Technical Differences In SBC's
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Mar 28, 2023.
  1. Orange, blue, or black. And bore/ stroke lol. Mine are corvette pieces. Funny how that comes across as bragging ain't it? "That's a 350 out of a corvette", but in the mid 70's, that means it was a 170hp boat anchor that had a funky distributor :rolleyes:
    Bob Lowry, -Brent-, Stogy and 5 others like this.
  2. I have actually owned 2 gennie corvette small blocks. I have sold several but only owned 2. :rolleyes:
    vtx1800, Tim, Stogy and 6 others like this.
  3. Speed Gems
    Speed Gems
    The crankshaft/rods must have the diameter journal then, maybe they'll fit you just have to weld that big gear on the crankshaft.
    Stogy likes this.
  4. Speed Gems
    Speed Gems
    And don't forget about the Volvo OMC Mercuiser engines. I've even seen a 3x2 manifold with slanted mounting pads for the carbs. I deleted the picture so I can't post it anymore.:rolleyes:
    Stogy likes this.
  5. Speed Gems
    Speed Gems
    The LG 327 in my '49 Chevy p/u has a steel crank in it.
    Stogy and Deuces like this.
  6. 1952henry
    1952henry
    Don’t know much about boats, but my dad had a 510 MF combine in the mid to late 70s. I remember him saying it had a 327. Didn’t know there was anything special about it. His had the dual straight pipes running out of the hood and along the grain tank. Made a joyful racket when started in the Quonset. When combining, if a slug went through, the governor would open her up and she barked. An uncle had a later 510 with the 350, and a 410 with the 292.
    Stogy, Budget36 and Speed Gems like this.
  7. Taboo56Chevy
    Taboo56Chevy
    They are a pretty rare crank, since LG 327s only lasted 68 and part of 69. I have 2 of them sitting on the shelf waiting.
    Stogy, Deuces and Speed Gems like this.
  8. 26Troadster
    26Troadster
    But the middle one was undrilled right?[/QUOTE]
    if i remember right no, one had two bosses and the other had three. i seem to remember one block being a tad thicker. it has been at least 32-33 years since i messed with the 400's, my old mind is not what it used to be. so take that with a grain of salt. when we looked for them that is what we looked for as well as we wanted 2 bolt mains, we ran them in what we called hogg cars on the round tracks.
    Stogy likes this.
  9. Budget36
    Budget36
    How long did GM make the small block 400? Personally, I’ve never seen one (or didn’t know if I did).
  10. Speed Gems
    Speed Gems
    From 1970 to 1980 IIRC with '70-'72 being the only years for the 4 bolt main.
    Stogy, Budget36 and Deuces like this.
  11. Hollywood-East
    Hollywood-East
    Every SBC, That has it's oilpan on, Is a 4 bolt main...
    Actual interesting fact, I had a 1955 6400 series truck, And the 265 was yellow!
    Stogy, gimpyshotrods, Deuces and 2 others like this.
  12. 05snopro440
    05snopro440
    My 1967 283 has the fitting for crankcase ventilation behind the intake manifold on the top of the block.
    I'm not sure which year that ended.
    Stogy likes this.
  13. 1971BB427
    1971BB427
    from Oregon
    I thought those motors didn't have the distributor hole in the intake? But did still have the same block as other post 1987 blocks. So if the intake and balancer is off the block they should look just like other non Opti-spark blocks, shouldn't they?
    Stogy likes this.
  14. 327Eric
    327Eric
    The LT block is different. My picture posted earlier was deleted because it showed the EFI, but is O.T. none the less. There is a gear in the back that drives the oil pump, and the block is the same under the manifold there, aside from the mounting boss for the pump drive, which looks like a distributo stub, for lack of a better description. A gm performance 4 barrel maifold can be purchased, and with some work a gen 1 manifold can be adapted, and a distributor run in the rear with a melonized gear. There is no water from the heads to the manifold. The front cover are is different due to mechanical water pump drive and reverse flow ports. A block off plate is available to eliminate the optispark. There is no way to run a traditional sbc water pump, balancer or accessory drive on one of these, in this respect it is completely different. It is an interesting, and odd beast. exhaust ports are different too. I wouldnt have messed with it, but Im a ****ker for a running 150 dollar engine. it is my hoarder mentality.
    Stogy likes this.
  15. DDDenny
    (In my quitest OT voice)
    I'll take your word on that, my wife locked the hood on her 96 Impala, said to keep my hands off this one!
    Chavezk21, Stogy and Deuces like this.
  16. 327Eric
    327Eric
    a good place too leave it. The other reason I know this, I didnt want to give up my standard bore 66 327 for this build.
    Stogy likes this.
  17. gimpyshotrods
    gimpyshotrods
    What's a freeze plug?
    Stogy likes this.
  18. squirrel
    It's a core plug that popped out when the water in the engine froze.
    I've seen it happen.
  19. gimpyshotrods
    gimpyshotrods
    And I have seen both sides of a V8 block blown out, without moving a single core plug, and all manner of other inline engines blown apart at the oil pan rails, also without disturbing a core plug.
    Forgetting to properly winterize your boat in New England has expensive consequences, none of which are prevented by calling something by the wrong name.
    X-cpe, Stogy and 05snopro440 like this.
  20. DDDenny
    Cripes, another "is it an engine or a motor" shtick!
    Bob Lowry, Tim and Stogy like this.
  21. Pass The Torch
    Pass The Torch
    What about "Fan Belt"...?
    Stogy likes this.
  22. gimpyshotrods
    gimpyshotrods
    Except it is not.
    Engine, or motor, in both cases, they are a means of providing locomotion.
    Using one or the other does not imply any different outcome.
    That argument is much like the debate between hoagie, hero, Italian, grinder, wedge, or a spuckie. In any case, order one and you get a cylindrical bread roll split lengthwise and filled with meats, cheeses, vegetables, and condiments.
    Calling a core plug a freeze or frost plug creates the false implication of function. It implies that said function is to protect the object into which it has been installed from the damaging effects of the initial expansion of water when it freezes.
    They most certainly do not do that, nor were they ever intended to do that.
    You can call a pig a duck, but you will go to your grave before you hear one quack.
  23. gimpyshotrods
    gimpyshotrods
    Accessory drive belt.
    Stogy and Pass The Torch like this.
  24. RICH B
    RICH B
    Came across a pair of these in a junkyard; thought they were pretty weird until I learned they were from a combine with vertical exhaust.
    Bob Lowry, Stogy and 1952henry like this.
  25. Hollywood-East
    Hollywood-East
    Yep... Been there!
    Drove a 59 apache back from TN., Western NY, started one morning an couldn't figure out the squeal , Yep..
    No antifreeze, game over..
    Stogy likes this.
  26. 1952henry
    1952henry
    They would make a unique cutout!
    Stogy likes this.
  27. 1biggun
    1biggun
    HMMMM vintage turbo looking set up .
    Bob Lowry, Tim, Stogy and 1 other person like this.
  28. Stogy
    Stogy
    That's seriously thorough Squirrel...perhaps the only thing I can throw in was some were blue...at least in Canada...but that was post Hamb cutoff I believe...:oops:...I see it's been mentioned...no surprise...I in the land of the know...;)
    The bolt holes for front motor mounts disappeared at some point or did they omit 1 and leave 3...I remember me and a friend either drilling a 4th or I might be mistaking that for bracket hole on the front of the driverside head...
  29. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I've seen later blocks with all or just some of the '55-'57 mount bosses drilled and tapped.
    Stogy likes this.
  30. Pass The Torch
    Pass The Torch
    My '65 327 was not drilled in the front for mounts.
    X-cpe and Stogy like this.
