Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. drtrcrV-8
    drtrcrV-8
    Marty : Interesting length rear suspension arm you are showing... Does it act like a "torque arm", being that long?
    Boneyard51 likes this.
  2. Marty Strode
    Marty Strode
    I don’t think it acts like a torque arm because of all the weight that’s on it. But it does allow some suspension travel, with maximum set back of the engine to increase weight on the rear wheels. The salt can be rough these days.
  3. Just Gary
    Just Gary
    Cotton balls are great for masking off kingpin bushings, when spray painting spindles.
    And you can stand them up in empty peanut****er jars.:)
  4. DDDenny
    I never bought a set of transfer screws, the few times I needed them I made "get by's" as needed, after getting off the shop floor as a machinist I ran the toolroom, apparently they were more popular for home projects than I realized as I needed to order them for the shop fairly regularly.
  5. Atwater Mike
    Atwater Mike
    Love these transfer punch screws!!! I used some of the standard 'transfer punches' to fab a quick side-motor mount for my flatheads. DANGED if I didn't miss one of the 7/16" hole centers (front of mount, rears are 3/8")
    I rat tail filed for 20 minutes to convert that hole to a 'slot'... 3/8" plate, Grrrr!
    Balljoint, alanp561, drdave and 2 others like this.
  6. DDDenny
    Mike
    A dog is not (a) mans best friend, the rat tail file is, now where did I put that cardboard!
    Boneyard51, drdave and Six Ball like this.
  7. In 1974 we called them Transfer Punches. You could even make them yourself, and drop them in...
    They were super helpful when you needed to precisely mark the places to drill for bolts.
    Dial in the ****tershield, clamp the bellhousing to leave marks, remove, drill holes thru the "punch" marks, bolt on the housing, dial in again, tighten, then drill for dowel pins to keep the precise alignment.
  8. Six Ball
    Six Ball
    from Nevada
    This one will work too & is a good tip on its own!
  9. Lone Star Mopar
    Lone Star Mopar
    Just to touch back on these file cabinets yall mentioned on this thread awhile back. Ive got a few now & since I like anything possible on casters, I started putting these cheap furniture dollies under them and it works great. The capacity & strength on these are great. Ive got em loaded w everything in the locker twice as big and still have room & can still roll it on this cheap dollie. 20230405_115508.jpg 20230405_115508.jpg 20230405_115520.jpg 20230405_120444.jpg
    Bob Lowry, brEad, Hamtown Al and 7 others like this.
  10. Kentuckian
    Kentuckian
    Ever miss something important because you let time get away from you? Setting at my computer the other day I missed the start of a show because I was too involved in an article I was reading. Well that will not happen again. I just purchased a one hour timer in the kitchen section at Walmart for $4.98. Simply set it for however many minutes till something important needs to happen and continue with what you are doing until...the alarm goes off.
  11. impala4speed
    impala4speed
    Yep, same thing happens to me. I use my cell phone timer.
    65pacecar, brEad, vtx1800 and 2 others like this.
  12. vtx1800
    vtx1800
    I'm with @impala4speed and use my cell phone to "remind me" to take the paint out of the shaker, turn the oven off while powder coating, move the sprinklers, and lots of other tasks, it's so easy, push the ****on for just a bit and tell Siri the number of minutes you need:)
    brEad and impala4speed like this.
  13. Six Ball
    Six Ball
    from Nevada
    I just use the alarm clock because if I'm missing something it's usually because I'm asleep.
  14. j hansen
    j hansen
  15. j hansen
    j hansen
    Thank God that I am ambidextrous.
  16. LOST ANGEL
    LOST ANGEL
  17. Six Ball
    Six Ball
    from Nevada
    Don't get the metric vice grips mixed with the standard ones. They are tough to sort back out, especially the the right & left handed ones are in the mix.
    alanp561 likes this.
  18. Marty Strode
    Marty Strode
    Allen bolts, knurled for vice grip torqueing !
  19. Marty Strode
    Marty Strode
    This has probably been shown before, this is how I hang to small steel parts while belt sanding, using a mop disc and a wire wheel. A magnet work well. IMG_0106.JPG IMG_0107.JPG IMG_0108.JPG IMG_0109.JPG
  20. spanners
    spanners
    I wish I'd of thought of that. I might have gloves with less ground fingertips. Thanks Marty.
  21. alanp561
    alanp561
    I'm covered for just about any contingency, Metric or SAE, with my adjustable spanner/wrench.
    Six Ball likes this.
  22. Fortunateson
    Fortunateson
    I see that that wrench is the automatic Imperial/Metric type according to the handle...
    clem, alanp561 and Six Ball like this.
  23. 1946caddy
    1946caddy
    from washington
    Couldn't you use a transfer punch that just fit the hole ?
  24. alanp561
    alanp561
    You're right, my bad. Last reference to anything "Imperial" I can remember was in Star Wars.
  25. Marty Strode
    Marty Strode
    I have a valve cover on the wall, that has Imperial stamped in it.
  26. Six Ball
    Six Ball
    from Nevada
    Make a helmet out of it! You'll look cool. :eek:
  27. overspray
    overspray
  28. swade41
    swade41
    from Buffalo,NY
    Now this isn't for precision work .... unless you have a perfectly flat table, perfectly flat hole saw and a perfectly straight jig to run your piece through.
    But if you just need something milled for clearance then this is your hack, it's a little trick setting the depth but multiple light p***es usually works pretty good.
    X-cpe, brEad, R A Wrench and 18 others like this.
  29. That looks good.... Show us the finished part, please.
    swade41, Six Ball and 54delray like this.
