Technical Con Rod substitution.
Discussion in 'Traditional Hot Rods' started by Outback, Apr 11, 2023.
  1. Outback
    Outback
    from NE Vic, Oz
    I'm starting to get a plan together for a modified banger of English origin - from the 20's.
    One of the issues with them are the aluminum con rods, they have a history of failure.
    The Rods measure 10.25" c/ & 1 7/8" big end
    So it brings me to my question, either does anybody know of a Rod that is similar in dimension's or is there a resource which lists various Con Rod dimensions??
    I have done some looking & will continue to do so,
    I can get Rods made, but they are about 3k for a set & for no more than 100hp it seems a little crazy, so I am hoping to find something which might work. Any ideas?? IMG_20230411_181450024.jpg
    metalhead140 likes this.
  2. studebakerjoe
    studebakerjoe
    Longest rod I can think of off the top of my head would be a Willys. The rods are over 9 inches center to center. Don't recall the exact figure.
    Atwater Mike and Outback like this.
  3. Outback
    Outback
    from NE Vic, Oz
    Thanks, what era Willy's?
  4. studebakerjoe
    studebakerjoe
    The Willys jeeps 134. Not too hard to find
    Outback likes this.
  5. ekimneirbo
    ekimneirbo
    What fails on them ? Probably easier to modify what you have and work on fixing whats causing the failure. Maybe better oil/oiling?
  6. onetrickpony
    onetrickpony
    from Texas
    There can't be too many options on rods that long with journals that small. Good luck with your search.
    Outback likes this.
  7. '29 Gizmo
    '29 Gizmo
    from UK
    Get them crack tested. If they p*** they are probably good for another 100 years.
    Outback likes this.
  8. gimpyshotrods
    gimpyshotrods
    I agree that having them checked for cracks and just running them is probably the best plan.
    Quality steel alloy billets alone are quite spendy.
    $3K for a set of finished custom-made connecting rods is not out-of-line, even if it is just 4.
    Engineering, CAD, FEA all need to be done. That is a portion of the cost, and a portion that cannot be amortized over multiple sales.
  9. TCTND
    TCTND
    If they have a history of failure there's probably a typical failure point. For instance, the sharp cut where the bolt heads seat or maybe the small end. If you can determine what that point is you might be able to have them reinforced before reconditioning.
    Atwater Mike, X-cpe and Outback like this.
  10. PackardV8
    PackardV8
    Agree, find the best heliarc guy in the county, box both sides with plate, weld up the area cut for bolt heads and convert to ARP cap screws. Have the rods reconned on a Sunnen rod shop.
    jack vines
  11. gimpyshotrods
    gimpyshotrods
    To cement this, just the material to make these, ***uming 4340, would be $1,100.
    What @PackardV8 says is sound advice.
  12. Outback
    Outback
    from NE Vic, Oz
    @gimpyshotrods The new Rods I speak of are a very high quality forged Rod & I can see that they are worth the money, it just seems for 100hp or less it's over kill.
    I'm not sure where they fail, but suspect you are right @TCTND
    @PackardV8 that's certainly an interesting idea, I have a guy I can chat to about this,
    I have ***embled engines, but haven't 'built' engines, so I don't know fully what can be done.
    These engines have a full pressure bottom end, but only 3 mains.
    Most people building these engines replace the rods, I just don't know if this is based on myth or reality. I could get a hardness test done to see what they are like....
  13. Beanscoot
    Beanscoot
    With what? Perhaps you could just replace yours with the same ones most people use.
    Fortunateson and Desoto291Hemi like this.
  14. shorrock
    shorrock
    I have made steel rods to replace the aluminum rods on a Norton motorcycle and managed to get them 100gr lighter - so it is doable to replace those rods with something far stronger. Never weld an aluminum drop forged rod - it will lose a lot of strength and fail.
    ottoman and Outback like this.
  15. Outback
    Outback
    from NE Vic, Oz
    The $3000 custom made rods.
    I may have to go this way, I have time & I was hoping to find an OEM steel rods that might be close....
  16. Outback
    Outback
    from NE Vic, Oz
    Thanks, my machining skills are not up to making rods, but will keep pushing forward
  17. seb fontana
    seb fontana
    from ct
    Generally Alum rods break do to lack of oil and they are trying to stick to the crank pin, I am thinking no insert bearing? If no bearing then oil pressure/volume is your friend, get the pressure/volume up and run them. A home shop machinist [me] could make them from 7075 Alum plate with adjustment in bolt area for strength or cap screws like suggested above. They don't have to be that shapely do they?
    Outback likes this.
  18. Outback
    Outback
    from NE Vic, Oz
    They are Babbit/white metal bearings,I think part of the concern is fatigue on the Ally (duralumin) rods.
    They tend to machine a bronze shell & then pour the Babbit into them, to reduce the thickness of the poured metal.
  19. seb fontana
    seb fontana
    from ct
    I tractor pulled with a 18hp Te***seh engine and the stock forged [alcoa] rod was plated with babbit maybe .001 thick and held up fine with just splash lubrication moded to about 45hp @ 6500. Guys with Kohler engines were boring the cast alum rods out to take an over the counter insert bearing [1.5 id] and still slash lube and virtually eliminated breakage. Is the crank pin at 1.875?
    Outback likes this.
  20. Torana68
    Torana68
    from Australia
    ask Argo in Sydney down here ( https://argorace.com.au/) they will make you a set and it could be cheaper given the value of the Oz Banana to the GBP
    Outback likes this.
  21. Rickybop
    Rickybop
    The only rods that I can think of that would even approach that length would be straight 8 Buick.
    Outback likes this.
  22. Outback
    Outback
    from NE Vic, Oz
    I am down here too, Argo are the one's who make them. If there was a job lot 5/6 sets they will be a bit cheaper. Thx
  23. Outback
    Outback
    from NE Vic, Oz
    Thanks, I will chase it up. I figure there should be something, old truck, tractor something.
  24. Kevin Pharis
    Kevin Pharis
    from Califunny
    Find the donor rod ends you want, graft em together, and run the hell out of em! They did it back in the day, and it works great for a relatively low power engine. Here are some pics of a set of A big end T small end rods cut to length and boxed to fit in a T with A crank
    EC951982-F0C9-4469-8AF8-DA36C478A3AA.jpeg 0FDA9014-28F4-477E-84F8-ECF74ECBA8ED.jpeg 7231BF04-3732-4BA1-982D-3827FCF21CFE.jpeg
    metalhead140, GuyW, XXL__ and 7 others like this.
  25. Outback
    Outback
    from NE Vic, Oz
    9.1" ish
  26. Outback
    Outback
    from NE Vic, Oz
    They are in the 8" range.
  27. Outback
    Outback
    from NE Vic, Oz
    This might be the answer @Kevin Pharis, just have to find the right size rods & someone who is brave enough to weld them up! :D a question, it looks like you removed the web before welding them up? I guess removing stress raisers is the key with the removed material? Have you photo's of the finished item?
  28. mohr hp
    mohr hp
    from Georgia
    In the antique tractor pull world, John Deere 2 popper guys used to shorten their rods like that when m***ively stroking cranks. How much RPM do these engines spin?
  29. Cymro
    Cymro
    Out of interest, what engine are you intending to use?
    5window and AccurateMike like this.
  30. X-cpe
    X-cpe
    Have you looked at motorcycle, tractor or aircraft?
