Technical 1954 ford 239 water pump… can I rebuild with the guts of a later pump?
Discussion in 'The Hokey Ass Message Board' started by flyin flattie, Apr 16, 2023.
  1. flyin flattie
    flyin flattie
    from Redmond OR
    I am at a cross roads. I’m thinking I’ll just order a rebuild kit and rebuild this the proper way.
    in the same breath I ordered a water pump (advertised 54-62 y block now knowing 54 is a one year )a year ago that’s technically useless now. So my question is has anyone used the bearing from the later pump in an early pump? I figured I’d ask before I pull out my micrometers and start scratching my head.
    hrm2k likes this.
  2. hrm2k
    hrm2k
    Sounds like hot rodding to me. Give it a try.
  3. flyin flattie
    flyin flattie
    from Redmond OR
    It worked! Had to cut the shaft down in both ends but thankfully the other pump was complete because the old impeller broke when pressing the shaft out .
  4. flyin flattie
    flyin flattie
    from Redmond OR
    Oh and I had to cut down the inpeller 4DA1A420-9E8A-4F22-AF4E-111A37550E2B.jpeg
    '29 Gizmo and jaracer like this.
