baggin a 54 chevy
Discussion in 'The Hokey Ass Message Board' started by slamdpup, Sep 18, 2006.
  1. slamdpup
    slamdpup
    im about to bag my car and i was wondering about the rearend..i have a 78 camaro rearend BUT if i use that i cant run skirts with out the tires rubbing..ive heard talk about using a s10 rearend ..and also 4x4 s10 which is a better rearend...heres a run down of what im using...
    sbc 350
    350 trans
    air bags all 4 corners
    standard chrome steelies
    TCI four link
    my buddy has the same rearend (78 camaro) and his tires rub and he has the standard steelies..
    i would like to get the same width rearend as what came factory in the 54
    thanks Eddie
  2. synthsis
    synthsis
    the s-10 non 4x4 is narrower and probably the one you want to run if you are going to bag and have clearance issues. best of luck, i want to see pics of the final product.
  3. Nightshade
    Nightshade
    Why not just have the stock rear narrowed?
  4. slam49
    slam49
    from tulsa ok
    i've never read about anyone using it on here but, i am going to use a dana 44 out of a late 80's grand wagoneer, its about 58", although i don't have any disks on it yet it will be a bit wider when i do, all in all still narrower than the camero or s-10. the only draw back is its a 6 lug so i am going to redrill or get custom axles. oh i am 4-linking mine so i'm not sure if the spring perch width is the same either as a 50's chevy but perches are cheap and easy to weld on
  5. bpc
    bpc
    I used a 67 camaro rear the dimensions are exactly the same as stock, I think I could bolt the damn thing right in if I wasnt putting in a 4-link bag setup
  6. Leebo!
    Leebo!
    from Yale OK
    Keep hearing 57 chevy rearends are great for 53-54 swaps, but havent laid a tape to it myself.
    I've got a versaille disc rearend for mine(if and when i ever get to it!!)
  7. Custom54
    Custom54
    I used a S-10 4X4 rear end in my 54 Chevy, no problems at all. She's down about 6" in the back and I'm gonna go 2" more.
    I can't remember exactly but I think they are 1/2" wider or narrower than the stock ones, and they are 3:73 posi.
    The 2 wheel drive S-10's work but they are about 4" narrower and non posi.
  8. slamdpup
    slamdpup
    what year 4x4?..and does anyone know if the s10 4x4 and the blazer and jimmy 4x4 are the same?..do you run skirts on your car?...the camaro i have will work without skirts..i want to be able to use the skirts when i want and run with out them whenever..if someone could get me a measurement on the 4x4 that would be cool..thanks
  9. 53sled
    53sled
    from KCMO
    Because you can't use it with a 350 swap. It is a torque tube.
    I am using a 55 rear, exact same fit as the stocker.
    http://www.teufert.net/other/rear end dimensions.htm
    bookmark this page it could save your life. or a trip to the junkyard.:D
  10. rustypipes
    rustypipes
    from san jose
    You have many options 55,56,57 tri5 chevy, novas, s10
    There is more info at www.50chevy.com
  11. I have a '78 Camaro rear in my car too...I was able to get the skirts on, but they do rub a little. Cut 1/4" off the inside skirt lip and you should be good to go.
    Bryan
  12. PBRmeASAP
    PBRmeASAP
    USE THE S-10 REAR. Parts are everywhere. I have a 90 or 91 4x4 rear in my 54, i beleive it was 1/4" shorter on both sides....no biggie, not noticable. They are not all posi, but if you want it, you might be able to find one, or again, the parts/kits are easy to find.
    if you really need the measurements i can throw a tape on both, but i'm feeling lazy right now
  13. slamdpup
    slamdpup
    cool thanks..all i really needed was year...BUT when you get time to measure i would like to know..i know i can trim the skirts ...but when i drive the car with the skirts on the car im only gonna rasie the car a inch or so ..so the skirts would rub the tire....i want plenty of clearance without hacking up my skirts..plus 55,56,57's are kinda hard to find..plus i like the walk into any parts store to fix the problem(s10)..thanks man
  14. S-10 rears are 60", outside drum to drum....we just put one in a '50 Fleetline.
    Bryan
  15. Wasahawaiianrat
    Wasahawaiianrat
    so if a 78 camaro rear is 58'' wide and a stock 54 is 60" according to 50chevy .com why would the skirts rub?
  16. slamdpup
    slamdpup
    4x4 or 2x4?
  17. slamdpup
    slamdpup
    the 78 camaro is 61'' from outside to outside..its 58'' from inside to inside..if the s10 is 60 from out to out..then the skirts want rub
  18. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    I think the tianglated 4 bars work beter in air bag set ups,one less bar to worry about and you dont get side to side movment that SOME times 4 bars get from the panhard bar.And you get beter side to side movement out of the trianglated 4 bar.If you do use the 4 bar make sure the botom bar front rod end is above the botom of the frame rail.
  19. 4X4. I think some of the measurements you hear are rounded. The '50 torque tube I measured the other day for Roothawg was around 61.5". My Camaro rear is 62" IIIRC, but I might have rounded when I measured too. Here's another reference for rear-end widths: http://carnut.com/specs/frear.html.
    Bryan
  20. Aeroman
    Aeroman
    I got a '47 Chevy Fleetline Aerosedan and I will be using a '72 Chevelle posi rear end...4-link is off suicidedoors.com
