Projects 33 Doll Build Page
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 20, 2020.
  1. 33Doll
    33Doll
    39785703-DD59-4E7F-BC45-35506E431C35.jpeg 618E43E3-CA96-4DDC-A86F-CB2A3AC7F59E.jpeg D607EAFF-811F-4376-B7B5-5C2DA90A2D6B.jpeg AFAFA326-4E05-4E42-A755-F6505961FF8B.jpeg 3ADA635B-C032-4B97-BCAE-016E525923FA.jpeg 246A69F2-8F04-4AE0-8CA0-6379007359D2.jpeg 1A6953AE-6A5E-4C43-855E-9D8D72889519.jpeg EFD6C5C6-C18E-4604-9A9E-4352E7DBEB82.jpeg 4A4C455E-C86D-4B38-9C40-5F815C339E64.jpeg 5F20F3E5-90F5-47F7-B3B1-3AC17955E877.jpeg 5EC1F0CD-A6B0-40EC-89F7-FCBF40EEAADE.jpeg D14D576A-4495-432D-BEC7-2B4E08117ADF.jpeg CC2DA72C-651C-4DEB-839A-9EED1E33AE7F.jpeg AEACB383-6DC1-4BDB-8D41-71EB590939D3.jpeg C78949A6-8007-4EED-A132-FE794B591538.jpeg 4C9893F3-F7A6-4854-A3AD-28BF74FCDB49.jpeg Alot More Done today!
    Fire wall insulation, heater hooked up, and Plumbed, Early Bronco Manual Heat Shut off valve.With my old cowboy hat band trim bezel!
    (new I would dig that out of my junk drawer someday!
    Lets see…
    Dimmer Switch in, PCV Plumbed! Cowl-vent drain line…All this little stuff takes forever! Few More Little things, and
    THEN the wiring!!
    Patience is a virtue…. They say…
    BULLSHAVIK!!! I Say!!! Yaw!
    mad mikey, Dave Mc, CC-Mo and 6 others like this.
  2. 33Doll
    33Doll
    More done than I thought today!
    Went to make the mount for the Fuse box, when I went trial fit the fuse box, it accidentally snapped back into the holder, so I left it, and just started separating the bundles, thought to myself, it looks relatively easy…and then started routing them!
    E802E0FE-8E67-4CC2-A1DC-83744C0BB96F.jpeg 5755B52E-148B-4552-BC43-3E4176D87B11.jpeg 7A24A8EC-CAD1-4AA8-A0C8-1E34B0C83B2F.jpeg 96D5D69E-D7C2-4F50-ABBA-67ED07A0B65A.jpeg 2CB40FCC-AE19-47ED-8C94-622D6F41081A.jpeg A3DBCF87-F525-4369-BD10-011A4CD79763.jpeg E378CB2C-90CD-434F-9C4F-A022AE936AAA.jpeg 197AD3E8-C79F-4C78-B784-0A62982AAFC6.jpeg 72D91692-05DF-404C-8DAC-5401E0782386.jpeg 434B47E8-71E6-4685-B8E8-D82B3A94A3DE.jpeg 19DEFB7E-A4AB-43D4-B2A8-39005CF6A776.jpeg FCF4189F-3673-44E0-A5C0-B66C9FCA739C.jpeg
  3. Ford blue blood
    Ford blue blood
    Just be careful you don't let the smoke out of the wires.......
  4. 33Doll
    33Doll
    “Voodoo” ? Uncharted Waters?
    mad mikey likes this.
  5. 33Doll
    33Doll
    B2877857-E452-41C9-86A8-0BEEA84942EA.jpeg D7A5F0B4-BBD5-4B28-B9FD-8B3B9145FA8B.jpeg F01F2CAE-7299-4399-9D7D-E2873CA056C1.jpeg 0D74FBA9-DC3F-4F39-A120-160A0547B305.jpeg 85560A49-7D11-415E-AADB-6A02BAD64795.jpeg E0623480-9E7A-4F16-A9AE-357FA831C1E1.jpeg A06E8581-1DBE-4A37-821A-7A0CEF6367A6.jpeg 674E664E-AAF4-4D68-9DBB-9D4A867999BA.jpeg Not so much “voodoo” but more like Spaghetti, and Sticky snakes! But slowly routing to all the right places.
    I also cut the the ugly Ni-Copp line on the firewall, down to the frame rail, squished a coupling farrell on there, and then cut the fitting off in order to have a flare, but didn’t really need it
    The Braided hose is tight and looks alot better on the firewall, cant see it really.
    You guys are probably sick of pictures every day! I’ll back off a little bit,
    I am sure Wiring is boring to alot of people!
  6. Johnboy34
    Johnboy34
    from Seattle,Wa
    It'll be running real soon now!
    33Doll likes this.
  7. RICH B
    RICH B
    Replacing that section of line with hose looks much nicer.
    33Doll likes this.
  8. Outback
    Outback
    from NE Vic, Oz
    You can buy genuine Lucas smoke (in a can) to put back in the wires, I don't know but I am sure it would be compatible with US wiring??
    Just Gary likes this.
  9. Ford blue blood
    Ford blue blood
    Ah yes, Lucas, the Prince of Darkness. No the Lucas smoke will not work in US wires. It is designed to further confuse folks working on those English cars......only way for the Prince to see the light is to replace all of his stuff with modern USA fittings and connectors!
    And no, we are not tired of pictures!
    mad mikey, Outback and 33Doll like this.
  10. 33Doll
    33Doll
  11. 33Doll
    33Doll
    E6C24E62-DBC0-4BFF-848E-2E3648087990.jpeg Heres My New SW Gauges
    Just Gary, mad mikey, Outback and 2 others like this.
  12. 33Doll
    33Doll
    Gauge Cluster ***embled!
    Going to make one harness, and Put a plug on it,feeding it from the left side towards the fuse box, so everything is tucked up and clean and easy to work on, or just unplug and remove the whole Cluster/Bezel!
    E6372F57-BAA9-4BBE-AF98-356B5705B37C.jpeg F46DDB9B-DE6B-40D8-BE46-1CF87DD8718E.jpeg D29F37C4-FB3F-43D0-AE2C-C04CDC852703.jpeg
  13. 33Doll
    33Doll
    Instrument Panel Is Done and Working!
    Should make this Wiring job alot Easier!
    Check My Tuber-Channel!
    mad mikey, Dave Mc, Outback and 3 others like this.
  14. 33Doll
    33Doll
    Boy! This wiring os about a thrill a minute!!!
    Got the Fan relay, and Fuse 450B346D-BF84-4F39-8703-3DA255907DB5.jpeg F7EBAA98-6429-4092-9FFD-4D593947099F.jpeg C2B91FC5-4C7D-4D34-9618-208C9C85C33A.jpeg Mounted inside
    (No where really in the engine bay on these 30’s cars!)
    Put a battery Hot Junction block down to the battery with a 30 amp Inline Fuse. That way if I want some things direct, I can Just hook up there.
    Just Gary, mad mikey, Dave Mc and 5 others like this.
  15. 33Doll
    33Doll
    Please don’t judge the “Spaghetti”
    Just Yet! It “Will” look betterer soon!
    Me Promise’ss!
  16. 33Doll
    33Doll
    99F36055-D169-462F-8032-65F4058DEAA3.jpeg 8F30C678-570A-4934-A96E-53F77441643A.jpeg 5013FF66-21EE-4B3E-9516-142CDCC3F008.jpeg 014EF548-AB8C-48CE-91A3-A6B68DDF91B0.jpeg Not much to report lately!
    Wife is restricting Garage Time for me
    Due to Honey-Do’s and House and Yard Neglect. Whatta ya gonna do??
    You need them Gals too.
    Heres a few pics… almost done with the inside wiring (Heater motor, and dome light left) I will make it prettier later after I know everything works…soon I can start hooking up the other ends to the components. And Might get somewhere!!!
    mad mikey, Tman, Outback and 3 others like this.
  17. roseville carl
    roseville carl
    how in hell did I miss this thread, Love it!!!!! and the history with your dad is just too kool.....
    mad mikey, Tman and 33Doll like this.
  18. 33Doll
    33Doll
    I thought so too… until I read The Canadian Model A widow story!
    WOW!
    Im in Lincoln BTW!
    Welcome!!
  19. loudbang
    I think I would pad the brown and purple wires where they meet that bracket and go downwards at a 90 degree angle. Just driving will produce vibration that could result in insulation being chaffed away resulting in a short.
    mad mikey and 33Doll like this.
  20. 33Doll
    33Doll
    Thanks
    I am gonna wrap the wires, and pad all the areas where they touch. just wanna make sure everything works first and in case I have to reroute a few things, which I’ve already been doing a bunch of times! so it’s taking forever.
    I was trying to secure the wiring somehow underneath the cowl without drilling into the body so I use the little tiny holes where the Cowl lace padding screws to. To hide any attachment points from the outside seems to work just need to fine-tune it.
    mad mikey and loudbang like this.
  21. 33Doll
    33Doll
    747C06D9-C4F6-42FA-BB7F-976551DDDADC.jpeg 0824053E-61D3-4E7D-AEA7-0406E453C88A.jpeg 59FAE8E6-AF7F-431F-8C0C-408F23E12BEF.jpeg 5686D9DB-1EBA-49C3-8D9D-5F85D370922A.jpeg 5AE1228F-93FC-4A7C-B097-8B242A5DE961.jpeg 328526F0-8ADE-414B-BB3B-6E31D6DC512E.jpeg EEBB99E6-8785-434D-BEFB-19F6BA730C4B.jpeg DB5865AA-68FE-4135-90B3-16342C97AF22.jpeg 4B161140-8E64-493B-9C80-6DF6FB4D37B6.jpeg Got bored, waiting for the oil to drain on the the big gear boxes at work. Did a little polishing while I’m waiting for the bucket fill up.
    A little before and after and working that repair my dad did. This is good as it’s gonna get! not gonna spend $2500 to get the damn thing chromed!!
    Before And after!
    Looks a 100 times better.
    Love that Meguiars Ww cleaner and flitz polish!
    The polished steel is shinier then the chrome itself!
    Worked that repair as best I could!
    Realllllyyy thin metal !
    I think it turned out awesome though hard to tell that it’s the same grill
    brEad, rod1, mad mikey and 4 others like this.
  22. flamedabone
    flamedabone
    That grille came out fantastic!! Keep it up, you are on the downhill slide.
    -Abone.
  23. 33Doll
    33Doll
    Thanks! Even Got a”Fantastic” from Pops!
    I’m gonna repaint the edge, flat, black like it was before. I think it looks better even though the hood hides it, but there’s those times where I probably run without the hood, to show off the Flatty!!
    rod1, mad mikey and Jim Bouchard like this.
  24. 33Doll
    33Doll
    22955AE3-E85F-4C89-AF0E-04F2C26E885D.jpeg 14FEB842-D793-49BC-B51F-5538E21B127C.jpeg Welp! Not Perfect! But nice!
    It blends in with the rest of the Scars properly! This ****er has always been a-Drive it Hard-Driver.! It might get a little more pampered with me…. Well…Alot more then when my Pops had it, anyway!
    (For those of you who don’t know it was his daily driver for 15 to 20 years commuting to Sacramento from Roseville/Granite Bay. rain-sleet-snow…well…rain!)
    brEad, rod1, mad mikey and 2 others like this.
  25. 33Doll
    33Doll
    0EE8C9C1-22D8-4886-A8CD-137E8D1A00E6.jpeg 36BD2EC0-0C7A-46DE-B080-F0A5BC0FE028.jpeg 1AA3204D-BBDF-4BA5-A8C5-4CB90329D2D3.jpeg 2B9ED5E8-9B6B-48E7-BE8F-F7CDE1E0B567.jpeg 20B130A3-A0A1-406C-A0A0-43F747195373.jpeg
    neilswheels, brEad, rod1 and 6 others like this.
  26. 33 cdan man
    33 cdan man
    Ask your pops if he remembers this cruising around Vallejo.
    33Doll and Jim Bouchard like this.
  27. 33Doll
    33Doll
    55AA1DDC-86B9-4283-8D6E-444AB70BC1DE.jpeg D3F73BFA-6D43-4752-B1B4-754AF3030C0F.jpeg C2E77622-4CE9-49EC-876A-E40876424BFF.jpeg 3296BA30-3C91-46C7-94A8-B65FED336140.jpeg 91E345C5-C48D-4EAD-B7A7-7B9EF110F157.jpeg 56E7E35B-E2A2-4FF0-A8F2-8C7EF70B5C9A.jpeg 8D0DCAEF-15E1-4DB3-A6BD-216ADB821210.jpeg E17E90DD-D69F-49C6-92E2-BCE0DCD443E8.jpeg DBA83A8C-3034-4115-B973-58595725A05D.jpeg 14139E9C-6DAD-4609-843A-C81AD156FC64.jpeg 4D4C1658-22D8-479C-A475-5A1B790657AD.jpeg Waiting for more oil to drain out of gear boxes at work!!!
    Well… That’s about as good as those lights are gonna get!
    At least I can put the bad part of the rust towards the grill. I got some of those Scott Drake Ford script headlights to look a little bit more old school.
    And shrink tube and made the harness is really nice!
    brEad, mad mikey, dumprat and 2 others like this.
  28. 33Doll
    33Doll
    I Will, Did Y’all ever meet?
    Whats your name?
  29. dumprat
    dumprat
    from b.c.
    Love the headlights!
    33Doll likes this.
  30. 33Doll
    33Doll
    Thanks!
    Do you think I should just leave them alone even though the chrome isn’t that great, at least they’re shiny?
    My wife says quit worrying about all the small things. Once the car is all together in one piece, know one will notice all that stuff! They are looking at how cool it is!
    brEad, Johnboy34, dumprat and 2 others like this.
