Projects built lots of cars, but never a 32 roadster...
Discussion in 'The Hokey Ass Message Board' started by SDS, Oct 14, 2021.
  1. SDS
    SDS
    Ch***is is finally off the jack stands (suspension fully ***embled) and I've started plumbing. Had to hang the exhaust pipe to work on the layout so I know where the flex line will live.
    PXL_20230212_212135103.jpg PXL_20230212_212117945.jpg PXL_20230212_212104311.jpg
    shortypu likes this.
  2. NJ Don
    NJ Don
    Hi Scott,
    Your project is looking great!
    I ordered the same dash panel for my car from Phoenix Machine. Should be here soon.
    DC
    pprather likes this.
  3. pprather
    pprather
  4. SDS
    SDS
    Mine is made by Bill Grau (5 gauge Auburn style dash insert)
  5. vtwhead
    vtwhead
    Scott, can you give me the measurement between the rear spring mounts. Mine appear to be wider and were installed by the previous owner.
  6. SDS
    SDS
    Mounts on rear-end ? Where the shackles attach?
  7. vtwhead
    vtwhead
    yes, mine IIRC are 46 1/2 center to center. What spring did you use?
  8. SDS
    SDS
    The spring perches on my rear end are 43 3/5" center to center. I am relatively sure the spring is a Posies unit. This tag was on the spring...
  9. vtwhead
    vtwhead
    Thanks Scott. yes that is a Posies piece.. Mine is a used 40 spring and my hangars are wider. It is on the list to be changed as it sets the body too high.
  10. SDS
    SDS
    Got myself out in the 40 degree garage today and got the gas tank secured
  11. NJ Don
    NJ Don
    Hi Scott,
    Tell you an interesting story regarding my '32 gas tank. I had just filled my gas tank and went in to get a cup of coffee. I come out and a guy is looking at my car and tells me I have a gas leak. WTF? I look under the car and the gas is coming out the vent hose I ran to the bottom front of the gas tank from the fuel pick-up ***embly, like that shown in your picture, the angled pipe. I crack the gas cap to relieve the pressure and it stops. I drive home and it's doing the same thing. When I fill my tank I fill to the bottom of the gas cap pipe, not overly full. I ended up draining and removing the tank. The vent pipe has a "roll-over" shut-off valve that protrudes into the tank about 2". When I filled my tank the pressure eventually started a siphon out and down the vent hose. I ended up removing the fuel pick-up ***embly and cutting the roll-over extension off the vent pipe. Problem solved. Looking back I probably could have run the vent hose up above the tank somewhere so not to start a siphon. If I roll my car the roll-over valve will be the least of my worries. Just one more thing to keep an eye on!
    Regards,
    Don
    1-SHOT, shortypu, SDS and 3 others like this.
  12. SDS
    SDS
    Got the $14 (Amazon) exhaust wrap on yesterday. Was easy to work with, hope it performs.
  13. SDS
    SDS
    Good from afar, far from good (at least in my perfectionist mind). 3/8" Ni-Cop isn't exactly easy to bend.
    Somebody tell me that I don't need to redo the entire thing because this bend looks ****py. It's not kinked, it's just dented a little because of the compound bend using my bender. Don't think the volume of the tube is affected.
  14. Anderson
    Anderson
    Curious what brand that stuff is. I have found they are not all crated equal. I used plenty of the stuff before and it’s always been great. Most recently I used 3/16” and 3/8” on a project at work and they both were normal. But needed to bend 5/16” for the last fuel line up to the manifold and it might as well have been stainless. First time I’ve had any NiCopp that was that hard. I don’t remember what brand any of those were though.
  15. pprather
    pprather
    My at***ude is, no one will ever see it once the body is installed.
    Give up the idea of perfection, you are the only one who cares. Let's get this rod drivable.
    05snopro440 and seadog like this.
  16. X38
    X38
    What are you bending it with?
  17. vtwhead
    vtwhead
    Scott, I have had similar issues with Nicop. I doubt that will interfere with the flow and it would be a pain to do it again to see the same result. I borrow my friend's hydraulic bender to do the bubble flare in the end of 3/8 nicop for holding the hose. One time it works fine, the next the tube wrinkles..go figure, aggravating!
  18. SDS
    SDS
    Summit Racing brand - it is almost as hard as steel to bend.
  19. SDS
    SDS
    That's why I do a double flare on the ends where rubber will connect - it's tough to get the rubber on there, but it really seals well.
  20. SDS
    SDS
    OK...front half came out WAY better. As I have plenty of tubing left, I think I'll re-do the ugly rear half
    A Boner and shortypu like this.
  21. Dick Stevens
    Dick Stevens
    I don't get it, you put exhaust wrap on that will make the exhaust rust out, not to mention that it is ugly, and you're going to redo a brake line that has bends that aren't perfect which no one would see when the roadster is done.
  22. SDS
    SDS
    It won't rust, the pipes are is Cerakoted. Thanks for your opinion, but everyone who's seen it likes the wrap.
    I'm re-doing the brake like because I'm a little concerned with it cracking on that crease (right above the exhaust pipe). Will help me sleep at night.
    shortypu, loudbang and vtwhead like this.
  23. SDS
    SDS
    Much better...
  24. pprather
    pprather
  25. vtwhead
    vtwhead
    Well done! Now you can sleep better tonight:rolleyes:
    SDS likes this.
  26. NJ Don
    NJ Don
    So, what did you do different? Same tubing?
  27. SDS
    SDS
    Bent up a new one with smoothe bends
  28. SDS
    SDS
    Started on the brake lines tonight.
    A word of advice to anyone who uses the Pete and Jake's br*** elbow and T fittings that attach to your through the frame fittings - don't tighten them too much because the fitting will deform from the wrench - the walls are very thin. I screwed my elbow up and had to order a new one - I think when I put the new ones in, I will put a stainless tube nut in the hole so it can't be deformed.
    Papas32 likes this.
  29. SDS
    SDS
    Kris Kross applesauce...
    I need something to hold the Wilwood valves to the frame.
  30. pprather
    pprather
    Can you fix use a double brake line clamp, set off the frame, between the master cylinder outlets?
