Not much to report but its a little bit here and there! https://www.jalopyjournal.com/forum/threads/slow-and-poor-37-buick.1100567/
Last car I had I put Flowtech Red Hots on it, about a 18" gl***pack. Droned like hell inside until I ran over the axle pipes and out past the rear bumper, then it was only loud when you mashed on it. The Lincoln has a set of those Flowmaster knockoffs, it sounded OK with the SBC, well, really sounded better at idle than going down the road to me. Going to see how they sound with the SBF, if they're not up to snuff for my ears, I'm going to try and find something else. My problem is the knockoffs have that stupid offset design, pipe goes in one side and comes out the other, so it will mess up where my tail pipes run, I'll have to have some kind of Z to get them back in the same place if I use a straight through muffler like a gl*** pack. May just have to leave them or find some of those shorty turbo style muffs that are too quiet for me....
Gl*** packs sound cool But they say look at me Mr policeman and give me a ticket I learned to keep my stuff quite.
Porters make a steel pack to replace the offset turbo style mufflers. I put them on my ‘41 p/u and fit perfect in the place of the old 70’s generic turbos. That’s the good thing about packs, you can go short for loud and long for quiet. You can also play with placement to adjust the tone.
I used to run them on my 56 Ford. A yblock with gl***packs has a unique sound. Now I have them on my 56 Chevy but without tailpipes and it sounds different,louder and deeper. I bought some for my 34 truck but I don't think I will run them, I just got them because they were cheap and used them just to break in the camshaft. Oh, I noticed something printed often about exhausts...... quiet and quite are totally different in meaning.
I've got a pair of original NOS Smitty's I bought in the 80's on my 55 Olds, but have run Brockman steelpacks on all the customs I've built since then. They sound the best!
Hello, When our stock mufflers were not sounding too good, despite the big 348/280 hp Impala motor, we went on a search for some different ones. We heard all of the stories of the gl***packs, tube mufflers and less restrictions for better flow, etc. One of my friends had a 56 Chevy and put on some standard gl*** packs from a muffler shop. They did make some odd ball noises after acceleration. I wanted performance, but no popping or backfiring. My dad’s friend in Los Angeles said to come up to his garage to pick up some mufflers he had. My dad had told him that we were looking for some performance mufflers. When I arrived in Los Angeles, he had two sets, a pair of tube style truck mufflers and a pair of Corvette mufflers from the factory. Now, that is a problem. Having heard plenty of Corvettes 56-61 in all stages of modification, the sound was pretty cool. But, the only truck mufflers were the stacks we used to see going up the side of the cab. So, which ones were going to work the best? They would both fit under the car without any road s****ing motions. The style and straight through pipes were much better than stock. Jnaki We finally decided on the Corvette, tube style mufflers. We brought them home and had our local muffler shop add them to our exhaust system. At the first installation, we had to leave a short down curved end on both tube mufflers. The shop had to make the rest of the custom rear exhaust system within the week. So, we rolled out of the shop for a week of cruising and racing with the short and loud mufflers only. Did they improve the sound and acceleration? Definitely, the sound improved with the short interim down tips. Upon acceleration at the local drive in back alley, it did make a difference. When the final complete exhaust system was ready, the “Corvette” mufflers’ sound made a huge difference over the stock system. It was time well spent. The E.T. time slips showed an overall lower time than with the factory stock exhaust system. It still qualified for the A/Stock cl*** compe***ion.
Gl*** or steel packs installed backwards so they do almost nothing, got that on my 425 nailhead 29 roadster and my 350 sbc in my 39 Ford tub and 51 Merc, sound great. If you get a ticket, stuff a couple of br*** pots and pan scrubbers up the pipes with a cotter pin to keep them in, get inspected, pull the cotter pins out hit the gas, pot scrubbers come flying out. put them away till you need them again. JW
I still use Thrush Cherry Bombs and just chop the case down to whatever size I want and weld them back together again. The ones on my '57 are about 12" long and 2.5" in and out
Blowmaster 40's are NOT!! a good sub for glas packs. "They-say" Flowmasters are some of the MOST restrictive muffz out there(including stock replacement mufflers)! I can tell the diff when I cap-up my headers and exhaust thru the muffz! Gl*** packs are still sold in auto parts stores...they're just called something different. Usually three types at Poop Boyz (and others) Turbo........Chambered...Straight-thru. Straight-Thru type are the old gl*** packs. What's that one muffler Mario Andretti likes to advertise?? Its a "gl*** pack"(with a big price) Hope this helps! 6sally6
^^^^ I have a pair of those ^^^^. The boxes are long gone, but they are unused. Probably never get used. The 51 Bus Coupe had a mild 350, LT1 Cop Car exhaust manifolds, and 36" Cherry Bombs into full length exhaust to the rear bumper. I am Butch/56sedandelivery.
Had Smithy's on my flathead because some commented they were perfect for a flathead... obviously I have a different opinion of "perfect"... so 2 lengths of pipe in place of the Smithy's solved the issue & now it sounds "perfect"
After walking around the MidAm street rod nats, with my dad, and after getting his 34 sedan back on the road, which has long gl***packs on it, I went home and cut the turbo mufflers out from under my 40 coupe. Replaced them with some 22" Cherry Bombs, because I didn't want it to sound like every other car that I heard that weekend. The stake truck has a set of Walker 24041 14" bodied gl***packs on it, with the pipes ending just past the back of the frame. Quiet enough, at speed, to have a conversation in the cab. In snorts and pops pretty bad, on the driver side, because I had to raise the latest engine swap up too high to get a good fit between the exhaust manifold and the exhaust pipe. I keep blowing out the donut gasket.
I have Thrush gl***packs, 26 inch overall length on my 51 F1 that is a daily driver. Tailpipes are 2 1/2” and run all the way to rear bumper. Engine is a 289. No noticeable cab noise at normal speed and acceleration with windows up. But a good rumble upon fast acceleration. Sent from my iPad using H.A.M.B.
Hey P, They were listed as a 61-62 Corvette Muffler online. They were not the exact ones we put on since it was way back in 1961 when I got my Corvette mufflers from my dad's friend in Los Angeles. The sound underneath my 58 Impala was so much better than stock. The motor was always sounding good, but after the whole exhaust system was complete, it was enjoyable for miles and miles of cruising around So Cal, during those teenage years. Jnaki I am sorry that those apartment dwellers behind Grissinger's Drive-In restaurant got the brunt of the acceleration noise down that alley. But, it sure impressed me and everyone else. Also, there were no tickets for loud noises from any CHP or the local police. Of course, we all knew how to raise the RPM to find that sweet spot of low noise from the exhausts. These Corvette mufflers were still on the Impala when I sold that car in 1965. So, at least 4 years of sweet exhaust noise and performance from those mufflers.
Ya I agree had walker continentals on my 69 chevelle back in 1980, long gone. I run smittys on my edsel mounted at the back. I plan on cutting off the turbos and installing gl***packs on my gto. My hot rod build will have gl***placks cant beat the sound
Purple Hornies with full exhaust was the best sound I have had on a car, plan on running them on the three window coupe this summer.
