Technical 51 chevy v8 swap issues
Discussion in 'The Hokey Ass Message Board' started by LarsL, Mar 24, 2023.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    so your car has a rack and pinion steering and an aftermarket column? are you sure that you are comparing apples to apples here?
  2. 51pontiac
    51pontiac
    from Alberta
    I have been running with that manifold since the early 90’s with no problems. These pictures might help you visualize how the exhaust needs a little jog built into it to provide drag link clearance at full lock. 3936F6D6-6BAB-40B2-BB7F-37056658911C.jpeg 3DC2B389-FEBF-4C0B-8703-963BF5AA08E3.jpeg
    '28phonebooth likes this.
  3. 51pontiac
    51pontiac
    from Alberta
    It was completely stock front end, steering and brakes with that manifold until this year. It is actually the factory column cut down to work with the off topic stuff.
  4. LarsL
    LarsL
    from Norway
    This is much help. Everything else fits good. Just the gear shifter that needs moved up the colum tube.
    Im shure most people think that this manifold will sound bad and such but more important to make everything fit than move over the engine and such.
    51pontiac likes this.
  5. jimmy six
    jimmy six
    I forgot how much monkey motion was on the stock steering geez..
    As a second thought you will loose your emergency brake and need to make it work from the left side of the dash. The original car had a closed drive line and you need to work around it.
  6. 51pontiac
    51pontiac
    from Alberta
    All I know is that this worked well for me and the price was right. I don’t know what motor mounts you are using so that could possibly change the position of your engine forward or back a bit but for me, using Ch***is Engineering motor mounts and transmission mount kit (slight cutdown of stock crossmember) , everything fit nicely.
  7. Acres
    Acres
    from Sweden
    I modified the shifter box like some previous, locked it inside so it only one arm works, removed the other, on the photo i havent cut the arm yet but before I mouned it i cut it, otherwise it bumped against the head.
    Bought a adjustable shifter linkage from lokar, easy fix and works like a charm
    '28phonebooth and 51pontiac like this.
  8. Budget36
    Budget36
    May not be the look you want, but how about a floor shift selector with a cable?
  9. LarsL
    LarsL
    from Norway
    I like to keep the colum shift handle.
    The E brake most likely will be floor mounted.
    jimmy six likes this.
  10. Budget36
    Budget36
    I get ya, I was offering a different approach to work around the issue without much ado.
    I too, in a cruiser would rather have the column shifter.
    LarsL likes this.
  11. Acres
    Acres
    from Sweden
    On my Chevy they have mounted an E brake pedal version, most likley from a 60-70s car, mounted to the kickpanel, looks better than a floor mounted i think, I like the floors clean from stuff, thats why i removed the floorshifter and modified it back to column shift
  12. LarsL
    LarsL
    from Norway
    Do you have any pics?
  13. Acres
    Acres
    from Sweden
    No but i can fix some tomorrow, it aint so advanced, they have just mounted the whole mechanism, but it works great
    LarsL likes this.
  14. 325w
    325w
    Rod an custom did a series on V8 in 53-4 Chevy. Full,of good ideas. I gave my copies away
  15. 51pontiac
    51pontiac
    from Alberta
    My e b D3E01629-95DF-453D-AF2C-9C89ED9AD25B.jpeg rake was always on the left side of the dash so no modifications required inside the car. That might be the “Pontiac” part as the dash is a Pontiac dash.
    alanp561 likes this.
  16. Acres
    Acres
    from Sweden
    The setup wont win any prices but it works, the mechanism is simply just bolted to the kickpanel.
    underneath its matched up with the original brake linkage.
    Should be quite easy find a brake lever this model, the most of them have the same size and function.
    But if i had done this i should have tried modify the original e-brake lever/handle and moved it to the left side of the steering wheel, (something like the previous post)
  17. samurai mike
    samurai mike
    I did it a little different, I IMG_0331 (1).JPG IMG_0326 (1).JPG cut off the stock arm and made a new one on the drivers side of the column. i used a ford windstar shift cable and made custom brackets to hold it top and bottom. i also used an old header flange to space the manifold out to clear the dipstick.
