bank if you work at it a bit.
    sodakmini likes this.
  3. sodakmini
    sodakmini
    36F544D0-AC1C-408F-BA9F-8AFA82F476C4.jpeg 78A16040-42A4-4BD7-9EDB-82D0BE914E80.jpeg 44C86A93-977B-4E23-928A-69677F7C9C19.jpeg So from my last true update. I ***embled the car and drove it from the trailer into our local winter car show. That was last February (2022). Was a huge goal of mine to drive it into that show.
  4. sodakmini
    sodakmini
    A2DF54E7-FB86-439E-92A0-48971F698536.jpeg E788D172-8BD9-41B8-B47B-F8CEE4DC62E0.jpeg 96D03584-2D35-4483-9237-B191BF4606E0.jpeg 9FD4608D-962F-4F27-B924-CF4F838F99E0.jpeg E982E347-F67D-4088-97C5-F5581F68893F.jpeg 7F61B3D5-602C-434A-B65A-03A4FC0D42E4.jpeg 2147CF11-C7AF-4E10-A7FA-ADF833D4B41A.jpeg EBC62AB2-EBE6-410F-AD20-D9F561256A18.jpeg Once I got it home my next plan was to blow it apart one last time and “finish” it for my clubs fall Reliability run. Once apart I body worked and re-painted the frame. When I sprayed that I also did the firewall, dash,steering column,steering wheel, and some trim. I pulled and re-sealed the engine and gave it a new coat of gold metal flake.
  5. sodakmini
    sodakmini
    7EC7F0E2-E6E9-4D74-8E0C-C692EDE398FE.jpeg B1CD95E0-90BE-4A7F-9680-17CE30C05DBA.jpeg 41C18BFA-596C-4134-A57B-BE86E1C43F96.jpeg 6DD434AE-F892-4053-BDFD-89954A2BFEDF.jpeg C939E173-8FBC-408E-870E-DA1EE3FC6320.jpeg 6F43532D-BC69-4650-B813-FBD73B59699F.jpeg Then came finishing bodywork and spraying the body. Like most of us, I am far from a body man. I told myself I was going to build this in my garage the same way my grandfather would have. And I did. It’s far from perfect or good. But I love it. Sprayed it hot rod flatz mint (gloss) single stage.
  6. sodakmini
    sodakmini
    AF16CEFA-0740-4096-94E2-E578E65E55E2.jpeg 1DF2F07B-EAA7-4055-9618-A67C679D3068.jpeg 47C06BCD-64A3-4B47-8EAF-DFF4EA772920.jpeg 2BA52914-399C-4E5D-8FC0-BF7035325C1F.jpeg I fit a 5/8 thick plywood roof and wrapped in poor man’s tuck n roll.
    OFT, Outback, RICH B and 2 others like this.
  7. Rand Man
    Rand Man
    Good thread. Good work.
    sodakmini and Greenblade like this.
  8. sodakmini
    sodakmini
    8B48E879-4A52-4F9F-8306-7B452C2CA248.jpeg 35BBD6DF-7522-4ECD-984A-89428F22FE7F.jpeg 6BFC0A6E-36AD-472F-8C44-AED0AC94F7A2.jpeg 0EF9CBEA-7BE3-4B78-91CB-8F629C02DEE4.jpeg BB908507-07F9-417C-9D16-95B369B28E70.jpeg C8C80C81-0B16-419C-95DA-28A38892A59F.jpeg Been a lot of tinkering and figuring **** out. It is ***embled and moving. I ended up in-reversing the front spring and putting an un-reversed rear buggy spring in it. Raising the car 1”. Was able to take it on our 170 mile reliability run with really no issue.
    OFT, H380, RICH B and 2 others like this.
  9. sodakmini
    sodakmini
    3BA0E3D8-B25D-40B0-A1AA-7A31E6B53630.jpeg 783FACC3-E8D5-43A8-B875-5509B3E82DE1.jpeg A2BD1EF9-BDDF-413F-B3AC-37D9D2758E2B.jpeg C144BFD5-A53C-4218-BA25-B6EAFF767051.jpeg D66B5177-1364-4CBB-8FC6-3611B4032543.jpeg C95ECA76-0D7A-4BA7-957A-319B6C96E95D.jpeg 1DAB80CF-CD01-41CB-991E-3D3FACBF2C20.jpeg 9C9C733A-F4F7-44CF-BAAE-F034D7E380DB.jpeg D7C0C615-490D-4A61-AC5B-1DA75071BA40.jpeg Some shots from the 2022 Rapid Shifters Reliability Run
  10. sodakmini
    sodakmini
    F236B662-4CD9-4818-AD4D-A73DE4C4528C.jpeg F236B662-4CD9-4818-AD4D-A73DE4C4528C.jpeg ABFD0C6D-19FB-4471-8473-7EB585E6650F.jpeg 752C5101-698D-43DB-818F-AEBE99CA6B4C.jpeg 650375A5-4530-431D-9C2B-BCA00D663DD0.jpeg Threw some back gl*** in it and took it back a year later to the Counts indoor Car Show.
  11. A Boner
    A Boner
    A 170 mile test run…SBC…good choice.
    “T” looks great!
  12. sodakmini
    sodakmini
  13. sodakmini
    sodakmini
    Appreciate it!
  14. Dick Stevens
    Dick Stevens
    Only thing that would make it better is if you would select full size images when you post pictures instead of thumbnails!
  15. sodakmini
    sodakmini
    I will have to figure out the full-size picture thing. I agree that is annoying
  16. sodakmini
    sodakmini
    Made some simple Masonite door cards and wrapped them in my poor man’s tuck and roll again. Need to start on the rear cards, will have to order more material. Broke my wife’s sewing machine, but I was able to throw together a matching shift boot as well. 9E78C892-3DB7-4D80-8646-0BA37D99D800.jpeg 17838BDA-5B1F-4EE6-9459-6C1A40712554.jpeg
  17. rusty rocket
    rusty rocket
    Let’s drive the wheels off that thing this summer! Not literally!
    Greenblade likes this.
  18. sodakmini
    sodakmini
    . Got it!
  19. sodakmini
    sodakmini
    Be careful how you word that…..
  20. sodakmini
    sodakmini
  21. Just went through the whole thread, I had missed some stuff before. Cool
  22. OFT
    OFT
    You did good !!
  23. sodakmini
    sodakmini
  24. Tim
    Tim
    from KCMO
    **** another cool Hot rod build i totally Missed!
  25. Pasthisprime
    Pasthisprime
    I just went through this build beginning to end, fabulous car, you should be proud of what you put together here!!
  26. RodStRace
    RodStRace
    Very nicely turned out T!
