Projects CONVERTING A 1933 FORD FOUR DOOR SEDAN INTO A 5 WINDOW
Discussion in 'Traditional Hot Rods' started by H-O-O-V-E-R, Aug 10, 2017.
  1. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    48C65304-AE1A-493E-9B9D-DABE9B8AF11B.jpeg 8CA7D4F6-06D6-4E85-BEC9-F037479F6572.jpeg
    This is how she turned out. Not too bad. Still needs a little love of course but I’m pleased with how it turned out. Also, I’ve been hunting for a quickchange for quite a while. Would love a halibrand 201 or at this point I would even settle for a rodsville. Also I have been hunting for the illusive 18 inch ford wide 5s for some years now. If anyone has any leads or can spare a few hot rod parts I could use some help tracking stuff down. I’m located in Utah. A little trickier to find parts around here. I’m headed to California this week though hoping to maybe meet up with some like minded people and find some parts. Thanks for the support!
  2. dirt t
    dirt t
    You sir are a craftsmen.
    H-O-O-V-E-R likes this.
  3. Aside from your skill, the thing that you exhibit most is perseverance.
    Algoma56, H-O-O-V-E-R and The37Kid like this.
  4. rod1
    rod1
    Your father and you are a good team. Car looks great.
  5. The37Kid
    The37Kid
    Great project, thanks for all the photos & details. Bob
  6. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    I don’t know about that. But thank you!
  7. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Thank you. It definitely is a labor of love. Gotta always keep the vision going.
  8. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    I appreciate that!
  9. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Thanks for following along and supporting Bob!
  10. micshotrodgarage
    micshotrodgarage
    from colorado
    I can tell this is a labor of love for you and your father. You have been at it for a long haul. I lived in Orem through the 80s and 90s there was a 33-34 four door and a two door sedan bodies along with a 36 coupe in a field I lived by, but I never could get in touch with the land owner, And one day I went by and it had all been cleaned out. Keep up the fine work. Mike
  11. Magfiend
    Magfiend
    I've got a Halibrand V8, newer case, aluminum bells, steel tubes, finned cover. Has a diff inside and 4 lug axles (is currently in a mini stock ch***is).
  12. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Wow Mike! Wish those bodies were still laying around. How cool you lived in Orem. That’s where I am. Thanks for the kind words!
    Outback likes this.
  13. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    I’ll send you a message thanks!
  14. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    here you can see the back bottom part of the door does not sit flush with the quarter panel. Most likely the quarter panel is off a tad is my guess. B83721C9-AC70-4A94-B7AA-ED423B8717E5.jpeg
    It bugged me so I cut into the door frame and pulled it in so it will sit more flush. 2110D57D-423C-4955-8FC3-74E0EF061764.jpeg E10E3C79-D87D-45D3-A07D-5DA7C7A23691.jpeg Final result turned out pretty good!
  15. Outback
    Outback
    from NE Vic, Oz
    That's the detail that really lift's a car & puts it in another cl***! Well done for ch***ing the details that came up really nice! :D
    H-O-O-V-E-R, Algoma56 and The37Kid like this.
  16. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Thank you! I agree. Sometimes things just nag at you until you fix them. Like a bad itch.
    Outback, Algoma56 and The37Kid like this.
  17. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    51DF1314-05C1-48C4-9B93-447D52D81CB3.jpeg I’ve been dreading fitting the trunk for a few years now. Decided to finally try and tackle it. I’ve been wrestling the trunk lid on the ground to get it to fit properly. It’s getting close. It’s tricky getting the hinges the right height and get everything tacked in place. As far as this gap goes its took some extra attention. I decided to weld in a small flanged strip of metal to make up the difference. 49BE485C-F156-443D-9275-5B54C3B20CF7.jpeg
    getting it tacked into place.
    That’s it for now. It’s close. Gonna take some fine tuning as always but getting closer.
    JalopyJimbo, Squablow, brEad and 10 others like this.
  18. Tim
    Tim
    from KCMO
    Way better!
  19. Bad Bob
    Bad Bob
    from O.C. Baby
    Anybody can tack on metal and beat it with a hammer, even me. It takes real skill to make it look like it came that way, flowing and aligning. You have great skills Hoover....
  20. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Thanks! Still going to do some height adjustment but it at least is closer for sure.
  21. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    I appreciate it Bob! Just learning as I go. Definitely not perfect but I think it will do the job.
    dirt t likes this.
  22. Bad Bob
    Bad Bob
    from O.C. Baby
    I've worked with metal all my life, but forming metal to match compound curves, belt lines, etc is tough. I'm amazed by some of the craftsman i've followed on the HAMB. FlammedA-Bone( I think he goes by), for one.
    Outback and H-O-O-V-E-R like this.
  23. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Yeah there are some really talented guys out there. Fun to see what is possible.
    Outback likes this.
  24. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    this is the front of the driver side window. You can see how uneven the inner part of the window frame is. I had to make this flush with the other parts of the window for the gl*** to fit. Also because it looks horrible. 543E1C59-BAAC-41BE-BA33-9159CEBFE48F.jpeg
    I cut a flat board out in the shape of the window to be able to tell if I am flush. Also you can see the small piece coming into shape to make up the difference. 2F3715CD-3ACE-43B1-8234-E742E21F5B66.jpeg 1CEBE4EA-9AF7-48BC-9A2E-C0BAE525A82C.jpeg
    65AE2378-F41E-4DCE-B33C-416F296A6AA9.jpeg D38CB03F-E4C6-4DEA-A119-B3314341876E.jpeg 58850ECA-1D07-4509-9A67-18FAA5D7E3B2.jpeg
    ready for a window now. Actually I still have to do the back of the window tomorrow. Thanks for looking!
  25. micshotrodgarage
    micshotrodgarage
    from colorado
    Patience is a virtue' and you are exhibiting that with this project. Keep up the great effort. I enjoy seeing you're progress.
  26. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Thank you, I appreciate the encouragement! I’m excited to get these windows finished up and then I can start tackling all the little small things that need to be ****oned up on the car. Next up it finishing the fit of the trunk.
    The37Kid likes this.
  27. Car looks WICKED! Amazing what can be accomplished with a bunch of hard work.
    -Brent-, H-O-O-V-E-R and The37Kid like this.
  28. Atwater Mike
    Atwater Mike
    Well, H-O-O-V... This is 267 posted reasons for me to buy a water cooled TiG welder!!!
    Love the cool (opposite of HOT cool) tacks and beads throughout.
    Mastery of this machine is illustrated in spades. Kudos to you! Say hi to your Dad. (I'm a senior too)
    JalopyJimbo, H-O-O-V-E-R and The37Kid like this.
  29. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Thanks! I agree. It’s gonna be worth it in the end to know I haven’t cut any corners.
  30. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Haha thanks mike! I’ll tell him hello for you. Yeah I got the old Lincoln tig at a school district type surplus sale for a deal. Had to add the water cooler. That machine hasn’t missed a beat. And yes the inside of the car is just riddled with ground down welds. I actually like to see them because you can see how much work has been put into it. Appreciate the kind words!
    Outback and The37Kid like this.
