Folks Of Interest Who restores license plates????
Discussion in 'The Hokey Ass Message Board' started by atch, Mar 15, 2023.
  1. jimmy six
    jimmy six
    I cleaned my 56 plate and final wipe with brake clean. Went looking for the yellow/gold at an ACE hardware. I think it was School Bus Yellow. Left them everyday in the sun for a week. Found a pin stripper at a show that did license plates. There must be one in your area. Turned out great.
    54delray likes this.
  2. George
    George
    he did 1 of mine.
  3. Joe H
    Joe H
    Mine were not rusty so I cleaned then in a bead blaster, then powder coated the black back ground. I went to the local craft store and bought white paint pens made for gl***. After painting the numbers, I baked them to cure the gl*** paint. With powder coat as a base, the number paint cleaned off without taking the base when a mistake or two was made.
  4. Zax
    Zax
    Be careful with how long you soak it in CLR. I killed a very cool tag topper by soaking it too long. I say 30 minutes max.
  5. atch
    atch
    I just now have the time to head out to the shop. Before soaking the plate in CLR I'm going to try spritzing it; wait 5 minutes or so, and wiping/rinsing off. I'll let you know how that turns out.
    If that gets the rust off maybe I'll just attach it to an aluminum plate with all 4 bolts and not try to do anything with the cracks.
  6. lonejacklarry
    lonejacklarry
    This fellow has done two or three for me over the years. I don't know about the others suggested but Lee is great.
    Lee Lawson
    1838 College Ave.
    Conway, AR. 72034
    phone: cell 501-628-4535 home 507-327-0810
    leelawson1374@att.net
  7. atch
    atch
    Erring on the side of caution I only soaked the plate in CLR for 5-10 minutes. That didn't do much. Next time I'll let it stay on longer.
    b-t-w; I didn't immerse it, just poured some on and used a scrub brush to distribute it around. Next time I'll probably immerse it.
  8. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Here you go fellas !
    Ron has been restoring plates for the last 26 years.
    His display the very top plate if you notice the left half of the plate is it’s original condition and the right half of the plate is the restored condition.
    His landline is on the card.
    Cell number 515- 835-9066
    74A0DBC0-884F-4022-8C89-668172F078BB.jpeg 43A23B93-DB5D-4F52-81B7-153E39BA8B3D.jpeg
    54delray and lothiandon1940 like this.
  9. atch
    atch
    Today it's warm enough to spend time in my uninsulated shop; without lighting the wood stove.
    I constructed a shallow plastic lined tray just the size for a license plate and began soaking the plate in CLR. As you can see I put it in at 3:40 (CDT). Any guesses how long it'll take? I'll be keeping an eye on it regardless.
    The green is the yellow CLR covering the blue plastic.
    Bill's Auto Works and 54delray like this.
  10. MCjim
    MCjim
    from soCal
    It helps to scrub with a plastic brush or very fine scotch brite pads(white)
  11. atch
    atch
    Here it is from the beginning of this thread:
    Here it is after a 6-hour bath in CLR and a scrub with a stiff plastic bristled brush:
    Tomorrow I plan to put it in earlier and leave it longer.
  12. 03GMCSonoma
    03GMCSonoma
    I used to live in Webster City 60 years ago. Ron and his brother had a gas station. Great guys.
  13. 03GMCSonoma
    03GMCSonoma
    I coat mine with some clear coat paint. It really makes the plate "pop".
  14. atch
    atch
    At the beginning:
    After the first 6 hour CLR bath:
    After another (8 hour) CLR bath:
    I think I'll give it another bath or two and call it quits.
    I still might send it out for restoration but the more I've seen of this the more I think I'll keep the 50 year old look.
    Would shooting it with clear ruin the aged look?
    anthony myrick and 54delray like this.
  15. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Yes it would IMHO. Spraying clear over natural aging ruins natural.
    Again IMHO.
    5window likes this.
  16. atch
    atch
    Thanx man. That's what I suspected but having never done it I didn't know.
  17. You're getting good results, but I think the patina would be out of place with your shiny new paint. JMHO
  18. I redid a 28 Maryland plate. It wasn't quite as bad as that one, but after I got it painted, I used a wide tipped paint marker to do the letters... easy-peasy. Gene.
    lothiandon1940 likes this.
  19. atch
    atch
    9 1/2 hours more in CLR didn't make much of a change. I may be done.
    However, I have citric acid and Evapo-rust on order so I may or may not do more when it arrives.
    I don't think I'll have this one restored at this time. I'll run it on Clarence and see what it looks like, then decide whether I want restoration or not.
    '28phonebooth might just have a point with contrasting shiny paint and ragged license plate. We'll just have to see.
  20. atch
    atch
    There is a moral to this story: when you're wanting to s****e up some salt at Bonneville you probably should use something other than your license plate.
    54delray and '28phonebooth like this.
  21. Jalopy Joker
    Jalopy Joker
  22. atch
    atch
    Here is one of my plates from the beginning of this thread...
    Here it is after extensive CLR and vinegar baths:
    That's the plate that's on Clarence right now.
    Here's the other plate as it was the day I sent it to @oldpl8s:
    Here it is when it arrived in my mailbox today: 20241220_211638.jpg
    So now I have a perfect restored plate and a patina plate. I can change them out as the occasion dictates.
  23. gimpyshotrods
    gimpyshotrods
  24. HOTRODPRIMER
    HOTRODPRIMER
    I did mine, not real professional looking but it works for me, I just sanded it, beat in into submission and used One Shot sign paint. HRP
  25. PotvinV8
    PotvinV8
    Be aware, it's illegal in many states to "alter" a license plate. That said, you'd have to run into a pretty ****py cop to give someone some flack on those beautiful examples posted thus far!
    I've got YOM plates on all my old cars and most of them aren't actually registered to said vehicles because I'm cheap and the difference between a single plate and a matching pair (which is what CA requires you to have in order to ***ign to a vehicle) is crazy expensive. And I've never been har***ed.
    A vintage car with restored plates will probably not bat Johnny Law's eye, but it's worth mentioning that it's actually illegal in many jurisdictions.
    5window likes this.
  26. davesclp.com
    davesclp.com
    Hi everyone!
    I've got you covered if you're looking for professional license plate restoration! Under certain cir***stances, I can also do some custom license plate replacements for 1956, 1963, and 1970s California plates.
    Check out my work at davesclp.com – I’d love to help with your next project!
    Feel free to reach out if you have any questions or want to discuss your custom needs.
    Cheers,
    Tim
    20240828_124152.jpg 20241113_152529.jpg 20240912_131618.jpg 20241125_113447.jpg
    Bill's Auto Works likes this.
  27. Where have you been for the last 7 years LOL? The great folks here on the HAMB could use a great plate restoration service. A good friend (Steve Hammatt) p***ed last year, but when he was here he serviced the hobby with awesome restored plates! Hope you can take his place & provide quality restoration service for everyone here.
    God Bless & Merry Christmas
    Bill
    https://www.jalopyjournal.com/forum...ar-transport-hauling-open-or-enclosed.614419/
  28. 325w
    325w
    Member used to be on here. Katfish Jack is his first name. He did several fit me. He moved from DFW Texas. I’ve lost contact with him.
  29. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Realizing it's an old thread.
    I'm located in Colorado, I've done a few plates. Primarily paint and lettering, bur would like to give a shot at something a little further gone than what I've used before.
