Projects 1931 Ford Truck Hot Rod build
Discussion in 'The Hokey Ass Message Board' started by Knifemkr, Apr 13, 2023.
  1. Knifemkr
    Knifemkr
    I've had this project for quite a while. I am learning a lot of stuff and having a great time doing it. IMG_7145.jpeg IMG_7133.jpeg IMG_7146.jpeg IMG_7148.jpeg IMG_7155.jpeg
  2. Knifemkr
    Knifemkr
    Pete and Jakes front end parts getting mocked in place. My Nephew Sam is looking over the stuff and starting ***embly. IMG_7156.jpeg IMG_7157.jpeg IMG_7158.jpeg IMG_7160.jpeg IMG_7163.jpeg IMG_7172.jpeg
    tb33anda3rd, GordonC and osage orange like this.
  3. Knifemkr
    Knifemkr
    Time for welding. My Buddy Andy is the welder. IMG_7188.jpeg IMG_7190.jpeg IMG_7192.jpeg IMG_7194.jpeg
    GordonC, osage orange and Just Gary like this.
  4. Knifemkr
    Knifemkr
    Front end parts welded in...Back home to the Garage. IMG_7202.jpeg IMG_7204.jpeg IMG_7205.jpeg Sam holding the Grill. Yep, set the cab on to make sure I could sit in it comfortably...being 6'2 ish...It should be fine. I'm on the floor but it's plenty of room.
  5. Knifemkr
    Knifemkr
    Got some rear end parts in the mail. Drove to Rhode Island and got a Bed. These pics are old...I need to catch you guys up. IMG_7233.jpeg IMG_7252.jpeg IMG_7254.jpeg IMG_7270.jpeg IMG_7271.jpeg IMG_7269.jpeg
  6. As a model a truck owner I dig it. I am very concerned about that deep transmission crossmember, I think you will get high centered on speed bumps, it looks to be below the bottom of the front axle or close to it.
  7. Knifemkr
    Knifemkr
    Nick, I'll check it out this weekend. I have a lot more pics to post that might show the angle better. Thanks for pointing that out.
  8. Knifemkr
    Knifemkr
    Rear end parts getting welded. Andy back on the welder. IMG_7328.jpeg IMG_7329.jpeg IMG_7331.jpeg IMG_7332.jpeg IMG_7333.jpeg
  9. Knifemkr
    Knifemkr
  10. Knifemkr
    Knifemkr
    Time to prime and paint some stuff. IMG_7422.jpeg IMG_7423.jpeg IMG_7424.jpeg IMG_7425.jpeg IMG_7435.jpeg IMG_7443.jpeg IMG_7444.jpeg
  11. Packrat
    Packrat
    I think that axle may be cast, if so you may want to find a Ford axle that's been dropped.
  12. oliver westlund
    oliver westlund
    Nothing wrong with a well made cast axle....
    Knifemkr likes this.
  13. 31Apickup
    31Apickup
    You’ve got a late 31 cab, august 31 or later, same as I have. It will be a tight fit, once you get your pedals positioned and seat in place. I’m 6’-1”, I can drive mine fine it is cramped and don’t drive mine as much as I used to when I was much younger.
  14. Knifemkr
    Knifemkr
    This is quite relaxing priming and painting. IMG_7445.jpeg IMG_7446.jpeg IMG_7447.jpeg IMG_7462.jpeg IMG_7463.jpeg IMG_7465.jpeg
    tb33anda3rd and Bandit Billy like this.
  15. Knifemkr
    Knifemkr
    ...and more painting and dry fitting. IMG_7553.jpeg IMG_7554.jpeg IMG_7557.jpeg IMG_7558.jpeg .
  16. Knifemkr
    Knifemkr
    Sam and I putting more things together. IMG_7571.jpeg IMG_7572.jpeg IMG_7573.jpeg
  17. Knifemkr
    Knifemkr
  18. Hitchhiker
    Hitchhiker
    Nothing right about it either. If cast was "good enough" Henry would have done it.
    '28phonebooth and Packrat like this.
  19. oliver westlund
    oliver westlund
    Not saying theyre as good as a forged axle, thatd be foolish.... but safe? Of course they are.... if an okie adams is safe theeeeen why would a modern cast axle thats well made not be? 20230413_094432.jpg
    I mean since this is a traditional hot rodding forum not a henry made em perfect so leave em stock forum lol .....now that point made and aside, if you get in an accident that cast axle should get tossed and a replacement installed because they dont bend and bounce back like a forged axle, cant be repaired like a forged axle, shouldnt be heated like a forged axle but they do work just fine and are safe!;) I do say all of the above with respect hitchiker, no disrespect intended at all, due to my build parameters i ended up needing to use a cast axle which caused me to do a LOT of research on the pros and cons so at the moment its all fairly fresh in my head
  20. Hitchhiker
    Hitchhiker
    You're not wrong there. My stance is....if there is better available...why not? I also drive my cars a lot farther and harder than most people around...So that extra insurance is worth it to me. I sure would rather have a super Bell than a magnum! :eek: that is for sure.
    My whole thing is with this. With a forged axle... I know its good. No matter what cast axle it is...I HOPE it's good.
    My final point is..."If" the worst should happen, I'd rather my wheel,tire, and spindle combo becomes pretzels with the axle, than have it break and become a missile.
    And I think we can both agree, no matter what straight axle you have...it's still better than Mustang II :D
  21. oliver westlund
    oliver westlund
    Amen, for my application, finding a dropped 39 axle is dang hard, especially a 4" dropped 39 axle. Theres only one on the market and it wasnt cheap. I do however agree wholeheartedly, IF I had two axles side by side and one was forged, I would pay an extra cpl hundred for that one. That just doesnt mean the cast isnt safe. I think we are on the same page
    Hitchhiker likes this.
  22. Packrat
    Packrat
    Whatever you think. I wanted him to be aware that it could be a problem. There have been examples on here of them breaking.
  23. oliver westlund
    oliver westlund
    Low quality cast axles, yes. Super bell? No, I dont think so...they have a stellar reputation. Appreciate your intentions though
  24. Knifemkr
    Knifemkr
    Wow, how long was I gone?...LOL
    I really do appreciate all the input. Thank you.
    I'm sure I'll run into some quirks along the way.
    I'm here to learn and have fun building a truck.
    Hopefully I can get some more done over the weekend.
    oliver westlund likes this.
  25. fastcar1953
    fastcar1953
    Looks good . Only thing I noticed was not enough adjustment on rear 4 link. Looks like less than a inch.
  26. Knifemkr
    Knifemkr
    Ok...followed install directions. Thanks...I'll look at it.
    nothing is exactly in place...just lightly bolted together.
  27. Bandit Billy
    Bandit Billy
    The only thing better than building something is watching someone else build something.
    Entertain me!
  28. and..... helping them spend their money!
    oliver westlund and Bandit Billy like this.
  29. I'm 6'1" and am putting together a '29AA. Yeah, Model A trucks are a tight fit regardless of the year but I'm so tickled for you. Nice work and keep posting. Is that a small block Ford going in? What kind of transmission? Nice K-member and quite the stout, boxed frame. You'll be glad you did that.
    oliver westlund and Knifemkr like this.
  30. Model A Gomez
    Model A Gomez
    Several comments, first is that I like the way you're heading but the center crossmember does look low and the transmission will hang below it a little bit. In the picture with the tires mounted it looks fairly close to the floor and will drop more when the engine and trans are set in the frame.
    As to the room in the cab I'm 6'3" and 240 and drove my 30 as a daily driver for 19 years before a friend talked me out of it, it was a banger powered full fendered pickup. There is an art to getting into a Model A, I have a 30 Coupe 50's style hot rod and have to bend quite a bit to get out of it since the top is about chin high on me.
    Pocket Nick and Knifemkr like this.
