Hot Rods Fuel filter help
Discussion in 'The Hokey Ass Message Board' started by F1 Ford, Apr 11, 2021.
  1. F1 Ford
    F1 Ford
    I'm thinking of hooking up a return line on my '56 Chevy to help with vapor lock/hot start issues before the Texas summer hits hard (it's running a mechanical fuel pump). I'm going to try a 1/2" phenolic spacer first and insulate/reroute the fuel lines to see how that works -- the carb/fuel line is getting too hot after a long run and the fuel line can be routed better. It's a problem that's already rearing its ugly head. I searched this board and the Wix 33041 filter was recommended. I need it to have an orifice. Apparently Wix 33041 is unobtanium from every supplier I've found -- bummer as I prefer Wix products.
    Is there another part # someone can provide that functions the same as the Wix 33041? I'd like to tackle this problem soon.
  2. F1 Ford
    F1 Ford
    I appreciate that, but I'm looking for one that accepts 3/8" line w/ the orifice. I think that one's 5/16" on the inlet/outlet.
  3. Mr48chev
    Napa Gold 3041
    Other numbers that should cross
    WIX Replacement for
    AC DELCO GF98
    ATLAS FF12
    BALDWIN BF887
    BIG A FILTER 95041
    CARQUEST 86041
    CARTER GF18
    DELUXE 73012
    FLEETGUARD FF243
    FRAM G18
    GENERAL MOTORS 5650829
    GENERAL MOTORS 5651119
    HASTINGS FILTERS GF20
    LEE LG1118
    MOTORCRAFT FG12
    NAPA GOLD 3041
    PUROLATOR GF1118
    WIX 33041
    WIX OLD NUMBER WF41
    Just Gary, BJR and loudbang like this.
  4. moparboy440
    moparboy440
    from Finland
    Carquest 86041
  5. F1 Ford
    F1 Ford
    Mr. 48 Chevy coming through again. Thanks.
  6. F1 Ford
    F1 Ford
    Thanks, Mopar.
  7. jimmy six
    jimmy six
    F1ford.. you don’t saw what style intake you have or it’s material. If it has a carb heat crossover you can restrict it also. If not a 3/8” phenolic carb spacer really helps or has for me with every engine I run..
  8. 1957buickjim
    1957buickjim
    I too have a fun time with vapor lock in my 57 Buick wagon. I would like to add a vapor return line to the system, but it seems that all of the alternative filters Mr. 48 Chevy listed are also made of unobtanium, as none of those have showed up in any of my searches for them. Looking for any potential alternatives or solutions. Running a Carter 2536S 2 bbl carb on the 364 Nailhead. Just yesterday, I stalled during a drive and opened the hood to watch the fuel boil right out of my fuel filter. Not fun.
  9. This is what I found when I realized the 3/8 were unavail through regular scources. It has an orfice insert of around .080 iirc. Pricey but I had no other choice.
    NOTE: YOU HAVE TO MOUNT VERTICALLY
    and that is a typo on return size, it is actually 1/4"
    Screenshot_20230414_000439_Samsung Internet.jpg Screenshot_20230414_000451_Samsung Internet.jpg 20230404_121708.jpg
  10. 1957buickjim
    1957buickjim
    Thanks! Yes, pricey, but if it works, it's worth it to not have vapor lock stop you in the middle of a drive on a hot day!
    How did you make the bracket for vertical installation?
  11. Screenshot_20230414_055629_Gallery.jpg Screenshot_20230414_055224_Samsung Internet.jpg I just used one of these and a peice of flat stock off of an AC bolt
  12. 1957buickjim
    1957buickjim
    Thanks! I will look into getting one of those for the mounting. Thanks for your help!
    Just Gary likes this.
