Hot Rods Who is your "Go to" manufacturer of steel wheels?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Feb 6, 2023.
  1. SDS
    SDS
    Stockton Wheel Service
  2. LSGUN
    LSGUN
    from TX
    Do the original 40-48 ford/merc caps fit on the wheelsmith 40-48 style wheels?
  3. mink
    mink
    from CT
    I will save you all some trouble. These hoops are too small on the I.d. , I had to skim the centers and had planned on reinforcing the centers with added material. I bought a ring roller and rolled a .5x 1/8 strip of steel. strip were to be welded to the center and riveted to hoop. Things got busy and that’s where I stopped.
    If the wheel balanced within reason , then this may be feasible, but there’s a bit of work needed
    if I recall there was a kid offering rehooping services here but I’m not sure if he did something similar or was able to source a supplier to make the properly size hoop. May we could find a hoop supplier and pool some cash up to run the minimum lot size
  4. warbird1
    warbird1
    I pulled a pair of Wheelsmith 16 X 4-1/2 Vintage wheels that I purchased from Speedway out of the box this morning. An original '40 V/8 hubcap snapped right on...
    AHotRod, RAK and Roothawg like this.
  5. LSGUN
    LSGUN
    from TX
    Good to know, thanks.
    seb fontana and Roothawg like this.
  6. PONTNAK123
    PONTNAK123
    wheel smith great products fast service
  7. VintageSpeed83
    VintageSpeed83
    from NC
    so the vintage wheels sold through speedway are manufactured by wheel smith? And the OG caps work bc it says right on the speedway website the OG caps won’t work.
  8. jimmy six
    jimmy six
    Wheelsmith makes their own caps. I wrote on the back of mine on my OT pickup. “Please put back on.. this cap won’t fit your Ford wheel”. CA7B1223-FD42-4AF1-8E73-C5865388C58C.jpeg
    INVISIBLEKID likes this.
  9. Phillips
    Phillips
    Off the shelf 16" aftermarket ID is 13.5". What is the exact OD of the OEM Ford centers?
    Elcohaulic likes this.
  10. xtralow
    xtralow
    Jimmy came up with these (inserts) for smoothies.... Jimmy had creative idea's and made some nice reverse style and other wheels.
  11. warbird1
    warbird1
    Yes, the pair of wheels I received from Speedway last week were in Wheelsmith boxes; bare metal. And a pair of OG 1940 Ford Standard wheel caps snapped on. Maybe just a fluke... but the caps were on there tight enough that they're not going to come off while on the road. Just primed the wheels today; can get pictures after it dries.
    VintageSpeed83 likes this.
  12. warbird1
    warbird1
    Pictures of the wheels and hubcaps... having read that Wheelsmith wheels need to use their own hubcaps I was surprised when an original Ford cap fit
  13. lemondana
    lemondana
    from Lincoln NE
    What is the best way to remove chrome from old wheels so I can have the centers rehooped?
  14. Clydesdale
    Clydesdale
    Get a Chrome Shop to strip them, any other way just isn't thorough enough
    lemondana likes this.
  15. VintageSpeed83
    VintageSpeed83
    from NC
    Ok. Thanks
  16. Gary Addcox
    Gary Addcox
  17. Gary Addcox
    Gary Addcox
    The centers are more heavily stamped. Is nobody running the vented, early steelies with inside nubs anymore ?
  18. Gary Addcox
    Gary Addcox
    Yes. Make sure the wheelman knows you want the nubs on the inside of the center. I forget the model number, but they are usually referred to as steelies (vented) while the unvented are called smoothies.
