Projects Bought a Mercury on purpose
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Feb 4, 2023.
  1. So for so good.
    I was hoping it at least had a good rotating ***embly. It does. The rest is just a bonus if it’s good.
    Plus I t learned how to get the valves out.
  2. I’d like to thank @LB for hooking me up with a nice NOS skirt.
    208A0EAC-8CCB-4F4A-A632-905F4FC7BD2A.jpeg 9AC6D123-71D1-434E-8C95-5E64C2AD5E46.jpeg
  3. Those bumper gards and center piece make a great bar grill if laid out horrizontal and welded together.
  4. I had some 49/50 bumper guards. Held em up in the grill opening.
    Looked pretty good.
  5. Squablow
    Squablow
    You have a way to get froze-in valves and seats out that isn't just brute force? Or just got the valves out of the seats? Because I've got a Merc engine that a mouse set up house in the lifter valley and everything in there is hopelessly stuck but the bottom end looks great, I'd love to know the best way to get all of the valves and guides out without wrecking ****.
    chryslerfan55 and bchctybob like this.
  6. Learned how to remove the unstuck valves. Never been this deep in a flathead before.
    The stuck ones? Well, they’re soaking. I did free up the lifters.
    I watched a video where I guy welded a slide hammer to a stuck valve and yanked it up enough the cut the valve with a grinder. Then knocked out the guide.
    My uncle suggested a heat lamp. Warm it a while then let it cool. Repeat. Probably wouldn’t hurt while it’s soaking.
    I figure some parts will be sacrificed eventually
  7. Did a plastigauge check on the mains.
    0.015.
    It’ll come down to the flatty and the 283.
  8. F-ONE
    F-ONE
    from Alabama
    I'm thinking flatty and 6V.
    Hold on, think about what a great teaching tool that can be. Generator, Regulator, Points, King Seely Gauges and senders Heavy Wire and all the old solid-state stuff. Everything is repairable. With the old manuals you can just about repair everything. It's like a flintlock rifle. It's rifle but only more so. A flathead 6V car.....is only more so.
    If you can master a flintlock rifle, you can shoot anything. If you can repair and run a Flathead 6V car, This gives a fundamental understanding of.....a car in its raw form.
    Custom?????
    I had a long reply, but I lost it in editing. The jest was The Mercury is the "Custom Car". It's been done and done and done. I know you are a custom guy; you like to stand out. The Custom Mercury is almost cliched. I'm feeling a little irony.... Custom Guy gets a Mercury, and does not go down the "Merc" Route. The irony is it will stand out in all its Mercuriness.
    Mercuries had a heritage before Barris and Hirohita.
    [Verse 1]
    Now me and my wife and brother Joe
    Took off in a port from San Pedro
    Didn't have much gas and the tires were low
    But the doggone Ford could really go
    Along about the middle of the night
    We's rippin' along like old folks might
    When a Mercury behind, he blinked his lights
    He honked his horn and he flew out of sight
    [Verse 2]
    We had twin pots and a Columbia but
    You people may think that I'm in a rut
    But to you folks who don't dig the jive
    That's two carburetors and an overdrive
    We've made three sparks out of many a-town
    And left the cops spinnin' 'round and 'round
    They wouldn't chase, they'd run and hide
    But me and that Mercury stayed side by side
    [Verse 3]
    I looked at my bride, her face was blue
    I was stuck to the throttle just like it was glue
    We left streaks through town about 40 feet wide
    My brother was pale, he said he was sick
    He said he was just a nervous wreck
    But why should I worry, for why the heck
    Me and that Mercury was neck and neck
    [Verse 4]
    Now on through the desert we did glide
    A-flyin' low and a-flyin' wide
    But me and that mercury was takin' a ride
    We stayed exactly side by side
    I looked in my mirror and I saw somethin' comin'
    I thought it was a plane, the way it was a-hummin'
    A-runnin' along at a terrible pace
    I knew right then it was the end of the race
    When it flew by us, I turned the other way
    The guy in the Mercury had a-nothin' to say
    And I could see it was a streak of gray
    It was a kid in a hopped-up Model A
    Hot Rod Lincoln 1st part....
    Well, you heard the story of the hot rod race that fatal day
    When a Ford and a Mercury went out to play
    I really enjoy my 6V 51 Ford Coupe. It's a car only more so.
    I know you'll do great whatever route you choose but....
    I do have one request.
    Whatever you do, please, please do not airbrush James Dean, Marylin or Bee-Bop-a-Lula on the decklid! ;)
  9. Dang. That’s a lot of typing. Thanks I think:):):):)
    No for any corny airbrush work.
    6v?……..I’ve got a 12v gen hiding somewhere.
    Points? Yep
    Might even run the gen if I go 283. And it would more than likely get points.
    and plan to keep the 3rd pedal
  10. Got the mock up 283 ready
    We’ll swap it out with the Y on Monday
  11. If you soak the flathead submerged in kerosene for a week or two it'll come unstuck.
    My prefference would be the SBC.
  12. A Boner
    A Boner
    Pretty big vehicle for a mild flathead to lug around…just saying!
    SS327 and anthony myrick like this.
  13. I’m not in a hurry :)
  14. Dick Stevens
    Dick Stevens
    The 283 would work much better than a flathead and it is traditional!
  15. 51504bat
    51504bat
    But the flathead was first
    chryslerfan55 and anthony myrick like this.
  16. Dick Stevens
    Dick Stevens
    That's the point, the 283 is an upgrade from a flathead!
  17. Well, the 283 was a nicer fit
    Trans and clutch linkage hooked up.
    rams horn looks like they will work.
    fuel pump would need a notch
    19 inch fan. Needs a little more room but we can make if work.
    plenty of room under the pan
  18. Engine is offset about an inch to the p***enger side.
    Less room for a mechanical fuel pump but helps the exhaust a lot.
    A 265 manifold would center the engine.
    But I was using the merc clutch lever to set the engine placement. I could shorten it to center the engine but the fuel pump would still need a notch.
    Or go electric.
  19. @anthony myrick There is a HAMBer with both a Desoto toothed grill AND a Kaiser grill bar for sale at the moment!?
  20. I’ve got the small desoto grill.
    Kiser bar. Mmmmmmmm those are ***y
    I’m kinda liking the 51 merc.
    And mine is stainless.
  21. Anyone ever seen an adapter like this?
    Would love to find one
    Supposed to be Chevy to the later flathead bell housing
    I think anyway
  22. bobss396
    bobss396
    The 283 looks fact-tree, well done. I love the ram horn manifolds, the center-dump ones are hard to come by, circa 1960-ish.
    Okie Pete, Sancho and anthony myrick like this.
  23. Temp engine mounts
    Cycled thru the gears and clutch is good.
    Will have to make a call on mechanical vs electric pump.
  24. guthriesmith
    guthriesmith
    Can’t believe those are just temporary mounts. Surely they would hold... :D
  25. bchctybob
    bchctybob
    There's a reason small block Chevies get transplanted into so many different vehicles....
    I like your approach, trying it centered, trying it where other parts dictate - good old engine swapping techniques. It looks good in there, traditional swap. I'd put a nice, finned block-off plate where the fuel pump goes and run an electric one.
    You're not liking the dual bellhousing set-up?
  26. The bell housing set up is good but if I had that later style adapter it opens up more trans options.
    I’ve got the late late style flathead bell as well, those use the 49-64 style trans.
    But I’ve never messed with that style adapter. So starter and flywheel placement (spacer ?) would be my questions.
  27. The 4 blade fan clears the old radiator.
    Going to run a gm radiator but it will fit closer to the front of the car.
    Im not a big fan(pun) of the fan placement.
    a fan shroud should help direct air across the entire radiator.
  28. Free parts are free parts
    Stock Racer, drdave, 40two and 7 others like this.
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    anthony myrick likes this.
  30. Yep.
    Gonna save the trans and bell from the s****yard.
    The block will turn into furniture
