Technical What are these mounts?
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Apr 20, 2023.
  1. oliver westlund
    oliver westlund
    Any ideas? Thought panhard but on both sides underneath? Thought sway bar but that doesnt seem right...shock mounts? Doesnt seem right either Screenshot_20230420_205954.jpg Screenshot_20230420_181901.jpg
  2. Dedsoto
    Dedsoto
    from Australia
  3. oliver westlund
    oliver westlund
    Location seems odd for that being directly under the axle
  4. X38
    X38
    As Dedsoto said. Plus, it needs a wide base spacer and should have tubes welded inside for support, not just holes in the plate.
    Just Gary and oliver westlund like this.
  5. oliver westlund
    oliver westlund
    Im not gonna run it like this, just wanted to know for sure what they were before i cut them off
  6. millersgarage
    millersgarage
    Coil over mount.
    I was a little confused about the open drive coming out of the top of the diff, then looked a little closer... :)
    oliver westlund likes this.
  7. Jim Mothershead
    Jim Mothershead
    Yep, coil over lower shock mounts from Total Cost Involved = TCI
  8. 42merc
    42merc
    Pete & Jake shock mounts.
    Check their catalog.
    warbird1 and oliver westlund like this.
  9. Me too, I hate to admit. 1st impressions?
    Ben
  10. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I think I would moch up the rear end in place before I cut them off. They may end up being where you "need" as opposed to where you would like to put them. They can always be removed if its wrong for your vehicle.
    warbird1, oliver westlund and swade41 like this.
  11. oliver westlund
    oliver westlund
    Hahaha yeah was a bad choice of pics but all i had at the moment
  12. oliver westlund
    oliver westlund
    I think I will do just that, thanks. Mostly I dont dig the look but I may be able to change that later
    ekimneirbo likes this.
  13. Marty Strode
    Marty Strode
    The shock mounts I like to use are from 65-70 full size Fords. They have style, offset, and can be trimmed to the proper height and housing shape. IMG_0089.JPG IMG_0090.JPG
  14. DDDenny
    I like these!;)
  15. Marty, good choice on the shock mounts.
  16. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Yes, I like the look of those brackets Marty. The thing I like about some other brackets is that they have more than one possible hole location which can help with getting a car to sit just the right height or use a slightly different coil over shock length. Usually someone fabricates a solid bar with the same length as the disired shock. When the actual shock is put on, it may settle some......or if you get a longer shock to offset the settling, it may sit the car slightly too high.....or using a softer spring later because the car rides too harshly. Some people can get it just right the first time. Me, I prefer to build in adjustability. I had a conversation with a guy at a rod run last weekend. He said his tires didn't rub, but it rode rougher than he liked. Was afraid to soften the springs.
    I like to use a bracket similar to what Oliver has with multiple holes. Then I make an additional bracket with multiple holes that bolts to it. Between the two brackets I can adjust to get what I want/need. Additionally I add a few mounting points on the frame crossmember to allow tilting the shock. With all of that, I can pretty well find the best working condition and get the car to set like I want. Also, in this case the bracket also holds the 4 bar linkage in front.
    alanp561 and oliver westlund like this.
  17. oliver westlund
    oliver westlund
    I wont be running coil overs, just some chrome tube gas shocks so its purely aesthetics to me. Car will have an A spring pack and the 36 bones with a torque arm. I may be able to use these as a shock mount though and it may look okay, i dig those 65-70 mounts marty pictured! Thats more along the lines of what I picture in my head
  18. Marty Strode
    Marty Strode
    I don't use them for coil overs, just standard shocks. Normally, when building a car, I know the ride height I am shooting for, so I remove spring leaves and or ***imilate weight to get to that height. Like on my RPU, ride height needs be an inch or so higher for the dragstrip. Also, there is some la***ude with standard tube shocks. IMG_9968.JPG
  19. Shock mounts
  20. RICH B
    RICH B
    Gas shocks don't always work out on light rear end weight hot rods.
    oliver westlund and X38 like this.
  21. Do you know how a car works?
  22. oliver westlund
    oliver westlund
    I do! Thanks for checking chief! Do you know how the bird works?
  23. oliver westlund
    oliver westlund
    This has been well covered already if you read above comments ;)
  24. oliver westlund
    oliver westlund
    Wont know til I get there, 10 gal tank and battery will be in the trunk but it will still be light. I have a little ways to go before I need to worry about that
  25. You got called out hard. You took it well. Many of us miss the old HAMB when you would have ever been known as SHOCKMOUNT?
  26. oliver westlund
    oliver westlund
    I must've missed getting called out "hard" you can have all the pet names you want for me, might wanna take me dancing first...
