Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. I've never dealt with them. The outfit here is a bunch of brothers. I built a mustang a couple of years back and had to get some parts, so I went over there and gave them my tax number when I picked up the parts, turns out they set me up in the computer and I get a decent discount. Not like I do much mustang work, but hey, the tank made for an easy setup :cool:
  2. swade41
    swade41
    from Buffalo,NY
    My first thought was the horn ****on on 57 pickup
    But for you, maybe this is more better lol
  3. mad mikey
    mad mikey
    Yea I get that Lloyd. Thats cool. That business was started by a guy down the road from me when I was a kid, in his back yard. Then later was sold to a corp. I guess. The big facility they have here now continues to treat employees like ****, especially woman, and low pay. The management is completely discusting Very few people around here will even consider working there unless they are desperate. I will never buy one damn thing from them!
    Lloyd's paint & glass likes this.
  4. Zax
    Zax
    I've seen lots of guys cut the bed floor out of a modern truck at the junk yard and use that. Looks pretty good it you can line it up correctly.
  5. swade41
    swade41
    from Buffalo,NY
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Just laying out a new pedal design for the 32. 4CEE607F-5E35-40DB-A9F3-05444B6247F8.jpeg
    rod1, Chavezk21, Okie Pete and 10 others like this.
  7. fastcar1953
    fastcar1953
    Yes feeling so much better . Time to get the fuel system. Bugcatcher scoop with o.t fuel injection.
  8. I dug through boxes trying to find something like that, but I didn't have anything close in size. But I sat and looked at it and I think it'll look better completely gone lol.
    swade41, 427 sleeper and mad mikey like this.
  9. All that fake **** on there.. I bet you've gotten a **** job too, huh?
  10. You know it! :D
  11. bangngears
    bangngears
    from ofallon mo
    33 3w Its farther along than pictured. Running, rolling and painted. will try and get updated pics. 20210209_101950 - Copy.jpg 20210610_174125 - Copy.jpg
    rod1, Okie Pete, RMR&C and 8 others like this.
  12. alanp561
    alanp561
    Cardboard, huh? I thought I was good, but you've managed to make me feel "creatively challenged" :(. I would have flame cut a brand new chunk of steel into the approximate shape I wanted. After finding that it didn't work, I would have gotten out another brand new chunk :rolleyes:. That would have gone on until I got it right or had to go buy more steel :oops:.
  13. Moobs?
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    All I know is that the arm that was supplied with this frame before I got my hands on it didn’t fit the bill but would serve as a guide to what and where corrections needed to be within regards to pedal height on the toe board and ratio limits. Then it was off to the CNC (see & see) what I come up with > https://www.jalopyjournal.com/forum/threads/let’s-redesign-a-brake-pedal-arm.1290053/
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    THE WORST!!!!! :eek:
  16. mad mikey
    mad mikey
    OH! You are high tech.:D
    427 sleeper, Johnny Gee and alanp561 like this.
  17. swade41
    swade41
    from Buffalo,NY
    I cut up that center cap this afternoon, just another option, still trying to find a 45 degree neck in the correct tube diameter to make this all work together
    FB_IMG_1681424967677.jpg 20230413_170614.jpg 20230413_165611.jpg 20230413_163633.jpg
    lewk, enloe, rod1 and 12 others like this.
  18. 427 sleeper
    427 sleeper
    Welp... been sorting through the carbs and timing... found that I was still too rich and this damned thing REALLY likes it's advance. So I leaned everything out and left the timing at 42 degrees! No detonation, start's perfect hot, and runs at 185 degree's down the road. Instant throttle response, this little ******* will pull your nutz off if you don't pay attention! Went for a test drive, Wound it up to 7 grand in 1st and went for 2nd... ****in' clutch pedal stuck to the floor!!! Anybody that say's a Centerforce clutch doesn't stick overcenter is a lying Mother****er!!! :mad: So now, this weekend, I'm gonna put my 2800# Long set-up back in! The ******** never end's, but I love it all the same! :cool:
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Decision’s decision’s. Left swing or right swing? 121EA61E-264A-4BC3-9548-CCEBD1B252FE.jpeg
  20. I pulled the stock gas neck out of the wife's truck and cut it up, kept the end and threw the other piece in the trash. Now I wish I hadn't done that, because it would've worked perfect for what I need!
    Okie Pete, alanp561, swade41 and 2 others like this.
  21. lumpy 63
    lumpy 63
    Did you end up keeping the Eddy carbs? The Centerforce in my 37 never stuck the pedal to the floor and I shifted at 7200 ...But I've been called worse:D Glad the 56 is running good:cool:
  22. lumpy 63
    lumpy 63
    Why not a hydraulic switch Johnny? Iv'e been driving my 56 pickup for 11 years and have replaced about 4 of those aftermarket switches ... the damn arms fall off.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Great, more decision’s. Junk mechanical switch’s or junk hydraulic switch’s that’s available these day’s.
    Real answer, don’t want extra plumbing.
  24. lumpy 63
    lumpy 63
    Put a tee in the front brake line where it is somewhat accessible from under the hood. Changing those mechanical switches by myself is a royal PITA just sayin.
  25. swade41
    swade41
    from Buffalo,NY
    Mine is a fuel cell, I never knew there were so many damn ones, there's 6 bolt, 12 bolt, 120 mm bolt circle, 135 mm bolt circle, 2 1/2 fill pipe diameter, 1 1/2 diameter, 1 3/4 diameter, some made out of aluminum, some say aluminum but really steel with aluminum cap (which I don't even need), some ready to ship, some won't ship for a month.
    I get lost in the searches lol, just when I think I found the right one then one of the fore mentioned issues rears it's head.
    Crazy I tell ya !
  26. guthriesmith
    guthriesmith
    Finally got this together enough to put some paint on it. Hope to have it running early next week. :cool:
  27. What size is your cell? You can have this 10 gallon i have, and they have the fill adapter on Amazon for it.
  28. What is the year model on your block?
  29. guthriesmith
    guthriesmith
    Uh...not sure but it is a little newer than ‘65... :oops: And, technically it isn’t mine either. I am building it for something at work.
  30. Yup.... moobs and a pickle (?) in his pocket!
    Dick Stevens, scotty t and alanp561 like this.
