Projects Drdave accidentally buys a Model A. Now what?
Discussion in 'Traditional Hot Rods' started by drdave, Jun 17, 2018.
  1. drdave
    drdave
    Thanks Mike! That's pretty close to where I am now. Phew!
  2. Okie Pete
    Okie Pete
    Very cool Kustom improvement
  3. drdave
    drdave
  4. drdave
    drdave
    Tada! A dropped headlight bar that fits like it should. Now I can confirm where I want to drill the holes in the grille shell for the wiring conduits and pull it apart for paint.
    Headlights are in primer...which of course revealed a couple dings I missed. I'll finish these up and prep the headlight bar then these items I'll paint black. I had some paint matched to the body, so the grille will be painted the color of the hood. Hopefully it's a pretty close match. ;)
    dwollam, 1stGrumpy, 2Blue2 and 11 others like this.
  5. sodakmini
    sodakmini
    Looks like a super fun project. Love it
    drdave likes this.
  6. drdave
    drdave
    Thanks @sodakmini. Looking forward to getting it back on the road after a 3 year hiatus.
    Okie Pete, Sancho and sodakmini like this.
  7. Tim
    Tim
    from KCMO
    Well **** I guess I’m due for a visit then!
    drdave and Outback like this.
  8. wide34
    wide34
    from Texas
    Looking forward to seeing it on the road:)! Really like the changes!
  9. 4 pedals
    4 pedals
    from Nor Cal
    Funny how those little projects turn into 3 years off the road...
    Didn't you say in the beginning you weren't going to do anything with this one while you stayed focused on your other car???
    Devin
  10. 2Blue2
    2Blue2
    Nice job on the headlight bar mods
  11. drdave
    drdave
    ...sounds like me (but you mean cars plural lol)...but also sounds like me that I may have qualified it with worrying about a flathead or juice brakes until after other stuff was done. Haha. In the time I've had it I've had to redo the motor in the Chevy and now the Merc has rounded off a cam lobe and is currently working on being completely blown apart for a new engine, front clip and engine compartment redo/detailing. So, progress does ensue on other cars, but slowly (I'm neck deep in a home remodel).
    Headlight bar is done and painted, headlights are in final primer, grille is in sealer and should be painted tonight. Almost to re***embly stage!! 3 1/2 weeks until the Stray Kat....I think I can make it. LOL
  12. wide34
    wide34
    from Texas
    Wow, you are busy! Looking forward to seeing what you’re doing on the Merc! See you in a couple of weeks!
    guthriesmith likes this.
  13. Sooo... you're taking the "A" to Dewey?
    Sancho and guthriesmith like this.
  14. drdave
    drdave
    Between work, house, grandkids and a little car stuff here and there it's the one legged man in the **** kicking contest story around here. LOL. Don't hold your breath on the Merc...it's going reeeaaaaal slow at the moment. LOL. Once the A is back up I need to get my son-in-law's 69 Chevelle running and out of my shop and into his garage....THEN back to work on the Merc. LOL
    That's the plan. :)
  15. stanlow69
    stanlow69
    Dave, now that you got your headlight bar all figured out. I thought I`d post these that Scan_20230411 (2).png Scan_20230411 (3).png I found last week.
  16. drdave
    drdave
    Thanks for posting that! That's a sure fire way to do it and not lose length at the same time....and be able to get more drop in the process. If I end up wishing I had more drop, I may go back into it and do it this way....but right now the jack out of my press is under the lake house to replace rotten sills. LOL
  17. drdave
    drdave
    Got a bit of painting done last night....one headlight and the grille shell.
    ....aaaaaaand of course, dang bug right on top front and center. EV'RY dadgum time! It's like they teach them in bug school that the most noble death of all deaths is to land in fresh paint, but ONLY right in the middle where it is most noticeable. A death such as this should you be presented with the opportunity will have your name sung loud a**** the children for all bug history. Sigh....
    It allllmost matches, but it's a bit brown....just like I told the guy it was. A close as I'm going to get to matching a color with no paint code I guess (the colors on the car are the "wrong" shades that the paint code had drifted to over the years but has since been corrected and the "wrong" formulas are no where to be found). @guthriesmith loaned me his paint charts and I'm working on some colors with OEM paint formulas for when I repaint the whole car. I like the greener shades on the car now than the browner authentic shades.
    Sadly when I went out this morning, there are sanding scratches, which makes me sick. I guess I'll let it all dry good and color sand it for the bug anyhow, so maybe that will lessen the scratch problem as well. That's what I get for being in a hurry....and not sanding out in the sun. LOL
  18. guthriesmith
    guthriesmith
    Hopefully you put enough on to get the bug and scratches out with color sanding? I guess you will find out. :D Also, sorry you are struggling with the color. I had the same issue with Silas's Edsel. I got close, but it is a little off even the with closest color I could find a code for. I'm sure it could have been tinted to get there, but I was in too big of a hurry the week before SK500 last year...
  19. drdave
    drdave
    Yeah, I hope I have enough paint on it. I've been going back and forth this morning about putting another coat on over everything, but not sure I want to press my luck. Be just like me to then get a bunch of wrinkles or some such thing and make a bigger mess than I have now. ;)
  20. Tim
    Tim
    from KCMO
    Yeah let er’ buck. Save the paint for when you sand threw and need a savior.
    could make the prewar pileup in Tulsa
    drdave likes this.
  21. drdave
    drdave
    Good idea, thanks Timm.
    the Pileup is the same weekend as the Custom Car Revival in Indy.....I expect to be there that weekend. ;)
  22. guthriesmith
    guthriesmith
    I guess I could take the A to the Pileup if needed Dave. What are friends for anyway? :D
    brEad, Outback, Okie Pete and 4 others like this.
  23. drdave
    drdave
  24. drdave
    drdave
    All the little steps finally added up to big step last night. Got the grille shell, headlight bar and headlights all in place. Pretty stoked with the change it's all made.
    There would be those a**** my close friends that would say I let a creeping attempt at perfection get in the way of getting things done and back on the road, and they are 1,000% correct. But, rest ***ured, my spray can painting and less than perfect hurried prep in this case matches the dinged, scratched, chipped, peeling age of the car quite well. LOL. I even put the splash apron back on without stripping and repainting it....just s****ed the flakes off the back and threw it back in there. Haha
    Started drilling new holes in the bumper irons for the 32 bumper. Ever try to drill a hole in a Henry bumper iron? Good gravy, I'm wondering how many drill bits and how much oil this is going to take. LOL Also working on converting the horn to a '32 back cover and mount so I can mount it down at the bottom of the fender on the frame rail like a '32 since now it won't fit it's original spot under the headlight with the dropped bar. Finish the 12 volt conversion and I'm back on the road. Stray Kat here we come!
    Outback, brEad, dwollam and 15 others like this.
  25. wide34
    wide34
    from Texas
    Looks great! See it in a couple of weeks!
    drdave, Sancho and 54delray like this.
  26. 51 mercules
    51 mercules
    Looks good!
    drdave and 54delray like this.
  27. 5280A2
    5280A2
    You may find it simpler to modify the Model A horn bracket to fit the dropped bar. I was able to modify a horn bracket to provide about 3/4-inch offset so the horn would fit back into the smaller area below the dropped headlight bar.
  28. jakesbackyard
    jakesbackyard
    from ND
    Really looking nice. Might I suggest some 16” 1935 wheels?
    drdave, 54delray and Sancho like this.
  29. Lookin' good Dave!
    When are you planning on heading up to Dewey? Mike and I are going up Friday morning.
  30. Dan Hay
    Dan Hay
    Looks good! Dave, I feel like you need more projects...
