Projects "Saving" a Studebaker
Discussion in 'The Hokey Ass Message Board' started by Jacksmith, Dec 14, 2022.
  1. Six Ball
    Six Ball
    from Nevada
    It looks like it belongs there. Nice work! I'll have to remember this if I ever get to my '59. I have a 331 for it. After seeing how you paint cleaned up I'll leave it that ugly Salmon color and call it "The Pink Caddy-Lark". :rolleyes:
    Hnstray and Jacksmith like this.
  2. Rynothealbino
    Rynothealbino
    What do you think of the radiator so far quality wise? I'm looking at that brand as an option. They make one that is supposedly a direct fit for my '54.
  3. Jacksmith
    Jacksmith
    from Aridzona
    My opinion of the radiator is that it is top notch! They have a huge selection available and many choices as far as 2, 3 & 4 row cores, cross flow options, fans, shrouds etc.. I ordered it and had it in hand in 2 days.
  4. Jacksmith
    Jacksmith
    from Aridzona
    I'm able to use my "long" water pump, pulleys, brackets, etc. with a steel 4 blade fan. I'm also using silicone radiator hoses with an extension pipe. So far so good.
    The rest of the exhaust pipe components came in so I can start s***ching that together...
    Greenblade, Joe Blow, egads and 5 others like this.
  5. Jacksmith
    Jacksmith
    from Aridzona
    B.T.W., Those mufflers are not "gl*** packs" as they may appear. They are a compact turbo style chambered muffler that are not loud but do emit a nice mellow low rumbly tone.
    Ragged Edge, egads, Six Ball and 2 others like this.
  6. Jacksmith
    Jacksmith
    from Aridzona
    The 90 degree exhaust pipe has been tacked to the collector and the ball & socket joint is in place. A short straight pipe is joined to a 45 degree pipe to get around the trans cross member. IMG_1769.JPG IMG_1770.JPG IMG_1771.JPG
    Now a second 45 pipe is trimmed and tacked in place.
    Next another straight pipe will be cut to place the muffler.
    Joe Blow, egads, Ragged Edge and 5 others like this.
  7. Jacksmith
    Jacksmith
    from Aridzona
    A ball & socket joint was tacked to the muffler and trial fit. Then a 90 degree bend pipe to mate with a U pipe, to go over the axle, was trimmed, tacked and trial fit.
    It was determined that the U pipes would run parallel to the rear shocks. A piece of 2x3 wood was used to maintain clearance.
    After measuring and cutting the exhaust pipe a couple pieces of angle iron were secured to the pipe to keep it straight & tight.
    After building the other side and installing the gas tank, the U pipes and tail pipes will follow...
    Joe Blow, egads, Ragged Edge and 7 others like this.
  8. Six Ball
    Six Ball
    from Nevada
    I just sorta' hate people with skills. :rolleyes: Well, maybe they make me hate myself. :eek::D
  9. Jacksmith
    Jacksmith
    from Aridzona
    Ohhh stop... No ya don't!
    Six Ball likes this.
  10. Jacksmith
    Jacksmith
    from Aridzona
  11. bchctybob
    bchctybob
    When working with exhaust, angle iron and tubing go together like peanut ****er and jelly!
    Ford52PU, Six Ball and Jacksmith like this.
  12. Jacksmith
    Jacksmith
    from Aridzona
    More of the same, just on the other side. IMG_1797.JPG IMG_1810.JPG IMG_1812.JPG
    Ford52PU, Joe Blow, egads and 5 others like this.
  13. Jacksmith
    Jacksmith
    from Aridzona
    A bit more progress:
  14. aussie57wag
    aussie57wag
    from australia
    It's do cool to have an off beat car. Don't ruin it by putting the same common generic motor as every other modified car. This would be supercool with a hemi, olds, pontiac, y-block or even an AMC or rambler v8 just to continue the oddball theme.
    Greenblade and Six Ball like this.
  15. X38
    X38
    Ah well, it's already ruined. You really should contribute earlier.
  16. SS327
    SS327
    He might have to junk it now.
    Joe Blow likes this.
  17. Jacksmith
    Jacksmith
    from Aridzona
    Sounds good... send a check!
  18. Jacksmith
    Jacksmith
    from Aridzona
    Yeah it was in better shape when it was laying out in the sun for 30 years... don't you guys have something better to do?
  19. Six Ball
    Six Ball
    from Nevada
    Yeah, Kinda, late now. I think the engine was there when the car came along. If engine choice was being considered I would have pushed for a Studebaker, a much under rated strong V8.
    Nice exhaust work. Finding room to run the exhaust was one of the biggest issues on my son's '54 Stude wagon. There were a lot of space issues with that car.
    bchctybob likes this.
  20. X38
    X38
    Hey man, I'm on your side. I guess you missed the sarcasm. I am also a victim of the other guy because of the engine I'm using, one that he disapproves of. He has posted twice in my build thread to tell me so.
  21. lumpy 63
    lumpy 63
    Yep, he's like a broken record. Nice work Jack:D
    Joe Blow, X38, Hnstray and 1 other person like this.
  22. Jacksmith
    Jacksmith
    from Aridzona
    Yup there's one in every crowd; For some sick reason they feel better about themselves by criticizing others. Thanks guys, I appreciate the support...
    Ford52PU, Joe Blow, SS327 and 6 others like this.
  23. Six Ball
    Six Ball
    from Nevada
    You know that what you are doing is the real deal! Don't let what ANYONE says bother you. This is a really cool save and all in Studebakerdom thank you!
  24. Racingsnake
    Racingsnake
    from So Cal
    Any info on the mufflers?
    Nice job on the exhaust btw, and the rest of the car too. Should be a fun ride
    bobbytnm likes this.
  25. aussie57wag
    aussie57wag
    from australia
    Maybe he actually can't think outside the box. Just has to follow the crowd.
  26. X38
    X38
    Well, he’s in the same box as Studebaker then, because they ended up using SBC engines too.
    Which means he’s keeping it in the family.
  27. Jacksmith
    Jacksmith
    from Aridzona
    Those mufflers are made by Jones. High quality, I get them from our friends @ Summit.
    bchctybob and Racingsnake like this.
  28. Jacksmith
    Jacksmith
    from Aridzona
    As the exhaust proceeds to the rear, I've reached a point were the gas tank needs to be in place in order to determine the placement of the tail pipes. However when I went to install the tank (which was in the trunk when I got the car) I realized that I was missing the mounting brackets. IMG_1826.JPG IMG_1829.JPG
    Luckily a buddy had a better tank with the brackets... so I saddled up and went, via old 66, and picked it up. Ha-ha, I really enjoy those BURMA SHAVE signs!
    With the tank installed I can get the exhaust done and move on...
  29. Six Ball
    Six Ball
    from Nevada
    As a kid we made many 66 trips from Texas to SoCal. Most of the landmarks were still in business and the towns were thriving. The neon was exciting when movies & TV were still black & white.
    Looks like a solid tank!
    Jacksmith likes this.
  30. bobbytnm
    bobbytnm
    The Rte 66 towns are trying to make a comeback. I spend quite a bit of time in Tu***cari, NM. It's finally starting to see a resurgence (not a lot) but its moving in a positive direction.
    bchctybob and Six Ball like this.
