Technical My tale of woe (Stromberg 97 related)
Discussion in 'The Hokey Ass Message Board' started by Jethro, Mar 31, 2023.
  1. Jethro
    Jethro
    So I've been waiting for the fuel line fittings for my carbs. They came in the mail yesterday and I put them on. They fit good , look good, the time is now to start this thing. I put a jumper wire on the fuel pump and filled the carbs and looked for obvious leaks....seems good. Time to crank , first turn it flashes and keeps running....it's idling! A few adjustments and it seems to be running pretty good. I let it get up to temp and shut it down to tighten any loose nuts or hoses. The rear carb had a small wet spot on the manifold so I checked to see if the jet plugs were loose and gave them a snug. That must have been it.
    Satisfied with myself I went in the house. Today I went out and tried to start it cold ....vroom! first crank runs like it should. Shut it down and theres still a little fuel around the back carb. Maybe the inlet is a little loose. I put my wrench on it to give it a snug and SNAP!!! Busted the body of the carb....it had a small crack that I didn't see....you can see the black in the photo. I SAID THE BAD WORD....IF YOU SEE KAY!!!!
    So I need a 97 body or whole carb. It was nickle plated and looked really good DAMMIT!
    Gonna have a glass of Crown Royal and sulk.....WOE IS ME!
    29Roadie, hrm2k, ottoman and 2 others like this.
  2. flamedabone
    flamedabone
    Stupid old cars, I hate 'em.
    -Abone.
    rod1, '28phonebooth, OzMerc39 and 9 others like this.
  3. mad mikey
    mad mikey
    Damn, that sucks.:( I feel your pain.
    hrm2k and J. A. Miller like this.
  4. 57 Fargo
    57 Fargo
    Well shit…
    hrm2k likes this.
  5. Rehpotsirhcj
    Rehpotsirhcj
    Ouch. Good thing 97s are cheap. :)
  6. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Ahh sheeit.
    Just know, unlike the crap I' ve broken lately, it wern't your fault.
    hrm2k likes this.
  7. RMR&C
    RMR&C
    from NW Montana
    Dang Jeff, that really blows. Sorry for your troubles. I might have an extra parts carb if that helps, but it wouldn't be plated
    Tow Truck Tom likes this.
  8. Jethro
    Jethro
    Hi Scott I can use a good body , my base and airhorn are in good shape . It doesn't matter about the plating....beggers can't be choosy. It's the back carb , you don't see much of it.
  9. 37slantback
    37slantback
    I have some crap from 1973 down here in Spokane
  10. Budget36
    Budget36
    That would make a wall hanger I’ve never seen before. You could make up all sorts of stories about how it happened as you were just cruising down the road. ;)
    OzMerc39 likes this.
  11. I have a large milk crate full of similar carburetors. Apparently this was a weak area of the carburetor body, or somebody with too much arm power.
  12. Fitnessguy
    Fitnessguy
    I hate it when shit breaks
  13. theHIGHLANDER
    theHIGHLANDER
    Isn't every part now available in a "new and improved" way? Not sure what a bare body would cost but its worth a look since that's an Achilles heel. Might need to top off that Crown Royal...to celebrate?
    Budget36 likes this.
  14. krylon32
    krylon32
    from Nebraska
    Why does anyone screw around with these Dam old cars?
  15. Jethro
    Jethro
    Well , I am known to be "ham fisted" but it wasn't the case this time.....still mad grrrrrrr
  16. Fortunateson
    Fortunateson
    Well bugger! With the HAMB this will soon turn into a minor inconvenience. Good luck...
  17. Jethro
    Jethro
    I've already got stuff on the way from Spokane....thanks 37 slantback
    RMR&C likes this.
  18. 37slantback
    37slantback
    No problem Jeff. Should go out today.
  19. You could wittle and glue a piece of plexiglass over the hole then sell it at the next swap meet as having the "very rare float window for ease of setting float level" option. :rolleyes:o_O
    Budget36 and 37slantback like this.
  20. I'll bet the new fuel lines look really good, though. :eek: o_O
    Budget36 and mad mikey like this.
  21. RMR&C
    RMR&C
    from NW Montana
    Glad you found a replacement. I don't have one anyway...
    Or at least can't find it. o_O
    mad mikey likes this.
  22. Jethro
    Jethro
    No worries Scott , thanks for looking!
    RMR&C and mad mikey like this.
  23. saltracer219
    saltracer219
    I also have some main bodies if you need one.
    Stovebolt, Budget36 and mad mikey like this.
  24. Stovebolt
    Stovebolt
    If the post creator does not require some of your main bodies, I need some to replace the one that came off my coupe due to a stripped thread in the needle and seat hole, which, under he electric fuel pump pressure gushed fuel all over the header in my coupe until I managed to turn off the pump, and close the fuel tap when it stalled in traffic 2 weeks ago
    saltracer219 likes this.
  25. Jethro
    Jethro
    I have some bodies coming my way via Spokane thanks to 37Slantback so go ahead and strike a deal with saltracer219...cheers!
    Stovebolt likes this.
  26. 29Roadie
    29Roadie
    When you said it broke I thought that it was just where the fitting screwed in for some reason. Wow, ya that's just a little bit worse. That sucks! Someone's going to have a nickel plated desk lamp build thread soon I think.
