Technical Marching forward 1-2-4-3, Banger time...
Discussion in 'Traditional Hot Rods' started by hotrodfil, Mar 1, 2023.
  1. 4BangerDean
    4BangerDean
    I‘m going to install a Stromberg 97 on my Model B. The truck is 100% stock at this moment. I’m not sure of everything I may need for the linkage and cable actuated choke. Any help pointing me in the right direction for what I need would be greatly appreciated.
  2. wuga
    wuga
    Your intake should come with a bar to connect the pedal linkage to the carb linkage. The link between the red bar and the carb came from the updraft I think. Don't have the choke anymore.
    Warren
    BiscayneBrain and Outback like this.
  3. SUHRsc
    SUHRsc
    Bad news on the HAL front.... unfortunately looks like this engine will need to be completely gone through. I noticed some odd lash in the upper part of the gear tower. Seems the cam blocks weren't fit correctly to the head and the idler gears are shot. The exhaust cam was so loose you could turn the crank almost 10 degrees before the cam moved. intake cam so tight that the tips of the teeth dug into the base of the idler. Looks like those 4 upper gears will need replaced and in the process of this happening there is metal shavings from the gears throughout the engine... with some help it looks like I found some ready made gears that can be modified to work. thankfully the rest of the gears seem pretty darn nice still. Pulled the pan and looks like a cast crank, not billet. It does have the nice tubular rods like an Offy though. Appears they hit the aluminum pan rail adapter a bit... At this point I don't trust any of the work with signs of shoddy craftsmanship all over.... so starting at square one I guess..... Overall its still a good engine to start with and not easy to go find another., just going to need a good bit of going through and more money invested before its ready to run.
    here's some photos if you've never seen inside one of these.
    ya win some, ya lose some.... IMG_20230318_070830845.jpg IMG_20230318_070853415.jpg IMG_20230318_103140567_HDR.jpg IMG_20230318_071952316.jpg IMG_20230315_151318937.jpg IMG_20230315_140601663.jpg
  4. UGH, it was delivered here as a "rebuilt, ready to run" motor for my Buddy.
    He took off to NZ and it sat thru Covid in the trailer.
    It looks like we dodged a bullet here, sorry to p*** along to you.
    Those gears look to have been run for a while like that and should have been howling pretty good.
    Hope the cams are not too beat up, everything else can be easily fixed, cams take a little finesse.
    I was just looking thru some do***entation, all A/B motor DOHC and cams are chain driven.
    Hope you get this running, John
    Old Dawg, Crazydaddyo and Outback like this.
  5. SUHRsc
    SUHRsc
    Thanks John,
    Almost looks like it was ***embled knowing it had the bad idlers and the rest pretty good but then the incorrect shimming at the cams caused it to eat those gears a bit too when fired for likely just a short time....probably because of the noise I ***ume. Luckily it was loose enough to not hurt the big center idler. Stripped holes and other work just seems it wasnt done by a very tedious person so I'm going to check everything out. A good excuse to learn more about them rather then just run it ....
    The actual cams are still real nice, just the cam gears too the hit.
    Jet96 and Outback like this.
  6. 4BangerDean
    4BangerDean
    Is this what is referred to as boxing the rod? Could someone explain what was done with these?
    Thanks
  7. Kevin Pharis
    Kevin Pharis
    from Califunny
    Here are a few pics of the steps to shorten, lighten, and box the rod
    GuyW, 282doorUK, burl and 5 others like this.
  8. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    So hit Chickasha prewar swap meet, man tons of T stuff, not much A, but I bought what I could. On the way up we stopped by Piranios Antique Auto, picked up some parts, got a shop tour of what was left after Dennis p***ed on and got to geek out on the salt flat car.
    So no real pics of the swap meet, cold, windy, but some decent deals to be had. Truth be told, almost all the stuff I bought is already sold. Kept a few things for myself...Highlight photo.
    So I decided to do the adapter to the 34 trans I have. So I have a clings adapter on its way.
    So while the motor is out, I can do the thrust washers easier this way... Here is the thrust washer damage. I think due to no oil grooves that it just basically starved for oil and wore down. Micrometer shows .040 wear so My calculations of crank play were correct. Test fitting to see what Intake I liked more. Decided to go with the Zepher cause someone in germany wants the burns.
    Savage Coupe, Tman, Stogy and 4 others like this.
  9. 4BangerDean
    4BangerDean
  10. Kevin Pharis
    Kevin Pharis
    from Califunny
    These rods are A big end with T small end for an A crank in a T motor. The A rods are 1/2” longer than a T, plus the crank is an extra 1/4” stroke. Final length for this set is 6.875”
    G Baese and BiscayneBrain like this.
  11. Kevin Pharis
    Kevin Pharis
    from Califunny
    Picked up another batch of polished parts today… and have most of the speedster engine stripped down. Will be pulling the head off and cam out this weekend and heading to San Jose to have it ground early next week! Next step is to get all that shiny stuff under the hood…
    A3BD3B63-73C6-47B9-93C9-CF813723EB21.jpeg 43E2FF85-41DF-4F0A-9B14-EC914C34C56F.jpeg
  12. Outback
    Outback
    from NE Vic, Oz
    Wow!
    Stogy likes this.
  13. BeaverMatt
    BeaverMatt
    Hi All - Does anyone know if there is going to be a hill climb/time trial event in Auburn, CA this spring?
  14. Dan from Oakland
    Dan from Oakland
  15. Dan from Oakland
    Dan from Oakland
    Regarding the Jenkins head:
    If you still need help with your rockers try these guys- they have done 4 banger stuff in the past
    http://rockerarms.com/index.html
    Or try Smith Brothers for pushrods.
    40 Olds likes this.
  16. BeaverMatt
    BeaverMatt
  17. 29 Speedster
    29 Speedster
    from Colorado
    I took the engine out of our 30’s Flat Tail Race Car to freshen it up, and thought some may find the parts interesting. Pictures attached.
    1. Race Car, B Engine McDowell OHV.
    2. Front Drive Oil Pump driven off Cam Gear. Pick-up tube in Pan covered by a screen, Output to Regulator, then Oil Galley beneath Side Cover. Oil P***ageways to Mains enlarged.
    3. Side Drive Magneto. Don’t know brand.
    4. Piston Dome at TDC. JE Piston Number is X99, 4” Diameter.
    5. Head Combustion Chamber. Valves are 1.75 in.
    6. Strengthened Front & Center Main Caps.
    This engine is much different for me. Progress is slow, trying to not make any mistakes. Going to check Pistons-Head-Valve Clearances this week.
    - 1AB0CF27-1DB2-4D1A-8DB7-AF599C011E40.jpeg 532F8A6A-B2B5-4727-88F8-47FA81E604A6.jpeg B97A5674-D21F-40B3-A78E-B7DA4E84B639.jpeg ADC4EEF5-48F2-4295-B024-F1594E8CEA7D.jpeg 5CDC09AC-6694-4C60-938E-724DDDEC6F29.jpeg D942532E-EF4D-42B2-9A45-126A869CF110.jpeg
  18. Crazydaddyo
    Crazydaddyo
    Close
    GuyW, G Baese, Jet96 and 7 others like this.
  19. Slightly off topic but I have been working on this banger for my GPW/Willys MB. Hopefully I can fire it in a couple weeks! 9077D65D-C9B8-44EA-B82E-B1D8D4AD1BDE.jpeg
    GuyW, PINEAPPLE, Jet96 and 5 others like this.
  20. That's fascinating! Do you mind posting more photos of the cam gear / tang, and the back of the timing cover?
  21. 29 Speedster
    29 Speedster
    from Colorado
    The Timing Gear Cover is special made aluminum with machines mounting location for the pump. The interface to the timing gear is just a slotted shaft, the fixture on the gear bolts to the timing gear.
  22. Crazydaddyo
    Crazydaddyo
  23. alchemy
    alchemy
    Retson asked me for pics of my marine conversion front cover, so I might as well post them for all to see. I have the rest of the kit as well, but I build hot rods, not boats, and I think this is the only part that’s useful to me. The accessory drive has a gear the same size as the crank gear, so it will spin at crank speed.
    Jet96, GuyW and Outback like this.
  24. Dan from Oakland
    Dan from Oakland
    The Rutherford sounds great!
  25. Crazydaddyo, what brand is that electric water pump setup?
  26. brokenspoke
    brokenspoke
    DAMMMMMM
    Crazydaddyo and 4BangerDean like this.
  27. Crazydaddyo
    Crazydaddyo
    skip65 likes this.
  28. studebakerjoe
    studebakerjoe
    Screenshot_20230307-123510.png Does anyone recognize this car?
  29. alchemy
    alchemy
    I’ve seen pictures of it, but don’t remember where. Maybe a more modern Hop Up Magazine? Maybe on the HAMB?
    studebakerjoe likes this.
  30. Kevin Pharis
    Kevin Pharis
    from Califunny
    Dropped off a cam core at RedLine Cams in San Jose today… now I just have to wait! Until then, I’ll be building the exhaust, oil lines, and throttle linkage
    PhiltheThrill, Jet96, GuyW and 10 others like this.
