Technical Steering box lube?
Discussion in 'Traditional Hot Rods' started by joel, Oct 5, 2013.
  1. joel
    joel
    I'm in the process of rebuilding my saginaw 525 manual box and my old Motors says "medium all purpose grease". Does anyone have something more specific? Thanks
    crazycasey likes this.
  2. tfeverfred
    tfeverfred
  3. sdroadster
    sdroadster
    I put 90 weight rear end lube in mine, it became much smoother and easier to steer.
    dana barlow likes this.
  4. joel
    joel
    I was wondering about using heavy gear lube. fred , that's the grease I would use if I use grease. I was thinking that grease might not get into the ball/screw ***embly.
  5. tfeverfred
    tfeverfred
    Have you seen what the factory grease looks like? This is what some use. I get what you're saying. What I'm saying is ignore what you THINK and use what OEM's KNOW. It must work, otherwise they wouldn't use it. Those college guys get paid large to know what works. I trust most of them.
  6. Dusty-NZ
    Dusty-NZ
  7. yblock292
    yblock292
    have heard STP is good, haven't tried it.
    sko_ford and desotot like this.
  8. gkgeiger
    gkgeiger
    I read that on the Barn and when I re-sealed my '39 box I used it. Seems to work good.
    sko_ford likes this.
  9. Morrisman
    Morrisman
    from England
    I put a grease ****** in my Corvair box, so I could pump fresh grease through occasionally. It was designed for oil but it would leak out now....
    jimmy six likes this.
  10. B Ramsey
    B Ramsey
    Every box I have is filled with John Deere corn head grease. love it. No leaks.
  11. squirrel
    There's a new Tractor Supply store opening in town. First thing I'm gonna do when they open is see if they have corn head grease.
    Gear oil is too liquid. Normal (NGLI #2) grease is not liquid enough, it doesn't flow. You need a #0 grease.
    dumprat likes this.
  12. hoop98
    hoop98
    from Texas
  13. Finn Jensen
    Finn Jensen
    GM "Approved Steering Gear Lubricant" is P/N 1052182. It comes in a large plastic tube that you squeeze into the steering box like toothpaste. It is certainly thicker than gear-oil, but it is nothing like grease. Pretty easy to use.
    Unfortunately, GM has discontinued it some time back. But there may be residual stock around. I located some in 2004 by calling parts departments of Chevy dealers around the country. Found some at a dealer in MA and they shipped four tubes to me.
  14. joel
    joel
    Thanks for all the input. I'll probably go with the grease, but I' m checking out a couple of gear oils.
  15. stimpy
    stimpy
    try Yoder Oil in Elkhart I used to deliver oil and grease to them , they might have what your looking for .
  16. V8-m
    V8-m
    from Alaska
    What about CV joints grease ( Moly type - grey colour). It should be fine i think.
  17. willys36
    willys36
    I make my own concoction; I mix moly axle grease with just enuf rear end 90W to make an almost liquid mixture.
    6sally6 and anothercarguy like this.
  18. BJR
    BJR
    John Deere corn head grease is the stuff to use. It acts like a solid when not being moved. So it doesn’t leak out when your car is sitting. But turns into a liquid when moved, like when you turn the steering wheel.
    vtx1800, sidevalve8ba, Tman and 2 others like this.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    I wonder what @joel ended up using 10 years ago when he started this thread?
    Outback, Blues4U, 427 sleeper and 4 others like this.
  20. 1952henry
    1952henry
    Link didn’t work, but Tractor Supply has Cotton Picker Spindle Grease. It is “00”. Same specs as PennRite, but doesn’t have a cl***ic car on bottle so it is only $5.99 a quart rather than $20-22.
  21. BJR
    BJR
    HA HA Totally missed that.
    Outback and V8-m like this.
  22. richard crow
    richard crow
    use what the people who designed the box said to use sae 90
  23. Still a valid question that seems to pop up every few months. Corn Head grease is always the right answer!
    vtx1800 likes this.
  24. Except the ratings have changed over the years. There was a great thread on this a few years back. I will see if I can dig it up and dust it off.
  25. '29 Gizmo
    '29 Gizmo
    from UK
    My go-to is Penrite Cl***ic Oil Semi Fluid Grease Steering Box Lube. Stopped my stock model A box leaking!
    Outback likes this.
  26. joel
    joel
    I used 250 weight gear oil to start but before I even seriously drove the car, I found the sector shaft seal wouldn't hold it. IIRC I asked Borgeson what they use. I believe, at that time, they would rebuild GM boxes. This was at the show in Louisville and one of the people said that they thought a grease was used.
    2020,I think it was, I drilled a bolt to replace one of the top cover bolts and added a grease zerk to the bolt. I used a medium bearing grease to supplement the oil (however much was left).
    At this time ,I'm planning on getting a new 24:1 525 from Borgeson. I don't actually know that my box is bad, but the new one should make the car steer easier.
    Moriarity likes this.
  27. joel
    joel
    I plan on using the Corn head grease on my 41 p/u stock steering box rebuild. In the recirculating ball-screw in the modern boxes, I wasn't sure the grease would adequately lubricate the ball screw.
    SS327 likes this.
  28. dart4forte
    dart4forte
    from Mesa, AZ
    The guys that ran vintage British cars with lever shocks ran STP.
  29. squirrel
    That's the problem, in a nutshell. The "viscosity" of grease is called the Grade Number. Most grease is Grade #2, which is too thick to flow. The grease you want is Grade #0 or #00, which will flow, but not run out like gear oil.
    427 sleeper and Blues4U like this.
