Projects Bought a Mercury on purpose
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Feb 4, 2023.
  1. Atomic Kustom
    Atomic Kustom
    Just notch the cross member, plate it back in. Mechanical pump seem to be less problem. By the way love where this is going!!
  2. With it squared up using the clutch linkage as the starting point, the rams horn is very close to the box.
    Could remove a little from the manifold mounting surface and clean up on the outlet with a grinder. 0D646F9B-3508-421D-B8FC-AADAFBF3D3D8.jpeg
    I’ve located these about 2 hours from the house
    hmmmm
    drdave, bchctybob, williebill and 7 others like this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup 55-56 manifolds are the fix for all those kind of problems...
  4. Gm trans mounts are perfect Ford replacements.
    alanp561, bchctybob, Papas32 and 4 others like this.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    yeah, the grease in the box will get too warm and probably leak.....
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    I remember a story from the thirties where some Indy cars had to get out of the race because the exh was too close to the steering sectors and prts grew with the heat making them hard to steer.... could you angle mill the manifold and get it to tip in at the bottom?
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    bchctybob likes this.
  8. I have access to do that.
    And thought about that.
    I don’t like this particular manifold. Bird dogin a set of late 50s with the gen mount.
    Might extend the clutch shaft 3/8-1/2 inch.
    I can cut this one on the red line, cut another clutch shaft, yellow line, and then extend the clutch shaft allowing the engine and trans to move over for box clearance.
  9. I seen those.
    The rear dump might crowd the master cylinder a good bit. Lots of stuff going on in the lower left corner. Brakes, clutch, shifter linkage then exhaust. 6A4DDCBA-F8B2-4A63-B390-19E96B071B1F.jpeg
  10. Now I know why everyone uses automatics
    Okie Pete, bobss396, Stogy and 6 others like this.
  11. Dick Stevens
    Dick Stevens
    Don't for get us old farts that used to love rowing the gears but now have bad knees so using an automatic makes the car more enjoyable to drive!
  12. bobss396
    bobss396
    I had a 396 in my last Nova stock car, the driver side exhaust manifold was close to the steering box, maybe a 1/4" away. After a few impacts on the track, I all of a sudden had close to a 1/2", problem solved.
    Moondog13, alanp561, Jrs50 and 6 others like this.
  13. Atomic Kustom
    Atomic Kustom
    I used the 265 manifolds in my '50 Ford and they worked great. Plenty of room and kept the heat away from the steering gear. I am running a 327 so I opened the ports up to help the flow. 265 manifolds should run about $100 bucks a pair
  14. One of the caddy caps had some damage.
    We started hammering those out. Should straighten out ok
    40921008-BB9A-45EE-8E03-D05D0975693C.jpeg BEF631E1-D8E3-4370-B364-21BDD419E1F3.jpeg
    a little more work then start filing.
  15. Shirts cleaning up nicely.
    Just a little more metal work. Bottom corner of the p***enger side needs a small rust repair.
  16. s55mercury66
    s55mercury66
    from SW Wyoming
    Your secret please, Shout, or perhaps All-Temperature Cheer? Wisk worked well for ring around the collar.
    alanp561, impala4speed, SS327 and 2 others like this.
  17. Paw-in-law just handed me these.
    2 p***enger side manifolds I guess.
    Ports are around 1/8 smaller.
    Purpose for this plate?
    would probably fix the steering g issue.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    that plate allows access to the choke heat source, maybe it was a result of how they had to cast the part originally, I know later there was a tube that p***ed straight thru the manifold. You can't **** exhaust fumes into the choke, it would corrode the chokes workings....
  19. Battery tray fits with these manifolds.
    too close?
    Gen mount wouldn’t work with the battery here anyway.
  20. There’s an engine way down there 7D6F1EC1-4AA1-4606-A769-885D519B8F48.jpeg somewhere
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    you may want to move the battery box, I think you will want the generator on that side, using one of those brackets they used to make for guys with headers
    Okie Pete and anthony myrick like this.
  22. It has room on the p***enger side.
    I’m going to order one of those brackets to modify.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    because that head is back further the Gen will have to stick way out past the head on that side.... up to you though, or were you talking about the batt on the p*** side?? makes for a shorter batt cable
  24. Well, the engine is offset to the p***enger side. That would make the battery tighter.
    The bracket for the alternator/gen I was gonna use as a pattern to figure out placement.
  25. Tri 5 radiator for the win
  26. wheeltramp brian
    wheeltramp brian
    Nice, those things seem to fit a lot of cars
    anthony myrick likes this.
  27. I’ll bend a couple simple mounting flanges and we’ll be good.
    Bought this radiator for the wife’s 56 Chevy. I’m gonna borrow it :):)
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    best part is that every tri five chevy I have ever had needed nothing more than a stock 4 blade fan and no shroud and they all ran cool......
    bchctybob, Tman, Okie Pete and 4 others like this.
