Projects Bought a Mercury on purpose
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Feb 4, 2023.
  1. Picked up this 4 row copper from a guy that wanted a polished aluminum one for his 55.
    New build he bought and thought the radiator needed replaced cause it wasn’t pretty.
    It’s a new radiator. I think I gave the guy $150.
    I’m good with an “ugly” radiator
  2. BamaMav
    BamaMav
    from Berry, AL
    A little black paint and it’ll be purty again.
    anthony myrick likes this.
  3. Just a FYI. The late 51 drive shaft is shorter than the 49 early 51
    Finally found my 50 drive shaft I saved decades ago.
    We saved a trip to the drive shaft shop getting a longer one made
  4. alanp561
    alanp561
    Is there room to fab a small stainless heat shield between them?
  5. Probably
    But I’m gonna go with the 55/56 ones
    ffr1222k likes this.
  6. Taking care of suspension issues. King pins were shot.
    I thought I’d check the parts car I have before I order some. They p***ed the tire wiggle test so I removed em. 68F5EB54-AD2A-4A34-8586-9A4A4382A70C.jpeg
    King pins have been replaced and feel great.
    Cleaned up nice
  7. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    1934 Fords, Henry not happy.
  8. 96EAC584-DD53-4916-AC34-5D2A58DD795F.jpeg Rounding up clutch pieces. looked up a few sbc to flathead threads. Got the instructions from speedway. Instructions say use the 10 inch borg and beck pressure plate.
    I’ve got 2. We have a local rebuilder. These are B&B 1319 and 988. Also had the appropriate pilot bushing and a couple 3 bolt starters in my stack of junk. 96EAC584-DD53-4916-AC34-5D2A58DD795F.jpeg E2882906-B7AF-4363-9D14-33347A1AA0CC.jpeg
    Ive got a 168 tooth FW but not drilled for a 10 inch setup. Just kinda curious why an 11 inch set up wouldn’t work since flatheads also had em.
    Not that big a deal to drill the FW but I might try to locate a 55 chevy one that had the 10inch clutch. The 55 Chevy FW casting number should be 3703870
  9. bobss396
    bobss396
    Some Chevy truck flywheels take both clutch covers. I run an 11 inch in my car, use a '55 Chevy bellhousing and truck starter.
  10. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Anthony;
    I'd guess that clutch dia would depend on the clutchcan/bellhousing depth & diameter you are using, that'll allow a given PP to fit. Since the stamped steel one was hard to find, didn't most ford flattie v8s use the smaller 10", so speedway, jcwhitney, et-al, just go w/the 10" version cause it'll fit most combos w/o trouble? (Not suggesting it'll be the best solution, or work the best). Would think if the dry-test-fitting has enough room, it should work ok. Sold all my old ford v8 flattie books, even the old jcwhitney catalogs are long gone, so I'm guessing from memory.
    Marcus...
  11. I guess the plan is to get one of the 10 inch pressure plates rebuilt. Purchase a disc. The trans I’m using has the larger input. 1 3/8.
    The depth of the speed gems adapter would be the only issue fitting the larger set up.
    No reason to waste time trying to make an 11 inch set up work. I’m not racing or towing. Just cruising.
    So the only thing to get handled will be either finding a 55/56 gm flywheel with the 10 inch clutch or drill the one I have.
    We ain’t skeered drilling new holes
  12. Students started ***embling the rear brakes. The brake hold down pins were wrong. Correct ones will be here tomorrow along with parking brake spreader bar springs
    Parking brake cables have been installed. Adjusters cleaned and oiled.
    new seals installed.
    Got the front suspension cleaned up ready for some paint. We ain’t overthinking this one.
    All of it was in great shape except the king pins.
  13. Okie Pete
    Okie Pete
    Many Hands make light work of a tedious job . Good of You to be teaching the Students how to make repairs and how to rebuild things . These skills will help them all through Their lives .
  14. bobss396
    bobss396
    Those casting lines... triggering my OCD...
  15. Those students must be pumped, I get a lot of satisfaction from your progress and I’m just watching from the sidelines.
  16. This one might be a bit more shiny than what Anthony would drive, but I will post it up for the kids- not my car, but you guessed it- I’d drive it. 62B67074-E0A5-4255-9304-841FD4C42124.jpeg
    R A Wrench, SS327, bobss396 and 3 others like this.
  17. Lowered the core support mount 1 1/2.
    For fan clearance and will lower the radiator to center it with the fan.
    students cutting and welding.
    We’ll add a small corner gusset on each end.
  18. skooch
    skooch
    Good looking welds!
  19. Ok for a student with a ****py teacher:):):):)
    Okie Pete, Sancho, 51504bat and 2 others like this.
  20. Almost a plague- so many gr***hoppers!
    Moondog13, SS327, 51 mercules and 2 others like this.
  21. Any guys near Bama have any Rochester 2 jets with the side fuel inlet?
    I have 2 but not a matching set
    the intake is drilled for both 3 and 4 bolt carbs. I have one larger bore 94.
  22. Bearings cleaned and repacked. New inner seals.
    Got the rest of the brake hardware installed
    nothing fancy. Just cleaning, rattle canning and replacing what’s needed.
  23. Master cyl mount fab. Welding student doing his thing.
    IMG_1466.jpeg IMG_1467.jpeg IMG_1468.jpeg IMG_1471.jpeg IMG_1472.jpeg IMG_1473.jpeg IMG_1474.jpeg
    plan to add a brace probably here. Or the other side.
  24. Dumb 283 question.
    I’ve got a couple 283s. One has this small “dampener”
    the other has this one
    I need to get the short pump lower pulley.
    What’s the difference between these two set ups and pulleys.
    I’ve got the timing cover that matches both.
  25. 51504bat
    51504bat
  26. We have a great welding instructor.
    Loves to do custom stuff as well. He’s about to start on a 50 ford business coupe.
    The young man welding is about to graduate and go to work.
  27. 51504bat
    51504bat
    Another success story.
