Technical Cleaning a radiator.
Discussion in 'The Hokey Ass Message Board' started by trollst, Mar 22, 2023.
  1. trollst
    trollst
    Hey guys, been lurking all winter. My old girl, my 36 has been running green coolant for twenty five years, it's time to give it the big clean. It tends to heat up faster than it used to, trouble is, there aren't many rad shops that work on rads, most just re and re stuff now. Got any suggestions for flushes that work? Gonna try it myself.
  2. Jeff Norwell
    Jeff Norwell
    MODERATOR
    No rad shops will boil for you?
    VANDENPLAS likes this.
  3. BJR
    BJR
    Pull the radiator. Turn it upside down and run water through it backwards as fast as you can. You will be amazed at all the **** that will come out of it.
  4. BamaMav
    BamaMav
    from Berry, AL
    Cascade dishwasher soap. Won’t harm copper, br***, or aluminum radiators. Put it in, run a while drain and flush, if not clean enough, repeat. My block had a bunch of rust scale in it, ran the Cascade through it a couple of heating cycles, flushed until it ran clear, no more scale.
    Muttley, alanp561, Driver50x and 6 others like this.
  5. trollst
    trollst
    No, interior BC has a lack of rad shops.
    Beanscoot likes this.
  6. I’ve done the cascade deal a time or two.
    And CLR
    '28phonebooth likes this.
  7. Petejoe
    Petejoe
    from Zoar, Ohio
  8. Fortunateson
    Fortunateson
    Hey why don’t you drop on down to the coast? I think the shop in Port Moody still work on radiators...
  9. How bad is it ? Just old ? Brown and murky ?
    if it’s just age your concerned about drain it , fill it add a flush run it and drain and fill one last time .
    If it’s brown and murky . Pull the hoses off , garden hose down all the inlets and outlets engine and rad .
    Put it back together with a flush and drive it , drain and fill everyday after a good drive until it’s clear.
    I had a 460 years ago that looked like thanksgiving gravy in the rad , did what I outlined above but also poped the frost plugs out that I could get to and hit the engine internal with a pressure washer. Couple flushes and a drain and fill every morning when I got into work and by the end of the week it was Chrystal clear .
  10. Mr48chev
    If you are driving it now you might take a shot at flushing the crud out of the outside of the core with either a garden hose or spray wand car wash. If you don't run a screen in front of the radiator you might have a world cl*** collection of BC bugs in that radiator.
    firstinsteele likes this.
  11. Look up a product made by Fleetgard Filters called Restore Plus. It’s a heavy duty acid based cleaner made for removing heavy rust and scale. They make two different types, Restore and Restore Plus. Regular Restore is made for cleaning oil from cooling systems. Fleetgard is owned by ***mins Engine and is available from ***mins dealers. We use both products at work with excellent results.
    Desoto291Hemi likes this.
  12. 4ty
    4ty
    Lots of the Model A guys use vinegar, run to get hot and then flush (do NOT do on a concrete driveway).
    Paul in CT
    anthony myrick likes this.
  13. I removed the thermostat in a FE. Poured a jug of clr in the radiator and let it run for about 15 minutes.
    Then opened up the drain and flushed with a hose.
    Looked like brand new cast iron on the inside of the block
    Radiator looked better as well
    Jeff Norwell, trollst and Driver50x like this.
  14. hemihotrod66
    hemihotrod66
    Well if you look thru old Model A books they tell you how to run caustic soda to clean the cooling system....You wouldn't want to run this thru anything that is aluminum but fine for steel and br***...
    RDR likes this.
  15. THIS! If you can get what the commercial AC guys use for cleaning the fins on the outside condensers. Melts stuff right out.
    Ben
  16. HOTRODPRIMER
    HOTRODPRIMER
    Any radiator shop has a vat, all they need to do is vat it overnight nothing hard about that. HRP
  17. trollst
    trollst
    Might have to, we'll see. There's a guy in Osoyoos, he's ancient, but may still be working.
  18. 2OLD2FAST
    2OLD2FAST
    from illinois
    One brand is Koil Klean
    Be careful with a pressure washer , good way to bend fins . Garden hose with a spray nozzle is generally plenty.
  19. trollst
    trollst
    No, it's still green, no sign of murk, but it's been running twenty five years, I can see it's got settlement on the core. Long as I'm moving, it's excellent, but slow down, the temp rises faster than it used to. I'm sure the silica in the coolant has settled out.
  20. inthweedz
    inthweedz
    20230324_112927.jpg Back in the day, we removed both hoses, and had a water hose/air hose (with operating valve, like an air gun) My one pictured uses a tire inflator, with a big tapered rubber sealing plug at the end ..
    The rubber end/plug, was put in the bottom of the radiator, (or reverse to water flow) and the water turned on, when the water came out the other outlet, short bursts of compressed air was used to move the gunk until the water ran clean..
    alanp561 likes this.
  21. arse_sidewards
    arse_sidewards
    from Central MA
    Both aluminum corrosion and steel corrosion can be cleaned off their respective metals with acids.
    If you have an aluminum engine and radiator a vinegar solution should work. But if you have an aluminum engine and radiator then there also shouldn't be enough volume of corroded material to ever plug up the radiator.
    I don't know enough about the chemistry involved to say if or how one can go about chemically cleaning a rusty iron block on a system that has aluminum present.
  22. BJR
    BJR
    If you can see crud on the top of the core when looking through the radiator cap, the only way to get rid of it is reverse flow flush. Which works better if the radiator is upside down. This can be done after all the chemical bathes with the engine running to loosen up stuff.
    trollst likes this.
  23. Jeff Norwell
    Jeff Norwell
    MODERATOR
    This is what I would exactly do as Anthony suggested..... cheap and easy. I completely understand the lack of rad shops... they are a dying business... same as electric motor shops and water pump rebuilders.
    trollst and anthony myrick like this.
  24. PhilA
    PhilA
    I find even that is often too much for old br*** fins.
    I mix up the chemicals in a cheap potato pump and use that. Most will undo the nozzle to create a very fine stream that'll get deep into the core with ease.
    Let the chemicals do the work then rinse with clean water from the same pump, or the watering can.
  25. 05snopro440
    05snopro440
    I like the Royal Purple product, it's called Royal Flush. There's a couple others I've tried from Canadian Tire with good results. They require you to dump your coolant, refill with this stuff and water, get it warm, then let it sit, dump it, flush it with water, then refill with coolant. I've had success getting scale off of copper-br*** and aluminum radiators with these and they're easy to use and work great. My 62 Bel Air had brown coolant for years, from the moment the rad came back from the shop it was always that way. Then I found it was heating up quick after sitting for several years. I did the flush and spent a lot of time flushing it with the garden hose to get the brown out and clear water coming out. Refilled with new coolant and water wetter and it's like new again!
  26. doug3968
    doug3968
    Might need to keep in mind rad cap may be 16psi and need to take it easy with garden hose connected to public water. Even with all ports open, pushing water thru one end at 80psi could damage.
  27. 05snopro440
    05snopro440
    That's a new one. What do you think flushing water through in an open system is going to damage? You should be flowing water through, not forcing it in.
    Regardless, if you're flushing the system with the garden hose, it's best to do it with both the upper and lower rad hose off and the thermostat out, so that you can flush out the block and the radiator separately.
  28. Jeff34
    Jeff34
    That's what I used. I made an adapter from a PVC union and a few other random parts to fill with water and blast with air. Worked great! No more overheating.
  29. trollst
    trollst
    6 pound cap.
  30. trollst
    trollst
    Thanks guys, gonna do the CLR thing. I'll let you know.
    Jeff Norwell likes this.
