Technical Another what is it?
Discussion in 'The Hokey Ass Message Board' started by '34 Ratrod, Apr 12, 2023.
  1. I found this out in the desert today and I'm wondering if there's enough there to identify. I think I'll get the dash and straighten it out a bit and hang it on my wall. I like the look of the gauges. The car appears to all be there, it just looks like it was run over by a steam roller.
    Larry
  2. fastcar1953
    fastcar1953
    I'm not sure it matters what it is at this point.
  3. lowrd
    lowrd
  4. 56don
    56don
    Thats what is called s**** metal
    caseywheels, Tow Truck Tom and X38 like this.
  5. It doesn't matter. I was just curious. Sorry to use up 10 seconds of your life.
  6. Squablow
    Squablow
  7. Squablow
    Squablow
    That die cast tail light housing on the right rear fender (see lower right corner in the first pic) is still worth grabbing if it's not smashed.
  8. Thank you sir.
    Larry
    Squablow likes this.
  9. Mr48chev
    When I first saw those photos I thought that the only way you could tear something up that bad was to run over it with a cat or a tank. Sure enough look at the tracks across the quarter panel.
    Probably cut up in pieces and dumped out there in the 50's when a lot of s**** yards didn't want body sheet metal. 38 hudson door (2).jpg
  10. Speed Gems
    Speed Gems
    Looks like another project car for @JimSibley .
  11. '29 Gizmo
    '29 Gizmo
    from UK
    _methode_times_prod_web_bin_cb384ff8-83fd-11ea-b876-ef9d21d57c48.jpg Start digging, you may find more of it.
  12. clem
    clem
    ^^^^^^ the door still opens…………not all is lost………….:)
  13. Thats one of those lightweight Anglia g***er bodies :rolleyes:. Looks like it was hastily buried. I see a banjo steering wheel, gauges and even the handbrake lever.
    Just Gary and '29 Gizmo like this.
  14. catdad49
    catdad49
    Did you find a flathead with it?!
  15. 62rebel
    62rebel
    My Dad told me that s****yard operators used to pile all the old bodies and set them on fire to burn out all the wood and upholstery, then flatten the pile with a dozer. There were still piles of flat, rusty sheetmetal in almost every yard I saw in Central Virginia right up to the 90's.
    WalkerMD and alanp561 like this.
  16. Budget36
    Budget36
    I wouldn’t doubt it a bit. When I was a kid I grew up in the county, my Dad worked for electrical places and always snagged the leftovers of wires. He’d put the in a 55 gallon drum and mash them down. With the right wind he’d toss some gas in there light it off and burn the insulation off the wires.
    And now we have clean air days for reasons like that;)
    alanp561 likes this.
  17. Pass The Torch
    Pass The Torch
    "What WAS It"!
    210superair likes this.
  18. 210superair
    210superair
    from Michigan
    Those gauges are pretty cool tho...
    '34 Ratrod and Squablow like this.
  19. 62rebel
    62rebel
    Kind of amazing that those gauges even LOOK like they are salvageable! The surrounding trim, not so much
    210superair and '34 Ratrod like this.
  20. Model A Gomez
    Model A Gomez
    It amazes me how fast it was identified from the pictures, not much there that is identifiable.
    WalkerMD and Squablow like this.
  21. JD Miller
    JD Miller
    reminds me of Mike Wolf from American pickers digging up an old rust harley buried in some woman's back yard that he was told about
  22. I know!! I didn't have a doubt someone would identify it. What an awesome group of knowledge.
    Larry
