Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Little Truckdoctor and I have decided to replace the 216 in our 1950 3100 with a 1964 Chevy 230 and an SM326 transmission. We wanted to keep the 3 on the tree (call us crazy) and this seems like the easiest route. I’m really looking forward to hot rodding a Chevy six. The rear axle (as of now) will be a Ford 8.8 with 3.45’s and a Traction Lok. I’m not looking for a screaming power house, but a nice, smooth, and reliable cruiser. One of will do a build thread on it. Eventually, it will get front disc brakes and dropped springs.
  2. swade41
    swade41
    from Buffalo,NY
    I got the domed gl*** lense epoxed in my homemade gas cap, didn't make to much of a mess of it
    polished a backer to fit under the dome
    got new taller lug nuts in and on
    little things to the patiently waiting Henry J.
    Testing ideas for what I want to put under the gl***, I've got a good one I can't show yet lol
    And then I did a little daydreaming in the 57, looking down the spear listening to Green Onions I imagined of cruising on a warm evening to nowhere
    enloe, rod1, UNSHINED 2 and 11 others like this.
  3. Thanks for posting your avatar.... I mean pictures... What's the scoop on your '57? More pics of it, please...
  4. I've used quite a few 230's and 250's in my stuff, I love those engines, hard to beat em.
    Truckdoctor Andy likes this.
  5. Day 2
    Day 2
    from ga
    Dolled up my generic traction bars with a nod to Ansen!!!
    Okie Pete, scotty t and swade41 like this.
  6. swade41
    swade41
    from Buffalo,NY
    You know I made an "avatar" album for everyone's viewing pleasure wink wink
    The 57 was a nice solid unmolested short bed big window I found abot 2600 miles away, took a gamble and had it shipped sight unseen since it was exactly what I was looking for.
    I have a build thread on it, just waiting it's turn to really get busy on it but I've put a 9 inch in it, setup sbc and th400, disc brake swap, lowered and collected a lot of parts.
    https://www.jalopyjournal.com/forum/threads/building-a-57-chevy-shop-truck.1084369/
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    Ball joints and control arm bushings on the 56
    enloe, rod1, Okie Pete and 7 others like this.
  8. lumpy 63
    lumpy 63
    ^^^^^^Shoulda just put a mustang II in it:p
  9. Or at least radials and disc brakes;)
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    yikes.....
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    I may go as far as tapered wheel bearings but that is it... I hate modern stuff
  12. lumpy 63
    lumpy 63
    Really? we hadn't noticed:D
  13. Finished the transmission swap. Test drive was great, car runs so much better now. Trying to figure out what to put in the bed floor. Picked up 2 pieces of aluminum diamond plate (stole them from a decommissioned ladder truck at work) but they aren't big enough. Stuck one on the inside of the tailgate though. Still gotta plumb a fill pipe up to the fuel door on the quarter panel. 20230411_190109.jpg
    enloe, Okie Pete, RMR&C and 7 others like this.
  14. 4speed411
    4speed411
    Finishing welds on the floor braces and coating it with POR15 PXL_20230411_233955410.jpg
    rod1, Okie Pete, osage orange and 8 others like this.
  15. lumpy 63
    lumpy 63
    So......Since it seems like most of the die hard guys follow this and I really don't want to start a new thread on the issue let me toss this out there.. My Vette has a M21 trans with a Mcleod dual friction diaphram clutch, not dual disc but dual friction. I have noticed when rolling to a stop in first gear with my foot mashed down on the clutch it feels like the clutch suddenly starts to engage, not fully but you can feel it. I pop it into neutral and and come to a stop and then put it back into gear with my foot on the clutch and its not an issue, which leads me to believe that with the input shaft spinning the disc on coast down is causing an issue. Never experienced this before in 45 years of doing this ****. Ideas?It also doesn't do it every time.
    Lloyd's paint & glass likes this.
  16. Are you running a hydraulic clutch or manual linkage? And is there any resistance at idle when you put it in gear?
    alanp561 likes this.
  17. lumpy 63
    lumpy 63
    Manual factory linkage and no problem putting in gear.
  18. saltflats
    saltflats
    from Missouri
    Main shaft to input shaft bearings?
  19. lumpy 63
    lumpy 63
    I thought about that but since the input is all locked up in the first gear position there is no slippage involved .
  20. Thanks Lloyd!! I’ve had one 250 over the years and it was tough as nails! I spent some time tonight on Speedway’s website and picked out a cam, intake, carb, and header. The Offy intake is $600! We will certainly rebuild the engine, but the hot rod parts might have to wait a little. Besides, a stock 230 still makes more power than a worn out 216!!
  21. saltflats
    saltflats
    from Missouri
    Pilot bushing/bearing?
  22. lumpy 63
    lumpy 63
    I wouldn't think so but maybe? More like the disc spinning on coast down is being forced either forward or backwards into either the flywheel or pressure plate?
  23. lumpy 63
    lumpy 63
    I'm stumped. I am going to pull the trans when the new one arrives and I will double check everything , just hoping you guys would say " hey dumb *** here's the problem":D
  24. I like it! Thaks for posting... and about that avatar album.....
  25. 57 Fargo
    57 Fargo
    Make sure the splines on the input shaft are clean, the disc needs to be able to move freely on it.
  26. Hey dumb ***, you left your empty bud light can inside the bellhousing.
    427 sleeper, lumpy 63, Day 2 and 2 others like this.
  27. 5w30
    5w30
    Latest project 327 engine m20 trans posi nine inch rear axle and going with bias tires and smoothie wheels..
    Okie Pete, RMR&C, scotty t and 6 others like this.
  28. alanp561
    alanp561
    Planting flowers :mad:. Only reason I mentioned it is because it's getting in the way of working on my car :mad:.
    ###%^&**!!!! :mad:.
    scotty t and 427 sleeper like this.
  29. saltflats
    saltflats
    from Missouri
    I'm watching concrete dry.
  30. I'm making fake cl***ic edelbrock valve covers out of regular edelbrock valve covers lol 20230412_122441.jpg
