Projects BENNETTS ‘Midnight Special’ speedster
Discussion in 'Traditional Hot Rods' started by jordabennett, Mar 3, 2022.
  1. twenty8
    twenty8
    Now that's what I call a happy face.......:D:D:D
  2. 1452E533-BFCF-4DDD-90AD-D674E29D45EE.jpeg 5C678EBF-54A3-4EA3-9B16-AB748D6E5F06.jpeg There was a couple of them!
    Stogy, Nailhead A-V8, Outback and 2 others like this.
  3. I totally agree. It’s wasn’t planned, I’m getting it cleaned and fitted
    Stogy and Six Ball like this.
  4. Stogy and Six Ball like this.
  5. Well there’s a test and tune coming up next month and I’ve got no second gear and apon further inspection a damaged main shaft too. So out with the box and try to find parts to rebuild this. If I have time id like to try get a list of things altered and fabricated to make this better on the track! Lots to come next week.
    64B083D0-1C73-47D8-9403-41CCFD070E36.jpeg 104D908F-E614-4FC5-A5E5-0C7F3FE0E77F.jpeg
    Stogy, Squablow, Ziggster and 4 others like this.
  6. Dave G in Gansevoort
    from Upstate NY
    2nd gear? We don't need no stinking 2nd gear...
    Carter likes this.
  7. Well I thought I had a 39 box with synchros but upon further inspection it’s just a late 36-39 box and no 3” fork. All good just need to find a cluster and 2nd gear! Would be nice to run a later set
    B066A1B9-F0B1-42CF-9002-B8BD0B097010.jpeg 8C71E91F-79A4-4A59-B481-9AB92220A7DE.jpeg FBCE62CE-85C8-4EC0-B51A-2C1F641C8327.jpeg
  8. Fabber McGee
    Fabber McGee
    I don't see how those skinny tires could hook up hard enough on dirt to break the gears.
  9. This was on a race track no dirt
    Stogy likes this.
  10. You’re not wrong. I need to get it fixed
    Six Ball likes this.
  11. ronzmtrwrx
    ronzmtrwrx
    I’ve been watching your videos on YouTube. Nice work.
    Ziggster, RAK and Six Ball like this.
  12. Thanks mate!
    Stogy, ronzmtrwrx and Six Ball like this.
  13. While I figure out what I’m doing with the gear box I decided to make a louver die mount that attaches within the press brake. Took some tweaking and massaging but the out cone is getting better.
    I’m undecided but thought about painting the hood and sides body colour but leave the louvers polished in the shape maybe a fine pin line the separate the colours.
    2812CCA5-AEC9-478E-8D72-7D0152912802.jpeg 5801492C-BE2F-48B0-9077-6836FCA29845.jpeg 5982E6EF-99D6-458B-B808-CE4E19D12375.jpeg 71FE2A6E-170C-42C3-8757-77FD3DD4BEA1.jpeg 86A1FBDF-896C-489D-86FB-4A23C1E6D5D7.jpeg 582626AB-DA57-4AA6-BA1E-F03E86260109.jpeg CD2D25DF-32B4-46AC-A3A9-4D5C5F185E08.jpeg AB8C3EA2-20EF-495D-BF6F-9BA52661A281.jpeg 10D0A712-BD9B-474B-9FE1-601CB1220D6F.jpeg E5D62AF5-92B6-464E-9D46-BD09115C324A.jpeg
    brEad, flatheadpete, Stogy and 23 others like this.
  14. 92 louvers later and a mission to polish.
    Looks cool 230C79A2-A550-4D69-A88B-B61EE6F5518B.jpeg 1FD43D2B-A162-4B30-8513-C4796F7BFA5F.jpeg A6024DD0-77B6-4906-8F9F-72DE7A3F9061.jpeg AFCCBEBB-91B7-409D-A651-1D8AD3C5529E.jpeg 512D6D78-8BFF-44A3-85C4-97CFA10DADA6.jpeg 1040989C-85FE-49B1-9659-3F3CBBF3D28C.jpeg 4CE70D3E-537B-4339-88C2-2CAACAF2294D.jpeg F6C43C55-A24B-487F-A169-C608D429495E.jpeg
  15. MMM1693
    MMM1693
  16. Six Ball
    Six Ball
    from Nevada
    How do you align the louvers, hold the piece in position? This is a neat tool, great work!
    Stogy likes this.
  17. Works by using the bottom plate and has adjustment
  18. Now, I like that hood without paint!
    Looks awesome!!
  19. Tim
    Tim
    from KCMO
    Watched the video yesterday good stuff. Did you modify the male due when you cut the female a little rounder? I think I missed that part
    I’m Also curious if your hood sides have a little distortion/ pucker between the rows of louvers or if it’s the reflections of the louvers themselves onto the polished hood side?
    great work, really enjoy your videos
  20. Nailhead A-V8
    Nailhead A-V8
    beautiful work!
    Stogy and jordabennett like this.
    I didn’t have to modify the male, just the female part of it just trying to make the radius smoothers.
    It didn’t distort too bad, a very small amount but the cut and press is so smooth it helps a lot with that. The back press also helped with this as well and came out better than i could have imagined
    Stogy, 41 GMC K-18, hfh and 6 others like this.
  22. roddering
    roddering
    from Arizona
    I love that grill on the car!
  23. roddering
    roddering
    from Arizona
    WOW... what an amazing and awesome job! :D
  24. Thank you kindly!
    Stogy, 41 GMC K-18 and roddering like this.
  25. Made a wire buck and formed a little screen from some 1.6mm aluminum. I’m on the fence with painting it body colour or polishing.
    Definitely breaks up the flat cowl section.
    7DAFE22A-D5A3-4A76-8BD0-02B7D883D35D.jpeg B38FB95F-3E74-4DA9-B5BB-8380F59A88EF.jpeg 3C4BA645-63A9-46B1-879F-3AD4D6D7DB1B.jpeg A18C6635-B6E2-4EFA-8B7C-5C51EDDF6A58.jpeg 1CA14A7B-B77F-4AEA-9C1F-57A69B0692BE.jpeg 26D12BEB-6490-41F7-B3FB-438CF899B5A3.jpeg 9F43CD52-E8C8-4D51-879C-48EB9B8D7B47.jpeg E527EBF6-EA26-4F51-B350-A87D12B82321.jpeg B955F422-5508-49B1-8E49-1AC4B0AB9A3B.jpeg
    brEad, sko_ford, ratrodrodder and 9 others like this.
  26. Tim
    Tim
    from KCMO
    Hey that’s cool! I vote leaving it brushed/raw but polished would be my second choice
  27. Flatrod17
    Flatrod17
    I would polish the flange and leave the rest as is.
    Stogy, Six Ball and Tim like this.
  28. 05snopro440
    05snopro440
    That looks great. My vote is polish the outside and leave the inside brushed.
  29. alchemy
    alchemy
    Heat a sheet of plexy over your form.
  30. Six Ball
    Six Ball
    from Nevada
    Paint it so there is not a break in the visual flow. Too many pieces with different colors, shapes, or textures. Have someone photo shop it. You do fantastic work!
