Projects 1949/52 chevy sedan clutch linkage
Discussion in 'The Hokey Ass Message Board' started by buick bill, Jun 14, 2021.
  1. buick bill
    buick bill
    from yreka;ca
    not sure if i should put this here, but, im trying for max exsposure. just got myself in to another project . a 52 fleetline and im missing a piece of the clutch linkage .its the L shaped off set rod adjuster that goes to the clutch fork. 0.787 . if anyone knows of one or where it can be purchased please let me know . thnx bill 10628933735_97611c94c2_c.jpg
  2. F-ONE
    F-ONE
    from Alabama
    You can make that...
    ems customer service likes this.
  3. Doublepumper
    Doublepumper
    from WA-OR, USA
    I just did a quick check and found one on eek bay.
  4. buick bill
    buick bill
    from yreka;ca
    thnx for your faith f1 .you might be right ,but id rather pay $20.oo than re invent the wheel. thnx double bumber ,the only one i found on the ech channel says its for a truck ,but sure looks the same so i offered $15.oo finger crossed . i figr someone is repopping them . is a wear item ??
  5. Doublepumper
    Doublepumper
    from WA-OR, USA
    Yes, they will fit the cars also. Reading the listing, it states the specifics concerning them.
  6. buick bill
    buick bill
    from yreka;ca
    thnx .sure looks the same , or close enough for a start !
  7. Bob Lowry
    Bob Lowry
    They are the same and many years will interchange.
  8. buick bill
    buick bill
    from yreka;ca
    thnx for the replies . should be here today . see if it will work
    VANDENPLAS likes this.
  9. jimmy six
    jimmy six
    They are flat on the lower side. The fork has a flat to match it….
  10. Nostrebor
    Nostrebor
    The truck one will work. I have one on mine.
  11. buick bill
    buick bill
    from yreka;ca
    my car has a 77 ,i think ?!250 integrated head and 3 spd syncro. so like i said , ill see if its close . i think it will work with minor mods.. also looking for the best dual master conversion. it dosent look like i have a rebuildable stock cyl. so i guess its a good time to add some safety upgrade . or just wear a helmet !
  12. RMONTY
    RMONTY
    I built a bracket using the front of the original master cylinder. Got the idea from a thread here on the HAMB. It took a couple hours and a few s****s of steel I had laying around. It works quite well it seems. I haven't actually driven the car yet, but the pedals seem to function as they should. Here is a link to the thread. BTW, I had a little trouble locating that exact M/C but you should be able to find something that will work. Lots of choices for the same basic type M/C.
    https://www.jalopyjournal.com/forum/threads/tech-49-54-chevrolet-master-cylinder-upgrade.367041/
  13. Chavezk21
    Chavezk21
    Check with
    Chevy's of the 40's in Vancouver, WA, or old car parts in Portland,
    OR.
