Hot Rods XO/PP Bonneville project
Discussion in 'The Hokey Ass Message Board' started by john mullen, Dec 28, 2017.
  1. fabricator john
    fabricator john
    from venice fl.
    years ago a friend built intakes for his drag vw , yes you can buy weber intakes but he wanted to make his own , he asked me about a source for tapered aluminum tubing for runners , i was walking thru wally world a few days later and spotted kids aluminum baseball bats ,they were cheap (at the time) that's what he ended up using, turned out slick ,the IDA's were opened up and had 51.5 mm throttle plates ,
    fabricator john
    miss you dad
  2. john mullen
    john mullen
    This is what I was making in the above photos.
    Plenum to Port entry velocity stacks 20230325_121608.jpg 20230324_124900.jpg 20230325_121637.jpg 20230325_121648.jpg
  3. Hmm, three deuces, all you need now is a four speed and a 389 ( i’m kidding) he he.
  4. john mullen
    john mullen
    Got the 4 speed just need cu. in. And hp
    Stogy and D-Russ like this.
  5. john mullen
    john mullen
    A little more progress on the plenum 20230327_155619.jpg 20230327_155630.jpg
  6. john mullen
    john mullen
    Who is this masked
  7. It occurs to me that you, @Druss, have been inside too long. He he.
  8. D-Russ
    D-Russ
    That's not me, that's @Scott_Rod .
    Just Gary, Stogy and chryslerfan55 like this.
  9. I see. Methinks the man needs to get out more.
    D-Russ likes this.
  10. john mullen
    john mullen
    Thank you jimmy six for the parts. They arived in good condition today.
    chryslerfan55, saltflats and D-Russ like this.
  11. john mullen
    john mullen
  12. john mullen
    john mullen
    Figuring out the intake runner angles for the sheetmetal intake using a printed protractor. 20230401_172919.jpg 20230401_172332.jpg
    Lol modern technology off the computer. Love it
  13. D-Russ
    D-Russ
    The intake for the Skinner head is progressing nicely. We worked on the plenum top today along with priming the bedrails on the 640.
  14. Okay so you’ve got three 97s now all you need is a four speed and a 389. He he.
    D-Russ likes this.
  15. john mullen
    john mullen
    saltflats and chryslerfan55 like this.
  16. john mullen
    john mullen
    Looking at the live camera on the salt flats and it looks like it snowed on the mountain again this morning.
    Still has water covering the salt as far as you can see on the video.
  17. jimmy six
    jimmy six
    We have 4 months and wind coming… no worries yet. I’m completing the rear brake maintenance on our roadster so I can safely load and unload it from the trailer and we will be ready to load up..
    Glad to see the parts arrived safely I hope they are all good and usable. Great progress on the intake system. JD
    chryslerfan55 and D-Russ like this.
  18. john mullen
    john mullen
    Thank you JD hopefully it will dry out...
  19. D-Russ
    D-Russ
    Makin' 55 DCOE base gaskets!
  20. john mullen
    john mullen
    20230407_132340.jpg 20230407_132345.jpg 20230407_171153.jpg Working on the burst panel for the intake and phenolic spacers for under the carbs
  21. Why do you need burst panels? Is there going to be more than 1 atmosphere inside that new intake?!
    chryslerfan55 and saltflats like this.
  22. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    backfire protection
    old flopper likes this.
  23. john mullen
    john mullen
    OK for those who are asking about the burst panel addition on the intake. It is being added for possable future use as we intend to use this engine for racing other venues that alow power adders. Such as drag racing. Once the intake is finished and powder coated I do not want to go back and weld in a burst panel and mess up the powder coat. Maybe never used but it will be there if we wanted it. Hope this answers questions about why I'm doing this.
  24. old flopper
    old flopper
    Exactly what I thought, there’s so many possibilities like valve or spring failure, valve float or hanging at high rpm’s or ignition system incorrectly firing cylinder at wrong time, etc. Why not take a little extra time to protect a sheet metal intake and maybe ~ $1500 of carburetors from a backfire.
  25. john mullen
    john mullen
    Backfire is a big concern when you have this much cost in the intake system especially with power adders. Precautionary
    Measure in advance is worth the extra time and effort.
  26. john mullen
    john mullen
    OK enough on the 302 build.
    Let's get back to our next trip to the Arkansas standing mile with the 262 ford engine. We will be leaving Virginia on May 3rd in the evening heading to Arkansas. Arriving around mid morning for tech inspection.
    Racing on Friday and Saturday and heading home early Sunday morning.
    We will be posting this adventure as it unfolds so look for our post.
    Thank you all for following the Virginia H.A.M.B. Special story.
  27. john mullen
    john mullen
    Progress on the Skinner sheet metal 20230412_102941.jpg 20230407_171153.jpg intake
  28. john mullen
    john mullen
    A friend posted this photo of me on my Dirt Drag Harley
    ( HOG WILD) BACK IN THE 80'S MAN WHAT A BLAST THIS THING WAS! received_726145602570267.jpeg
  29. john mullen
    john mullen
    In need of 215 or 223 Ford p***enger car oil pan.
    D-Russ and The Magic Ratchet like this.
  30. Nailhead Jason
    Nailhead Jason
    Its not a car, but i still have the whole 223 truck motor with a good pan on it if that helps John.
