Hot Rods 33/34 Ford axle in a Model A question
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Mar 31, 2023.
  1. harleycontracter
    harleycontracter
    I want to use a 33/34 front axle in my model A to lower it a couple inches. What do I have to change out to do that? I just want to lower the front and rear a bit . Leaving the rest pretty much stock for now .
  2. WTF really
    WTF really
    I used a 36 and just had to put a washer in to make up the difference in the wishbone space.
    mad mikey and irishsteve like this.
  3. Hitchhiker
    Hitchhiker
    33-36 is the same axle. Different wishbones. Model A perch width is 2-1/4 inches and 33-36 is 2 inches. It should be noted that functionally a 32 heavy and 33-36 axles are exactly the same. 32 heavies just have a different forging. The king pins, perch pin holes, and drop are all in the same locations.
    Probably the bigger question is the brakes. Do you have juice or mechanical?
    mad mikey likes this.
  4. panhead_pete
    panhead_pete
    What brakes are you running?
  5. '29 Gizmo
    '29 Gizmo
    from UK
    You can get 2 inches lower with the stock axle.
  6. harleycontracter
    harleycontracter
    Was going to keep stock for now. I have everythink to male it an AV8 but not ready to Txs
  7. harleycontracter
    harleycontracter
    I have a reverse eye how would I increase the drop from that easily for now
  8. '29 Gizmo
    '29 Gizmo
    from UK
    I removed a spring leaf to drop it further. You can also get the larger leafs re-profiled flatter.
  9. j ripper
    j ripper
    from napa ca.
    E7892D07-1E5B-4207-AF29-F8074369ED6C.jpeg D4333D97-B151-4DE1-902B-676CFBBB4E55.jpeg 9862C28F-DA45-41CB-A10E-6D53A8548BB7.jpeg 33-36 axle
    32-34 spindles.
    32-34 perch pins bushed to accept model A shackle.
    1/4” spacer for wishbone at axle.
    Reverse eye spring. Remove leaves to taste.
    Use existing kingpins and brake bits.
  10. Blues4U
    Blues4U
    from So Cal
    ^^^ Nice!
  11. harleycontracter
    harleycontracter
    mad mikey and 51 mercules like this.
  12. j ripper
    j ripper
    from napa ca.
    Here is the car today with an AV8 makeover.
    Dannerr, mvee33, Packrat and 11 others like this.
  13. DG Racing
    DG Racing
    j ripper nice car
    what is your tire size ?
  14. j ripper
    j ripper
    from napa ca.
    Thank you! 700 rear. 450/475 front.
  15. Stovebolt
    Stovebolt
    My coupe has a reversed eye flattened spring, and a 33-36 axle, 32 spindles and brakes.
    The rear has a T spring.
    18" 32 rims, 475-18 front and 600/650-18 rears.
