Projects Big daddy's 1960 El Camino
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Nov 18, 2020.
  1. Lloyd's paint & glass
    Oh I work on cars every damn day that I'm not at the firehouse, just not my own! Lol....
  2. Lloyd's paint & glass
    Fly your big *** into Louisville and hit I65 south!! :D
  3. Lloyd's paint & glass
    Changing a few things on the ol heap. And one of the tasks at hand is my gas tank. I have a 10 gallon fuel cell, works fine, but 10 gallons of gas is limiting on the interstate. I was thinking about buying a mid 60's mustang tank, 16 gallon, easy to mount, but of course i will have to change my gas gauge. I am seeing 19 gallon aluminum fuel cells on Amazon that are about $50 less than the tank. What would you guys do? 20230320_160804.jpg
  4. fastcar1953
    fastcar1953
    Less money is not always the way to go. $50 isn't much. I would choose which fits best .
    I have run a lot of stock reproduction tanks and only one aluminum one.
    Which one fits best? I'm guessing the aluminum one. Will it be in the way? The gauge will be better though . gm to gm.
  5. fastcar1953
    fastcar1953
    Oh hell I forgot it's a race car. moon spun tank would be my choice. :D
  6. Lloyd's paint & glass
    Yeah the $50 doesn't really steer me, not having to change the gauge is a plus though. I'm just at a crossroad and don't really have a reason to choose a path lol
    chryslerfan55 and scotty t like this.
  7. The37Kid
    The37Kid
    First thing that comes to my mind on the gas tank choice is a two piece stamping in steel vs. a lot more in aluminum and a lot of TIG welding.
  8. chevy57dude
    chevy57dude
    Lloyd, how are you going to mount it? Cut it into the bed like the mustang trunk floor? Or in the bed? My aluminum 20 gallon fuel cell had an incorrect sender, I ordered one that was a universal 0 - 09 Ohm unit compatible with my stock gauge.
    *edit - just looked up a stock replacement. Eek! $600
  9. saltflats
    saltflats
    from Missouri
    What kind of fuel are they selling around your parts?
    mad mikey likes this.
  10. Lloyd's paint & glass
    The fuel cell that's in the car is mounted to a subframe that i built at the rear of the frame, but if I use the mustang tank I'll build a new setup that basically mounts it just like a factory mustang setup. My current sender is 0-90ohms and the bigger cells come with a 0-90. I don't know what the mustang uses.
  11. Lloyd's paint & glass
    As far as ethanol?
  12. saltflats
    saltflats
    from Missouri
    Yes, if that aluminum is not anodized the ethanol will cause corrosion.
  13. Lloyd's paint & glass
    I never pay attention, I just put 93 in it, but I'll look. That foam in the cell doesn't seem to be affected yet but I'm not sure
    mad mikey and chryslerfan55 like this.
  14. Lloyd's paint & glass
    I went to Kentucky mustang and got the kit. 3/8" fuel line on the sender. I needed to change the gas gauge anyway, doesn't match the others lol
    mad mikey and saltflats like this.
  15. fastcar1953
    fastcar1953
    You put a ford part on a Chevy? That's so wrong. :eek::D
  16. Lloyd's paint & glass
    Yeah I'm doing it to make up for all the small block Chevys I've put in model A Ford's lol
  17. chevy57dude
    chevy57dude
    I may have a 2" gauge for ya
  18. saltflats
    saltflats
    from Missouri
    What's wrong with that?
    ffr1222k, Tickety Boo, enloe and 4 others like this.
  19. Lloyd's paint & glass
    I don't even know what the ohm requirements are for this sending unit lol. Never had a Ford sending unit lol
    mad mikey and chevy57dude like this.
  20. Lloyd's paint & glass
    chryslerfan55 and mad mikey like this.
  21. Lloyd's paint & glass
    I've already caught hell over the white gauge :rolleyes: 20220512_132735.jpg
  22. fastcar1953
    fastcar1953
    chevy in a ford is o.k. but no ford parts on a chevy.
  23. fastcar1953
    fastcar1953
    I think fords are 0- 30 ohms
  24. Lloyd's paint & glass
    Guess I can pull out the ol ohm meter and check it. Got called in to work though
    SS327 and mad mikey like this.
  25. Budget36
    Budget36
    Pretty sure I have a black faced fuel gauge from a Peterbilt, if I can find one of the tank sending units I’ll ohm it out and you can compare to your sending unit and see if the gauge is compatible.
  26. Lloyd's paint & glass
    I got these sweet moon gauges from scotty t, need to see if they sell a matching gas gauge, but anything will work
  27. chevy57dude
    chevy57dude
  28. Lloyd's paint & glass
    Yeah that's the monster :D
  29. blue 49
    blue 49
    from Iowa
    You should have gotten a Mustang "style" tank from Tanks Inc. They have an aftermarket type sending unit mount so you can use the appropriate sender to your gauge. I have one in my Henry J.
    Gary
  30. Lloyd's paint & glass
    The main reason I went this direction is Kentucky mustang is just up the road from the firehouse i work in, it's easy to walk into the showroom and walk out with your parts lol. If only I was a mustang guy I'd be able to get parts easy
    enloe, chryslerfan55 and saltflats like this.
