Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Dis***embled the '87 AOD and waiting for upgraded parts and a rebuilding kit. Notice the broken belleville spring, the notch worn into the drive shell and the rust spots on the intermediate clutch steels. I was surprised that the frictions and bands were in excellent shape and no other wear issues were evident. There's probably stuff I'm missing since I've never rebuilt an automatic transmission before but I'm hoping better replacement parts, a rebuild kit and careful (!!!!) re***embly will result in a stout transmission. I've got a '77 351W that I rebuilt recently to hook it up to. I'll need a new radiator, a separate transmission coo IMG_2270.JPG IMG_2271.JPG IMG_2272.JPG IMG_2273.JPG ler and a lot of luck to get me to a start up maybe this year.
  2. saltflats
    saltflats
    from Missouri
    I should have the seal protectors for that style transmission if you need to barrow them.
  3. lumpy 63
    lumpy 63
    I'm strictly a Miller light guy nowadays:rolleyes:
  4. That's not what Scott told me :rolleyes:
    scotty t and 427 sleeper like this.
  5. lumpy 63
    lumpy 63
    How come theres no rainbow emoji on here?:p
    Waiting on the breather to dry lol
  7. Give me some ideas, everything is gone as far as trim. I wanna cover this hole and finding **** for this car is impossible. Don't wanna just weld a piece of metal over it. It's about 4.5", need to come up with something, possibly something with a Chevy emblem on it? 20230412_164621.jpg 20230412_164637.jpg
  8. fastcar1953
    fastcar1953
  9. gimpyshotrods
    gimpyshotrods
    That appears to be a 16-gallon Pony Car tank.
    When low-mounting like that, you may be able to use a 22-gallon one. It rises up from the pinch-weld seam, to make the extra volume, and is otherwise the same below it.
    If that one is too tall, there is a shorter 20-gallon one.
    I have the 22-gallon one in my '60 Falcon, it bolts-in to that entire model-line too.
    Lloyd's paint & glass likes this.
  10. fastcar1953
    fastcar1953
    Maybe something like swade did with his gas cap.
  11. saltflats
    saltflats
    from Missouri
    Maybe something like this, these are 3 3/8 inch.
  12. lumpy 63
    lumpy 63
    I'm sure Scotty and I could come up with a fine emblem....but you have to promise to put it on:D
  13. Yes! Thank you for the offer. I'm southwest of Belton. I'll be happy to cover shipping here and back to you. Do you have much experience with these transmissions? If so, I probably need to chat with you for a few minutes or so.
  14. Yeah man, Kentucky mustang restoration parts is close to me. All I seen was the 16 gallon! Which I'm happy to have it, better than the 10 gallon cell I had last year. I was gonna put the tank on top of the sub rails but after I looked at it, I can drop it to the bottom and have room to run the filler back to the original spot, so that's what I did. Hard to beat a new 16 gallon tank with a new sender and hardware for $250. Made in Canada
  15. Got me thinking now, set of cross flags might work
    Okie Pete likes this.
  16. Look kinda silly with a rubber **** hanging out of there lmao!
    427 sleeper, lumpy 63 and scotty t like this.
  17. saltflats
    saltflats
    from Missouri
    3 7/8 at the widest point.
  18. saltflats
    saltflats
    from Missouri
  19. On ePay right now
  20. saltflats
    saltflats
    from Missouri
    I have worked on a few of them, should have a ATSG manual also.
    osage orange likes this.
  21. gimpyshotrods
    gimpyshotrods
    https://www.cjponyparts.com/fuel-tank-22-gallon-1970/p/FT4/
    $165.
  22. I put a 19-gallon M**** stainless steel tank in my '29AA and fitted it about the way you did. I've just not figured out how I'll route the filler but there's enough room between the tank and where the bed will be to give me some options.
  23. The more I look at it, I might just cut the stamping out and smooth it
    '28phonebooth likes this.
  24. lumpy 63
    lumpy 63
    Do like Moriarty did on his vette . Have the wife make up a pleated upholstered insert to match your seat.
  25. mad mikey
    mad mikey
    I would stay away from C J Pony parts, they are 2 miles from me. Horrible company, can not keep employees their to save there lives and lots of complaints from all the Mustang guys around here. Just a heads up big guy.
  26. lumpy 63
    lumpy 63
    Although, crossed flags on a piece of engine turned aluminum would be slick.
  27. I've talked myself into shaving it. Tailgate will look better smooth anyway
