Technical Vern Tardel Steering Box Wedge
Discussion in 'Traditional Hot Rods' started by mantuajohn, Nov 14, 2020.
  1. Mr48chev
    Just thinking that for 100 bucks I can cut a batch of those spacers out of a piece of s**** steel plate, drill the holes to match the box and sit on my stool and grind on them with my angle grinder until I have one trimmed up to fit the way I want it to.
    I remember the article that showed how to do it the way NealinCA showed and that always was the way I thought of doing it. I'd have to prevail on my buddy with the mad metal working skills for that though.
  2. Pete1
    Pete1
    from Wa.
    Many people don't have the tools but if you do, a kickout on the frame works much better than a plate and if you need a bit more header room you can build that in at the same time.
    Looks like factory then.
    joel and dmar836 like this.
  3. On the Model A jalopy I'm working on, I used a front axle wedge for a large truck and just put the holes where I wanted. I could also slide the wedge backwards and forwards to get the column centered where I wanted. Gene.
    Outback and alanp561 like this.
  4. patsurf
    patsurf
    with full hood?
  5. Pete1
    Pete1
    from Wa.
  6. Raisor
    Raisor
    I made a bump out on the frame rail of my 33. I did trim the flange down to put the column at my desired angle. Disregard the junk mock up draglink and the unbent pitman arm.
  7. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Kevin;
    I understand. If possible, I just would rather not deal w/bad business(es) - if I know who to avoid. & yes, some are big names, & since they're rarely named, like the Energizer Bunny, they keep going... It's a Problem everywhere, & sadly, getting worse. I've had a few friends fill me in, names & why/what happened - privately, but mostly that's a fluke & being in the right place/time for the discussion. I get it.
    Marcus...
    Unkl Ian likes this.
  8. V8-m
    V8-m
    from Alaska
  9. dmar836
    dmar836
    Casting aside, most of the Henry castings I've played with have welded beautifully with ER-70. (#limitedexperience)
    D
  10. NealinCA
    NealinCA
    I use 312 SS rod most of the time. Sometimes silicon bronze.
    This was 312. You can see the slight color difference in the weld ring
    skip65, V8-m and dmar836 like this.
  11. V8-m
    V8-m
    from Alaska
    Thanks @NealinCA
    I just made my own flange. The center hole is a little smaller but is cut straight and will be enlarged with correct angle.
