Projects Northrop F5 Belly Tank Racer
Discussion in 'Traditional Hot Rods' started by Superlite, Feb 1, 2023.
  1. alanp561
    alanp561
    More on the box sections for attaching suspension. I'm sure that you've seen this up close and personal but, for the benefit of others, the following pics are of what holds the landing gear of a Cessna 172 to the aircraft. Building similar boxes front, rear and in the engine area configured to the shape of your tank is easy enough and with hat section stringers, the bottom half of your tank becomes strong and gives you more room inside. You know what I'm talking about, the last picture is of what actually holds the back end of a 172 together. Ribs, stringers and the skin which is a heck of a lot thinner than the metal in your tank. Yeah, you'd want to flush rivet the whole thing but, what the heck, you work on airplanes for a living, right? Wish I was closer, I'd buck the rivets for you.
    [​IMG] [​IMG] [​IMG]
    Toms Dogs, Outback, Superlite and 2 others like this.
  2. lake_harley
    lake_harley
    I'm about 5'9" and 143#. I built a all-wood ultralight airplane (MiniMAX) and the fuselage was 22" wide at the outside. At shoulder height there was about 1 1/4" width of longeron and additional structure on both sides, so the inside width at shoulder height when in the plane was about 19 1/2". I fit in it just fine as well as a 170-ish pound friend who flew it. He had plenty room and ****pit width too. FWIW....my **** will fit in a 14 1/2" aluminum racing seat.
    Lynn
    Superlite, 26 T Ford RPU and alanp561 like this.
  3. Superlite
    Superlite
    The exterior of the tank is symmetrical. I am noticing the dissymmetry within the tank so wind tunnel testing wouldn't make a difference. I think it just has to do with where the brackets and flanges were held in place prior to welding and potentially, they shifted before the welds went on. Due to the dates of the tank, this has to be a very early tank so it wouldn't surprise me. The dissymmetry is only an inch to an inch and a half at most.
    26 T Ford RPU likes this.
  4. Superlite
    Superlite
    My intention is the build the frame out of 2x3 C-channel stock steel. I'll probably incorporate a tube steel section on the back side of the seat to help protect myself in the event of a rollover. I'll utilize steel brackets off the main frame ***embly for attaching what is needed.
  5. Superlite
    Superlite
    Thankfully I'm a small guy so I'm pretty sure that no matter how I put this thing together, I'll still be able to fit :D
    Toms Dogs and 26 T Ford RPU like this.
  6. 26 T Ford RPU
    26 T Ford RPU
  7. It's possible that cutting it apart relieved as-built stresses and allowed the top and bottom halves to seek their 'normalized' shape/profile.
  8. Superlite
    Superlite
    Possible but not in this case. These measurements were on the hard connected flanges with all structure in-tact within the immediate area. In other news I just realized yesterday I need to find a radiator that will work with the 1950 Mercury V8 Flathead and fit within around 18 inches or less of space. If anyone has the scoop on something that would work i'm all ears. If there isn't anything lower profile available, I might incorporate air vents on the side of the tank to allow for more width in the engine compartment for the dual purpose of fitment and cooling. Not optimal, but it's an option.
  9. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Some possible radiator options -
    A lay-down radiator
    A vertical longitudinal radiator with an electric fan (think toaster)
    A custom aluminum radiator built to fit into your confines made from a cardboard mock-up by somebody like Superior Radiator.
    https://www.wwwsuperiorradiator.com/
    Superlite likes this.
  10. Harv
    Harv
    from Sydney
    Just a thought on the precision grinding. Cut some light sheet steel sheet to act as “guards” either side of the area you are grinding. Put some rag over the outside of the tank, and use your hands to bend a curve around not the guards. Gaffer tape them in place while you grind.
    Guarranteed that if I was grinding, I’d muck the guards a few times :oops:
  11. Superlite
    Superlite
    Here at work this evening and was having a conversation with a coworker about the idea of a longitudinally mounted radiator and a fan to push air through it. Would be an interesting concept and have never personally seen that done before. I do have 14ft of space to work with but optimally it would be nice to have the radiator sit aft of the seat / firewall. Thanks for the link. I'll have to take some better measurements and get in touch with those guys. A custom form-fitted radiator in the shape of the tank would be sick!
  12. Superlite
    Superlite
    Thanks Harv. Can't go wrong with some protection. I've been using a taped cereal box in the event of a nasty accidental slip.
  13. Lingwendil
    Lingwendil
    Very cool project!
    Thinking of rear suspension, maybe look into the stuff us VW guys use for Formula Vee- granted it's an IRS setup, but maybe if you were to use two coilover shocks with a cantilever setup to have them inside the body, and have a center hardpoint for them to pivot on. Think pic related, but with two shocks coming to a centerline mounting point-
    Or like the VW based trikes do-
    Looks like it would fit your space constraints.
    alanp561, 41 GMC K-18 and Superlite like this.
  14. Superlite
    Superlite
    A month and a half later and I boy do I have some serious updates and developments for you all! First things first. You may notice that the name of the build blog has changed. For the past 5 and a half months of ownership and after much research I had previously determined the belly tank to be from the A10 Warthog. The previous owner didn't know where the tank came from. Pictures that I could find on the tank showcased extreme similarities, however there were some subtle differences. I was incorrect this whole time and I apologize to lead you all astray.
    I was scrolling through Instagram after having searched the hashtag #lakester and I came across a familiar sight. The top of this tank I'm looking at on my phone looks exactly the same as mine.... Hmmmm... Clicked into the picture and the page owners Instagram and found that he had Maryland license plates. I had purchased my tank in Maryland outside of DC... Hmmmmmmmmm... The paint markings are exactly in the same spots....HMMMMMMM... I looked under the tank and there were some slight scratch / gouge marks in the same location as where the front of the tank was riding along the front edge of the trailer that the previous owner used to transport the tank.... NO WAY! I asked him if he had previously sold that tank to a certain individual and BINGO!!!! He did! He further told me that he picked this tank up from an area in south Jersey close to an airfield, stating that a gentleman had a bunch of these tanks and would acquire them when the aircraft were decommissioned and these tanks were removed. I now have concrete evidence showing that my tank is from a decommissioned Northrop F5 which is a supersonic light fighter. I am currently unsure of which model currently but will do more research. It is for sure from a navy aircraft. I am just happy to know for sure which bird my tank came from. The side of the tank as well as the serial number is HSNC-117 which stands for High Speed Naval Craft. Not sure what the 117 stands for yet but more research will ensue. These markings now make WAYYY more sense than the idea that this tank belonged to the A10 Warthog. I have attached a picture of my exact tank from around 125 weeks ago which would date to December of 2020. My tank is on the Driver's side / Left side of the trailer behind the Russian Mig 23 Tank. So cool to randomly see this!! I guess this would make me the 5th official owner of this tank. #1 Navy, #2 Gentleman in Jersey that picked up the tank after aircraft decommission, #3 Maryland Gentleman in the picture with the tank on the trailer, #4 Maryland Gentleman that owned the tank before me and bought it from gentleman #3, #5 ME :D
    I have found earlier dates than before inside the tank, one piece dating back to 1967. The Manufactured date on the side of the tank is March of 1970, with a reconditioned date of 1990. This is still a pretty early tank as the in-service date for the Northrop F5 is 1962. I will do my best to update my blog accordingly to reflect the proper aircraft with proper information.
    Progress pictures to follow here shortly! Now that Cruisin' Ocean City is done and over with, I am putting my Corvette on the back burner and am giving myself a 1 year deadline to get this tank on the road by May 16th, 2024 which is when Cruisin' Ocean City, MD 2024 starts. Time to get busy! 348954647_1309096843288086_1539482294583875632_n.jpg 21f4ab889a40af738bd88ca376665d02.jpg 437749-aircrafts-army-fighter-jets-usa-northrop-f-5-freedom-fighter.jpg 348698257_3502303090044983_4673023594049161009_n.jpg 348866469_666072302227485_4067794433354225580_n.jpg
  15. Superlite
    Superlite
    The past 3 days I have been working hard on the tank with my current deadline looming overhead. It's exciting and motivating having a date to beat to get this thing on the road.
    Taillight ***emblies
    I have started off with grabbing both internal fuel transfer pumps and taking them apart, gutting them and removing the float ***emblies to leave myself a hollow chamber. They are both ready to accept the taillight ***emblies. I am currently planning on buying two motorcycle tail light ***emblies like I have on the motorcycle I built and mounting them inside the transfer pumps. They already have the red lenses and I should be able to mount them inside fairly easily. They are already sealed to the elements and already have the wiring run. Should make it easy! The wire harness for those motorcycle taillight ***emblies will be hidden perfectly due to the fuel pipes attached to the transfer pumps. Those fuel pipes will mount through to the inside of the tank. I have determined the mounting / feed through locations for the tail light ***emblies.
    Tank Mounting structure to the F5's Bomb Rack
    I spend a good bit of time working on taking apart the internal support structure that mounts the tank to the F5's bomb racks. Removed several bolt and nut ***emblies, as well as drilled out many rivets / Hi-locks / Huck rivets. Some of the rivets were impossible to drill out with the tank being in the way, so those got the cutting wheel treatment. The large exterior nuts that sit around the hangars are permastuck... I spent HOURS trying to remove them with no success using everything from penetrating oils to heat to brute force.
    Wheel and Axle Placement
    I took my Corvette wheels and tires and positioned them to start giving myself an idea of axle placement. I worked from the rear up and using the approximate driveline measurements I took, I came up with the location for the rear axle, which should give me enough room up front. Even with a 14 foot long tank, i'm running out of room quick but I should have enough! Check out the pictures for where i'd like to position my wheels and tires / axles.
    ****pit Cutout
    I have a ****pit! After taking some approximate measurements and doing some math, I calculated the length of the driveline up to the radiator from the rear axle to be right around the 6 foot mark. This includes the rear axle, a driveshaft of about a 6 - 8 inch length, transmission, new bellhousing, engine, engine fan blades, radiators, radiator hoses, and firewall. Using my now roughly located firewall ***embly, as well as the rough area for where the bomber seat will be located I was able to mark out the location for the ****pit cutout. I wanted to get the cutout location right and symmetrical so I first used a laser level to find the exact center of the tank. From there I was able to lower the level, and using the curvature of the tank, I was able to warp the flat line of the laser around the curvature of the tank, thereby displaying a curved line. Using my previously determined longitudinal centerline, I was able to get a perfectly symmetrical curved line for my ****pit / canopy. I took measurements of my shoulders and wanted to ensure my fitment. The tank itself is 22 inches at it's widest diameter. My shoulders come out to around 19-21 inches depending on how my arms are situated. I took the ****pit cutout down the side of the tank and left myself around an inch / inch and a half of tank on each side, giving me just enough shoulder room to fit.
    Wiring Harness
    At Cruisin' Ocean City a few days ago I had an awesome conversation with a gentleman that owns around 50 cars and builds all sorts of stuff. He tipped me off to a company he uses strictly for wiring harnesses so I figured I'd give them a shot. Since i'll be starting from scratch I pre-emptively ordered the lakester's wiring harness and it shipped out a couple days ago. This company makes it EZ and every wire is labeled every 5 inches. Lengths of wiring are based on a long bed pickup truck so this should give me enough run. It is a 21 circuit / 18 fuse harness that include the Horn, Fan, Dome light, Hazard, Radio, Cig lighter, Door Locks, Brake, Headlights, Trunk light, Gauges, Back up and Cruise, Wipers, Choke, Coil, A/C, Electric Fuel Pump, Power Windows and Turn signals. I obviously won't be using many of these circuits, like the A/C and power windows of course, but I can use those circuits for stuff like a fire extinguishing system a**** other things. Here's the link.
    https://www.ezwiring.com/product-page/ez-wiring-21-standard-wiring-harness
    Brace yourself for a lot of pictures! 346138459_1415754895887967_5276019193341422995_n.jpg 346110727_768538528109276_1273286576420473382_n.jpg 346144759_773770440894016_333623571896347988_n.jpg 346141990_640261548008156_8121348587966617643_n.jpg 346106694_3466799716935081_142322653846171868_n.jpg 346144627_601125628649412_7825682861705469173_n.jpg 346155887_1265458104080484_2378416452633481449_n.jpg 346162397_231470616273872_1814128898526277742_n.jpg 346141979_1320301205496165_3556720605679768775_n.jpg 346142365_834859231493155_404673033109666651_n.jpg 346111048_764373308752044_9166356167940980652_n.jpg 346141980_967223117747866_4160082719189688817_n.jpg 346140610_570356735203901_4313192006245479754_n.jpg 346150931_1395889164591361_2034179194178488302_n.jpg 346165841_1231354844232265_6302886977942573509_n.jpg 349006077_3618277291749613_1905396357396450190_n.jpg 346155976_631865078871514_8775883352953265817_n.jpg 346155096_2187759118100644_5482201223525598307_n.jpg 346142120_517910553748976_4299716375050491880_n.jpg 346142023_6359817900705576_5387594222476494813_n.jpg 346157961_610683017836183_7047199663486077216_n.jpg 346143827_265167052549700_4453393446568010597_n.jpg 346157078_575779257983187_2105708051796531655_n.jpg 346142018_1843415149365379_8027723235920162147_n.jpg 346150437_2163982073790587_7588866977445605365_n.jpg 346138065_797197698481689_7537714022014264758_n.jpg 346158641_258637316742945_940570327108294089_n.jpg 349014112_243384371629499_5384106162853169577_n.jpg 348992176_812408353275403_8882039411130392189_n.jpg 346148754_204573249120875_6956056384380661189_n.jpg More progress to follow!
  16. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  17. Superlite
    Superlite
    First time hopping in the tank! Tight squeeze, but I fit! I'm going to have to make the ch***is so it follows the lower contours of the tank to squeeze as much space as possible out of this thing. Very happy I decided to cut the ****pit opening down where I did paying attention to my shoulder width. I'm 5'11" and around 145 pounds. My shoulders sit around 20-21 inches or so. with the tank at 22 inches in diameter, I'd say I fit just right. Already having a good time :cool::D 348922271_202476682626304_1674389335965114069_n (1).jpg 349154179_2089274064608144_1466384411623975700_n.jpg 349178945_159742913559740_8092760827903090762_n.jpg 349018247_1200166167364299_6580437489374339951_n.jpg 349082277_214925951320835_8547287188282716893_n.jpg 349084454_151595067893367_6202384086019901321_n.jpg 349102973_3371575556490779_2173980614123779322_n.jpg
  18. X38
    X38
    Man that's a slim tank! You sure look like you're having fun.
    (I hope those wheels etc. are just for mock up :eek:)
  19. Superlite
    Superlite
    Yes they are just for mockup purposes to help get an idea of where the rear axle will be located. I'm planning on running 1935 Ford wire wheels or wide 5's if I can find them.
  20. Superlite
    Superlite
    I have some pretty m***ive updates for you all. I scored this beautiful 1928-1931 Ford Model A Rolling Ch***is on ebay out of Wisconsin. This will be the donor ch***is to provide the belly tank with almost everything it needs to get on the road. It has been completely re-furbished, rebuilt, and gone through in its entirety. It will be coming with the engine and trans you see pictured, however those will be put aside and I will still be using the Mercury V8 Flathead and rebuilt 3 speed transmission I picked up earlier. It has everything I wanted for the belly tank from the rear end, to the wheels, to the proper radius rods. I will be coordinating shipping here in the next couple of days after memorial day. Purchasing this ch***is will greatly accelerate my build completion date, and I fully expect the car to be done and driving by the Endless Summer Cruisin' Car show in Ocean City, MD in October. I have reduced my deadline for completion from 1 year down to 4 months. The lakester will need to be completed and setup on display by October 4th. Wait a minute... Display you say? Speaking of which! This is HUGE!
    I was reached out to by the moderators and promoters of Cruisin' Ocean City, MD and Endless Summer Cruisin' to display the belly tank inside their convention center as a feature car during the spring and fall shows which is a pretty big deal. Typically, only the best of the best gets inside the convention center during the show with thousands of hot rods. Movie cars and celebrities, extremely high quality builds, and wildly cool cars get the spot light for these 4 day events. My Lakester will be one of them (If I can get the build done by then!)
    As far as the build itself goes here are some key points:
    Ch***is - I will be using the Model A's ch***is here for the belly tank instead of sourcing fresh metal from a shop. I plan to cut this ch***is and form it to conform to the inside of the tank as best I can. Still not sure if I want to reverse / flip the sides of the ch***is so that the C-Channel is facing inside or outside. An outside facing C-Channel will provide opportunities for a cleaner build.
    Steering - As you can see there is no steering wheel or steering column, so that will need to be sourced.
    Torque tube / Driveshaft - I probably won't be using the torque tube as provided with the ch***is. If I do, it will of course need to be greatly shortened for my needs. I'll probably end up getting a custom driveshaft made, as well as have to do the conversion on the banjo rear to accept a driveshaft.
    Rear Suspension - I probably won't be using the rear leaf spring. At this point I am aiming to pick up the trailer suspension I have attached in an earlier post to enable to rear suspension to be contained within the tank if possible. An angled coil over suspension to be mounted within the tank would be pretty cool and is also in the running.
    Wiring harness - I got some pictures of the new wiring harness from EZ Wiring down in Florida. I attached them here. As a nice aviation related touch to the wiring harness I am planning on lacing it after it is all laid out. It will be as tidy as I can possibly make it.
    Seat - After mapping things out and doing some math, I'm pretty sure there will only be room for 1 seat. I thought it might be cool to have a second seat, but I don't think it will fit. It is a 14ft long tank, however the tank cones in pretty severely, so a lot of that footage is unusable unless my p***enger is extremely small. :D
    Radiator - After the ch***is is made and the entire driveline is in the lakester, I plan on taking measurements and hiring a company to custom make a radiator that will fit the contours of the tank and work with the dual water pumps of the flathead.
    Shifter Linkage - I will be fabricating a support tower of sorts next to the right side of the toploader trans. The trans will be positioned behind the driver, so a mechanical linkage will need to be made to kick the linkage off to the side. I am toying around with the idea of a floating shifter handle.
    Gas tank - Currently looking at the possibility of using a yellow WW2 era Breathing Oxygen tank, or a couple of them! It should be small enough to fit. If I can manage it, I might be able to run a dual fuel tank setup in the car, one tank being higher than the other to gravity feed into the lower tank. I want to drive this thing!
    Towing capability - I am very interested in being able to tow a small trailer with this Lakester so I can have the capability to tow my custom built motorcycle behind it, So I am going to try and incorporate a removable towbar. I would also be able to attach a removable T-Handle as well for when the need arises to push the tank by hand.
    Things are heating up QUICK with the build but that's all for now. Happy Memorial Day! I'll be back with another update very soon. ;)
    s-l1600 (1).jpg s-l1600 (2).jpg s-l1600 (3).jpg s-l1600 (4).jpg s-l1600 (5).jpg s-l1600 (6).jpg s-l1600 (7).jpg s-l1600 (8).jpg s-l1600 (9).jpg s-l1600 (10).jpg s-l1600 (11).jpg s-l1600 (12).jpg s-l1600.jpg 349308188_2365627346974329_9128644292837930724_n.jpg 350236629_781491053361829_8804591073521514309_n.jpg 350370157_481156510841643_1924703050759877555_n.jpg
  21. 26 T Ford RPU
    26 T Ford RPU
    That ch***is is a 28-29. I would say it would be easier to build a frame to suit what you have instead of making the A ch***is fit. Just my 2cents. JW
  22. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I am envious of anybody who can build a complete car in such a short time frame. My builds take years.
    You can also use the hitch reciever for a "tailgate" party attachment.
  23. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Maybe make a compartment for a pet (of the 4-legged variety)? or room for a gym bag or cooler or tools?
  24. Superlite
    Superlite
    After the Model A ch***is arrives I'm going to confirm the amount of splines on the banjo rear and pick this up. This will allow me to run the required driveshaft. I'll be trying to incorporate a small storage compartment if I can.. I would like to be able to carry around atleast a standard size backpack and keep the car's paperwork with the car.
    https://www.speedwaymotors.com/Spee...en-Drive-Driveshaft-Conversion-Kit,40133.html
    41 GMC K-18 and 26 T Ford RPU like this.
  25. I agree with @26 T Ford RPU It seems like with as little as you'll be using from the Model A ch***is, it would serve you best as inspiration and a guide to sit next to the belly tank for reference, rather than hack it up and discard some good stuff that would no doubt be useful to someone else.
    Greenblade and 26 T Ford RPU like this.
  26. Superlite
    Superlite
    This is exactly what will happen. After taking some measurements, I will not be able to use the '28 Model A Ch***is to build the frame. It is about a foot to a foot and a half too short lengthwise. Custom self-made ch***is it is! The ch***is itself is in incredible shape, so I plan on saving or selling the frame to someone that can use it instead of chopping it up.
  27. Superlite
    Superlite
    The frame itself is saved from the chopping block. Can't use it for my purposes! Will probably be up for sale soon.
    '28phonebooth and 26 T Ford RPU like this.
  28. Superlite
    Superlite
    Early last week I started digging into the rear cone section where the winglet supports are. Here's how it went down.
    I had yet to see an actual data plate on the inside of the tank and if there was one to be found, it would have been in the rear dry section where the winglets are. There was an exterior data plate, but haven't come accross one on the inside yet. There is an exterior inspection / access door to the rear cone section, but I did not want to disturb the Torq-set screws. There was a small inspection hole on the inside, so I used a very small telescoping mirror to take a good look of the inside. Low and behold, there it was. I took mental note of where the data plate was and found some really cool stuff. I managed to extract the data plate without damaging any of the markings. Take a good look at it! It took a few hours and I took yet another aluminum shaving shower, but I got in there just fine. After some nut and bolt removal, rivet drilling, and lots of careful, slow cutting and grinding later the tail cone is in an acceptable state.
    While I was in aluminum grinding mode, I took the time to very carefully cut and grind down the rear-most flange. It actually wasn't a flange at all, but rather the rear concave domed portion of the fuel containment area where the fuel sat. You can see this rear concaved domed section on post #12. This portion on the tank was laying flat on the skin of the tank, so I very carefully cut down MOST of the way through the aluminum. When it was thin enough, I was able to peel the aluminum back and rip it off the tank without damaging or accidentally cutting into the exterior shell with the cutting wheel. I performed this process on both the upper and lower halves.
    353862705_565652352174334_5746798691553037887_n.jpg 352386430_247400284567613_4016987274794499441_n.jpg 353988552_287963586927073_4726501060184189710_n.jpg 351631633_647122650605175_3673450329851650977_n.jpg 354016110_263629779668727_4660857668936678594_n.jpg 351612620_1921787088195281_9072808560281551762_n.jpg 351442644_1266594234273098_5567782051444010243_n.jpg 351524874_763514355520825_7201775550560845178_n.jpg 350813210_1307532703524485_3110314310018961815_n.jpg 354048101_1193165108022959_4470467359288060056_n.jpg 354044919_1979694262407626_3693826150253689598_n.jpg 354080937_985208635838691_2188701961673615796_n.jpg 354076588_177360511973334_8537557303509720933_n.jpg 351534247_800073201430326_2529893465780427335_n.jpg 345502131_302817468737239_4098258544259795720_n.jpg 348937652_1388625691992003_5821600206054028314_n.jpg 352912958_999406777722384_6141910203544579364_n.jpg 351468265_910236240077478_5067101501132951292_n.jpg
    282doorUK and 26 T Ford RPU like this.
  29. Superlite
    Superlite
    Exciting update here!! My 1928 Ford Model A rolling donor ch***is arrived around 9:30pm Wednesday, June 7th from Cameron Wisconsin. I purchased this ch***is on eBay and the seller had excellent communication with me throughout the whole process. He was a very pleasant gentleman to deal with and will be mailing out a bill of sale. Unfortunately there is no ***le for the ch***is nor does he know its history.
    I couldn't possibly p*** up the quality of this ch***is and these parts as the whole thing had been gone through and restored / refurbished.
    There were a few key points for purchasing a donor ch***is instead of individual parts.
    - The entire driveline is supplied for the lakester via the ch***is. Everything I need to get the lakester on wheels is provided. This has saved me an insane amount of time and h***le over trying to source individual parts and then figuring out how to put everything together. This is my first time building a full car, so I wanted to take an easier route, especially since I have a deadline for getting this thing on the road in less than 4 months.
    - I wanted this tank to be period correct! This was a huge step in the right direction!
    - Probably the biggest point to purchase a donor ch***is was so I would have a route to register the lakester for road use. After I receive the bill of sale, I will be getting it notarized in the town over. I will immediately begin starting the ***ling process utilizing the Vermont loophole. After I receive the Vermont ***le, I will then be selling the lakester to my LLC in Montana and transferring the ***le over. The lakester will then become a "Company Car" ,be permanently registered to my Montana LLC as a 1928 Model A and will never need an inspection, EVER.
    Side question! Will this be the first lakester on white walls, atleast temporarily? I have yet to see one picture of a lakester on white walls. I would rather have black walled firestones, but these white walled firestones will do the trick with my tight deadline. I'll have time to polish up how the tank looks after the big show. The less I have to worry about for now the better. I did not notice in the pictures and it is really hard to tell, but the tires are larger in the rear than the front.
    352621152_671854794783046_1642447515645070017_n.jpg 351378352_149014484841137_345921776497442508_n.jpg 351512152_968361894360027_4757437920123992318_n.jpg
  30. Superlite
    Superlite
    Here are some better pictures of the ch***is under the lights of the garage. The most damage I can see anywhere is chipped paint on the wheels. The rest of the ch***is and driveline components are almost perfect! It is in incredible condition for being almost 100 years old. The ch***is came with a 3.3L Inline 4 sporting a whopping 40hp. :cool: 351559018_3619800738255004_5686390456740040095_n.jpg 351509907_260405536571605_2938995945771276411_n.jpg 351490744_1404453106955588_1252274992330834980_n.jpg 351547294_1937908233275694_8015221137178941672_n.jpg 351612630_2262329447310726_5537605807686260350_n.jpg 351643219_1335071160441100_2598016976166596580_n.jpg 351603024_6239808432782319_6902114773059657262_n.jpg 353930082_1637269266788495_7873789570238348005_n.jpg
