Hot Rods 1955-59 chevy truck gauge I.D. question
Discussion in 'The Hokey Ass Message Board' started by crider, Apr 20, 2023.
  1. crider
    crider
    I bought a 55-59 truck gauge cluster to use the temp gauge in my 54 delivery. Now I need to get the proper sending unit to match the gauge. As I understand it, the 56 gauge uses a different sending unit then the later gauges. My question is, how do I tell what year cluster I have so I can get the matching sender.
  2. crider
    crider
  3. 325w
    325w
    If the gauge is electric I think you need the 56-57 sender..
    crider likes this.
  4. Pic would help !
  5. squirrel
    TS-6 seems to work for me....
    the 55 cluster uses a mechanical gauge.
    There might be a date stamped on the cluster, usually on the speedometer. Like the rubber date stamp they used in the library when you checked out library books in the 1960s, remember?
    crider, X-cpe and 49ratfink like this.
  6. crider
    crider
    I wasn't around in the 60's...lol, but I know what you're talking about on the date stamp. I'll look at the cluster and see if I find one. I was just under the impression that 56 and 57 sending units didn't interchange
  7. squirrel
    Maybe they don't. I've only used the TS-6 on old trucks, but maybe it's wrong?
    1513130 and 1513321 are the GM part numbers for the 56 and 57 and later senders.
    crider likes this.
  8. crider
    crider
    I don't know for sure either, so much internet info is wrong, and I know very little about 50's GM gauges and senders
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Jim, didn’t the truck’s continue using the 1956 (one year only for cars) temp unit until the new truck body style come out?
  10. squirrel
    I just looked in the 59 Chevy parts book, it lists different sender numbers for 56 and 57-59. The listing says ALL for each set of years, which includes cars, trucks, and Corvettes.
    I haven't looked into the aftermarket cross references yet, though.
  11. Mr48chev
    crider likes this.
  12. squirrel
    Oh yeah...the connector is probably the only difference. Thanks for the reminder about the pin.
    So just use a TS-6 and don't worry about it.
  13. crider
    crider
    I had to cut the little cup that mounts to the back of the 54 gauge cluster and add a strip of metal to make it 3/8" deeper. Gauge looks identical to the original 54 gauge once it is in the cluster. I'll try to remember to take a couple pictures tomorrow. Thanks for the help on the sender.
  14. crider
    crider
    Thanks for the help Squirrel
