Technical 1951 Chevrolet Styleline Special
Discussion in 'The Hokey Ass Message Board' started by Chris Bailey, Apr 6, 2023.
  1. Chris Bailey
    Chris Bailey
    I recently purchased a 1951 Chevrolet Styleline Special. It's powered by a 261 Straight 6 out of a 1954 1 ton Chevrolet truck. I drove it to work and it ran great. On the drive home, about a mile from my home it started running rough, and actually quit running as I was turning in my driveway. Now it will crank and run with the choke halfway out but runs really rough. If I push the choke in it will not idle at all. I disconnected the fuel line at the carb and it was getting fuel. The fuel/air mixture screw on the carb has no effect at all when I adjusted it. I screwed it all the way in and backed it out 1 1/2 turns. I even backed it out a few more turns but it still had no effect. Could a bad fuel pump cause this problem.
  2. CSPIDY
    CSPIDY
    Wow a couple possible issues come to mind
    dirty gas, vacuum leak, cucked up carb
    and electrical issue
    sounds like the pump is working
    VANDENPLAS likes this.
  3. Empty tank? Seriously! Fuel delivery problem somewhere. Nothing magic here, Chris.
    Welcome aboard.
    Ben
  4. fastcar1953
    fastcar1953
    If its pumping gas at carb then its in the carb. Unless pressure is low. Doesn't take much pressure though.
    If you get it running can you spray gas down carb and keep it running with choke open ?
    Could be stuck float. Tap on the float bowl and see what happens.
    I would rebuild carb if you haven't done so.
    RMONTY, VANDENPLAS and Chris Bailey like this.
  5. WalkerMD
    WalkerMD
    I’d check fuel filter first.
  6. ClayMart
    ClayMart
    ***uming it's a Rochester Monojet, check the two big phillips head screws that attach the float bowl to the throttle plate. It's not uncommon for them to work loose, creating a vacuum leak. You may have to remove the carb to tighten them properly. And maybe replace a couple gaskets between the bowl and thottle plate and the carb to intake manifold.
    alanp561 and studebaker46 like this.
  7. Paul
    Paul
    Editor
    back in the day I'd expect water in the gas.
    hrm2k likes this.
  8. studebaker46
    studebaker46
    inline chevy sixes were notorious for the intake bolts and carb to intake bolts coming loose and causing a vacuum leak. just an old man thinking outloud Tom
    alanp561 likes this.
  9. bobss396
    bobss396
    The carb halves can loosen up too, but I suspect something like a tank full of crud, pull the carb apart to see what is inside.
    firstinsteele and Bob Lowry like this.
  10. F-ONE
    F-ONE
    from Alabama
    Check the condenser.
    62rebel and VANDENPLAS like this.
  11. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Dirt, water, partially plugged filter, partially plugged filter on the pickup tube in the tank, carb full of ****, plugging the jets. All possible causes. Not an ignition problem. Pulling the choke to make it run will not make an ignition problem go away. If this car has been sitting a long time, I would go through the entire fuel delivery system. Get rid of any old gas, too, and blow out the lines, all the way back to the tank. Remove the gas gauge sender in the tank and check for rust holes in the pickup tube and the condition of the filter screen on the end of the tube. Clean the carb and blow out the p***ages in the body.
    bobss396, alanp561 and firstinsteele like this.
  12. RMONTY
    RMONTY
    Post some pictures of the beast! We want to see what you got!
  13. 62rebel
    62rebel
    Don't know if that uses a ballast resistor but I had two MoPars that drove me nuts because of bad ones
  14. Chris Bailey
    Chris Bailey
    I just got done doi
    20230402_164434.jpg 20230402_164307.jpg 20230402_164307.jpg 20230402_164332.jpg 20230402_164434.jpg 20230402_164351.jpg
    I took off the carb today, took it apart, and gave it a thorough cleaning. The fuel / air mixture port in the carb was stopped up and the float was sticking. I blew out the fuel line from the tank to the fuel pump and the line from the pump to the carb. I also added Heet to the gas. It will idle now but it's still a little rough. I have the fuel / air mixture screw almost halfway out. If i screw it in any further she will start cutting out and choke down. Per my Daddy's advice, I'm going to put a new fuel filter on the carb and also install a new fuel pump next week. My Daddy is 82 and back in the day he used to build the 235's and 261's. He said they called the 261's V8 killers back in the day !
  15. RMONTY
    RMONTY
    Nice car! Love the 261s!
  16. alanp561
    alanp561
    Welcome to the HAMB from SE Tennessee. You've got a nice ride there. Sounds like you're on the way to getting your problems solved.
    lothiandon1940 likes this.
  17. Chris Bailey
    Chris Bailey
    I got the old 261 running good. The distributor clamp had loosened up and threw the timing off. I also purchased a turn signal kit from Vintage Auto Garage and installed it. Now for wheels and tires. I'm partial to the old steel wheels with baby moons. Maybe 15 x 7's on the front and 15 x 8's on the back. What are yall's suggestions on tire size front and back ?
    tb33anda3rd and CSPIDY like this.
  18. wheeltramp brian
    wheeltramp brian
    I believe the 15/7 and 8th will look a bit Street Roddy. I keep the stock wheels
    guthriesmith likes this.
  19. rusty1
    rusty1
    205's front, 225 =15's on the rear, will work,..6" rims front, 7" on rear, bout as big as will fit.....that's what I had on my 49
    Jim the Sweep likes this.
  20. ClayMart
    ClayMart
    I don't know how familiar you are with these older Chevy I-6s, but even when everything is working as it should the distributor can still appear to be loose. When the vacuum advance is actuated the entire distributor housing rotates to advance the position of the points, as opposed to moving just the breaker plate like the later model distributors do. With the engine off you can easily grab the distributor cap by hand and rotate the entire ***embly several degrees.
  21. guthriesmith
    guthriesmith
    Neat car! Reminds me of the 52 I had back when I joined the HAMB several years ago.
